Did you add any xbox
entries into your configuration.yaml
? You don’t need them.
Never configured it before, so I would say no.
Odd. Is it already configured somewhere? Do any dialog boxes show up before that?
No other configuration was done, and that’s the first and only box that shows after selecting Xbox from Integrations -> +
If you do this on a clean-slate HA instance do you get this? You should raise an issue over at the core anyway.
Yeah, it’s already reported by others as well.
Looks like a nice update, I’m looking forward to trying the Tasmota integration.
I can’t seem to find Tasmota 9 however, I can only find 8.5.1 on the releases page.
The docs for the tasmota integration state that v9.0.0.3 is needed.
- Tasmota devices flashed with 9.0.0.3 or later
I believe that version is on the development branch. It’s a beta, after all.
Thanks I missed that, I think I’ll wait for the stable release before flashing
Was wondering about this too. The HA MQTT integration is working perfectly with all my 8.5.0 devices, so I guess I’ll just stay there until this matures.
Same. Not sure what I should change here or just stick to current…
I guess I have one I can play with… so I turn discovery off and then add the Tasmota integration after flashing 9.0.0.3… BRB…
This is great
This is welcome
This is fantastic
Well that seems pointless.
As soon as I setoption19 0, the Tasmota automatically was discovered in integrations. Add Tasmota and it has the device in Tasmota integration as well as MQTT.
But it doesn’t have the status sensor available with all these goodies:
So not sure what’s the point??
Then reversing it, it renamed the switch to something else…
I’m really looking forward to testing the Panasonic Viera fixes. it’s been a major pain since 109. I will update tonight
Breaking Changes
Below is a listing of the breaking change for this release, per subject or integration. Click on one of those to read more about the breaking change for that specific item.
(Unclickable list follows)
Where can I read about the ISY994 breaking change?
@pashdown, Something has gotten messed up with the 0.117.0 Blog post above. The details on Breaking Changes and other times have disappeared. I am sure someone will get that fixed.
As for the ISY, the main breaking change is the new support for decimal precision for Variables. If you had a variable being brought from the ISY into HA, and that variable had a precision (as in 2 decimal places) set, it would in the past not display correctly. Before, you had to manually do the precision conversion. Those manual conversions must now be removed so that they are not converted twice.
For example, if the variable was 1.45, before it used to come over as 145, and you had to divide by 100. Now, it will come over as 1.45.
This is a really good one! Doesn’t seem to close if the last dismissed item was done as an individual item though.
This is not the blog, it is the forum post about the blog item. If you go to the blog, they are clickable: https://www.home-assistant.io/blog/2020/10/28/release-117/#breaking-changes
I am very excited about the automation and script editor! There was recently a script posted for status led notifications that I deemed “not worth it” to implement but that is no longer the case.
I was under the impression that adaptive lighting would be included in this release. I tried to check github to get the status of it, but my github navigating ability only got me so far. Does anyone know when/if it is going to join core?
Tried FF and Safari. Not clickable for me.
