0.81: new Lovelace cards, LG soundbars, Dyson fans, Elk-M1
Same here with the 81.1 docker tag.
Show up as 0.81.0.dev0 in HA
Yes, fixed with 0.81.1.
0.81.1 fixed the red boxes with vertical-stacks - Thanks!
It also (partially) introduced the thermostat for Tado, however the only controls present were thermostat temperature and the current (measured) temperature:
33%20PM
Samsung_tv component broke in 81.0
Hassio 81.1 isn’t available yet?
Doing a docker pull with “0.81.1” tag and “latest” tag is still showing “0.81.0.dev0”.
Did the vertical/horizontal stack fix make it into 81.1? If so, the problem still exists
To clarify, it is specifically the homeassistant/raspberrypi3-homeassistant latest docker image reporting 0.81.0.dev0.
The same here, reverted to 80.3 and everything works again.
Tried to upgrade to .81.1 to get the red box fix and I am too seeing .81.0.dev0
edit: Raspberry PI using hass.io
Logging from my upgrade:
18-10-29 16:51:07 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-10-29 16:51:17 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.81.1
18-10-29 16:51:17 INFO (SyncWorker_6) [hassio.docker.interface] Update Docker 0.81.0 with homeassistant/raspberrypi3-homeassistant:0.81.1
18-10-29 16:51:17 INFO (SyncWorker_6) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.81.1.
18-10-29 16:54:11 ERROR (MainThread) [hassio.utils] Can’t execute update while a task is in progress
18-10-29 16:57:04 INFO (SyncWorker_6) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.81.1 as latest
18-10-29 16:57:04 INFO (SyncWorker_6) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-10-29 16:57:38 INFO (SyncWorker_6) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-10-29 16:57:39 INFO (SyncWorker_6) [hassio.docker.interface] Cleanup Docker images: [‘homeassistant/raspberrypi3-homeassistant:0.81.0’]
18-10-29 16:57:56 INFO (SyncWorker_12) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.81.1
18-10-29 16:58:57 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
same problem here showing 0.81.dev0 using hass.io on raspberry pi
One more on the list! I also get 81.0.dev0 on the version sensor although the system log says:
18-10-29 17:38:01 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.81.1. The vertical stack in my lovelace UI is still broken.
Great work other wise! I really enjoy Home Assistant!
Is it possible to update to 0.81.1 for HASSIO on NUC?
i have same problem (getting red box messages) on version 81.0.dev0.
Is this really version 81.1 or is it previous?
after upgrade Ecovacs Vacuum stop working, in the log appears the following:
2018-10-29 17:49:14 WARNING (SyncWorker_3) [sleekxmpp.basexmpp] fulljid property deprecated. Use boundjid.resource
2018-10-29 17:49:18 ERROR (read_thread) [sleekxmpp.basexmpp] day is out of range for month
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py", line 1492, in _process
    if not self.__read_xml():
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py", line 1564, in __read_xml
    self.__spawn_event(xml)
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py", line 1632, in __spawn_event
    handler.prerun(stanza_copy)
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/handler/callback.py", line 64, in prerun
    self.run(payload, True)
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/handler/callback.py", line 76, in run
    self._pointer(payload)
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/features/feature_starttls/starttls.py", line 64, in _handle_starttls_proceed
    if self.xmpp.start_tls():
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py", line 889, in start_tls
    cert.verify(self._expected_server_name, self._der_cert)
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/cert.py", line 133, in verify
    not_before, not_after = extract_dates(raw_cert)
  File "/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/cert.py", line 111, in extract_dates
    not_before = datetime.strptime(not_before, '%Y%m%d%H%M%SZ')
  File "/usr/local/lib/python3.6/_strptime.py", line 565, in _strptime_datetime
    tt, fraction = _strptime(data_string, format)
  File "/usr/local/lib/python3.6/_strptime.py", line 528, in _strptime
    datetime_date(year, 1, 1).toordinal() + 1
ValueError: day is out of range for month
2018-10-29 17:49:24 WARNING (MainThread) [homeassistant.components.vacuum] Setup of platform ecovacs is taking over 10 seconds.
2018-10-29 17:50:14 ERROR (MainThread) [homeassistant.components.vacuum] Setup of platform ecovacs is taking longer than 60 seconds. Startup will proceed without waiting any longer.
thanks and regards.
I’m pretty sure it’s just mis-tagged. I did a hassio ha update -o version=0.81.1 yesterday and got the dev version too so I downgraded to 0.81.0 and thought I’d just wait. Today the front-end says 0.81.1 is available so I update via the hassio panel and again it’s saying 0.81.0dev0. I’m running the
homeassistant/qemux86-64-homeassistant image. So seems all hassio images are mis-tagged.
Just updated (shows 0.81.1dev0) and all my horizontal stack with inside custom cards are showing the error
I’m still seeing horizontal-stack and conditional cards broken on hassio 0.81.1. Is there a workaround for this issue?
I’m seeing the same thing for my MQTT Thermostat.
MQTT%20Thermostat
Just the Thermostat temperature and the current temperature.
It seems from reading the different posts that the problem is fixed in 0.81.1. But a lot of us, including me, get 0.81.0(dev) where it is not fixed.
0.81.2 out now fixes it for me.
