@thomasloven, would you consider enabling the use of comments in the YAML editor for automations? If I add a comment now it just gets deleted. Could that be enbled somehow? I really like to comment my automations so that I know what I “thought” when I created it, just to make it more readable for others, and myself.
However, I don’t find it to be as flexible as comments which can be inserted on any line and even be used to ‘comment out’ lines of code.
That’s one of several reasons why I don’t use the Automation Editor. Nevertheless the recent enhancement is a welcome addition for users with less demanding needs.
I think I have the same problem after updating to 0.117 from 0.116.4 OZW beta no longer works and all my Esphome devices that have temp sensors no longer report temp. I can also not restart from the restart menu. Restoring 0.116.4 worked.
I have switched off/on Rpi4 but no luck.
In supervisor logs I have:
ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
and when I do the downgrade to 0.116.4 I get:
ERROR (MainThread) [supervisor.utils] Can’t execute update while a task is in progress
No, this doesn’t do anything (see Update to 0.117 just bricked my system ), cannot rollback the core version, cannot restore from snapshot, tried ‘ha supervisor repair’ but this just hangs etc…, totally shafted…
Okay. Everybody’s reporting bugs. Look: The forum topics are a place for support, the forum comments are a place for reactions, and the GitHub issues are a place for bugs.
Has anyone else’s header completely disappeared? I don’t have a header anymore unless I click the 3 dots in the top right to edit my dashboard. I have the Soft-UI theme installed, but even if I switch to different themes, it doesn’t seem to change. I used to have Compact Header installed but removed it before upgrade
