I have a similar issue with SabNZB sensor component. Was working fine in 0.65, and have updated to 0.65.1, but the issue is still there, though Wunderground is working again.
2018-03-11 00:32:21 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform sabnzbd
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/sabnzbd.py", line 152, in async_setup_platform
if not (yield from async_check_sabnzbd(SabnzbdApi, base_url, api_key)):
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/sabnzbd.py", line 62, in async_check_sabnzbd
yield from sab_api.check_available()
File "/srv/homeassistant/lib/python3.5/site-packages/pysabnzbd/__init__.py", line 43, in check_available
with aiohttp.ClientSession() as session:
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/client.py", line 742, in __enter__
raise TypeError("Use async with instead")
TypeError: Use async with instead
Also, another error I have that has popped up since 0.65 is the following. No idea what itâs about.
@cjsimmons Thanks for the sanity check! I have definitely confirmed that removing the http password fixes the issue.
@DavidFW1960 - Iâve tried it on 2 win 10 machines with both chrome and edge - same issue - also showing same from android phone as well.
Edit: Just installed 65.1 - no help with http password and menus so far.
Ok - another oddity around this - removed http password so it would go back to normal until this is sorted out. Checked with Chrome from Win 10 laptop - all is fine. No password - menu looks good.
Check from same laptop with IE 11 (not edge) - get password prompt (which I confirmed in chrome was off and double checked config file in HASS). Menu is now messed up in IE just like Chrome when password is enabled. Cleared IE cache - no difference. Refresh page again - no password prompt now (no changes made in HASS) - but menu is still messed up. Edge however on same latptop shows ok and no password prompt when I access HASS.
Also - the screenshot/gif shown in the post for changing the light name does not appear to be working for me (at least so far) - my 65.1 instance is on a test box with one yeelight it discovered via wifi, I can turn on.off/change my yeelight with this HASS instance. However - I donât see the cog wheel when I click on the light to be able to change the name, Am I missing something or is this just because the yeelight isnât supported for the name change from the front end or something along those lines?
One question, Iâm running hass on synology container in docker. Before upgrade it used to use about 700MB of ram, but after upgrade to 0.65.1 it uses over 2GB of RAM! I cleaned container couple times it didnât help. Anybody noticed that?
I am also trying to upgrade python from 3.5.2 (default Ubuntu) to 3.5.5 but canât figure out. Tried using PPA no luck it says it has already.
If someone can provide step by step details for Ubuntu 16.04 LTS how to do this will help a lot many people like me.
If I figure out will update this post with the steps.
Thansk
The same basic process applies - build Python from source, and install it. Then call the new version explicitly (eg python36 rather than just python3).
Thatâs the point of LTS, having a stable environment for server usage.
16.04LTS is still supported and well updated.
There should be a LTS soon (18.04 announced on Apr 26th) and this is the way to go for users having an LTS, not adding other packages from external sources.
People using LTS and sticking to it, including me, do that on purpose. I have other services on other VMs with 17.10, but Home Assistant is controling my home, some security devices, I donât want the system to be a risk.
So I posted an issue earlier about my iOS device tracker setting my status as not_home. I thought it was only in the iOS app, but seems to be happening in Safari too. Also, the pull out menu items on the left are lower case, and some are missing entirely.
If I refresh the iOS app or Safari, it fixes it temporarily until it times outs.
Appreciate it.
I will try and see how it goes because I have Home Assistant running with ssl using letsencrypt certificate so I will have to see anything else I will have to do.
Thanks a lot.
