I use this script (see last post) for resuming both TuneIn and Spotify on my Google Home device after a TTS broadcast.
Volume is not included, but shouldn’t be to hard to add as an extra variable.
After updating to 117.0, the webinterface was not working anymore. If someone else has the same issue, this is how i “solved” it (don’t know the correct messages anymore) via CLI::
- run command “core restart” gives a 500 error with some message like “containerID is marked for removal” and it wont restart
- run command “core update” gives a processed successfully, there after a 404 error.
- run command “core restart” works
there after 117.0 was starting, but my zigbee sensors did not work anymore, but i was able to start the webinterface again and restore 116.4 backup.
Yes, for the Supervisor, the plugins and eventually the add-ons it will change, it’s mentioned here https://developers.home-assistant.io/blog/2020/10/29/supervisor-update#releases
Hi!
since the update, rest sensor is not working anymore.
Platform rest not ready yet. Retrying in 150 seconds.
Am i the only one?
I have many rest sensors, all working.
That’s pretty cool Ludeeus… great info.
ok so it might be me…
Same problem for me, after updating from 0.116.4 to 0.117, HA no longer works, a reboot does not work, it looks like a problem with OZW, I had to restore a full image.
Looking forward to the Tasmota integration. But after updating I lost all my unused entites!! ;-( I had about 20 of them and after updating 0.
Go back to 116.4 and rest sensor are working…
How can i enable more logs for rest sensor ?
How can I downgrade to 0.116.4? I have access to IDE and commands like:
hassio homeassistant update…
I am getting these strange errors (at the end of the log) when onboarding on a fresh installed Hassos 5.4:
09:30:50 All core tasks are scheduled
09:30:50 Started Supervisor hardware monitor
09:30:50 Supervisor is up and running
09:30:50 Home Assistant setup
09:30:50 Updating local host information
09:30:50 Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:0.117.0
09:30:50 Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 0.117.0.
09:30:50 Updating service information
09:30:50 Updating local network information
09:30:50 Updating PulseAudio information
Failed to load cookie file from cookie: No such file or directory
09:32:29 Stopping homeassistant application
09:32:34 Cleaning homeassistant application
09:32:34 Home Assistant docker now installed
09:32:34 Starting Home Assistant
09:32:34 Update pulse/client.config: /data/tmp/homeassistant_pulse
09:32:34 Starting Home Assistant homeassistant/raspberrypi4-64-homeassistant with version 0.117.0
09:32:34 Wait until Home Assistant is ready
09:32:44 Updated Home Assistant API token
09:32:44 Detect a running Home Assistant instance
09:32:44 Cleanup images: ['homeassistant/raspberrypi4-64-homeassistant:landingpage']
09:56:26 Successfully imported 4bdcec99
09:56:35 Partial-Restore 4bdcec99 start
TypeError: Verbindung zum Server konnte nicht hergestellt werden.
That is running for half an hour now.
What can I do?
How do I activate the compact header in 0.117 or is it by default?
By default. Uninstall before upgrading the old cc.
My cameras have stopped too, they don’t appear as entities anymore, so don’t show up in my lovelace UI and automations that use camera/snapshots fail
Error executing script. Service not found for call_service at pos 1: Unable to find service camera/snapshot
Not sure if this applies to the others having issues with their cameras, I was running ‘BOM’ radar as a camera, The BOM platform is no more, so I commented out the BOM radar camera in my config and rebooted, now all my other cameras have come back to life. Hope this helps.
that wouldn’t have to do with CH. It’s still working as before, beautifully I might add.
don’t suppose this the intermittent buggy left-side menu has anything to do with that … ?:
Am I really??
Homeassistant OS
at first believed this to have to do with the beta versions, but now this is on release, should be all ok?
ha core update --version=0.116.4
