0.87: SmartThings, Areas and Entity Registry UI.
Thank you @GreenT, it was a base url issue. All good now except getting zwave locks over.
Huh. Interesting. News to me. Thanks for the heads up. Will do that.
https://github.com/home-assistant/home-assistant/pull/20930
I don’t see the 0.87.1 docker build. Am I missing something?
https://hub.docker.com/r/homeassistant/home-assistant/tags
Yes, patience.
Thanks, no worries.
that’s true but not entirely accurate. and the link you pointed is pretty sparse. Here is a better link with a better explanation:
When trying to use the new QRCode component I’m getting “ImportError: Unable to find zbar shared library”.
How do we get zbar installed in hass.io images ?
https://github.com/home-assistant/home-assistant/issues/20875
Kudos!! I can finally move off of Smart Things and leave my trusty webcore behind until I get my Z-Wave/Zigbee stick
Just updated to 0.87.1 and now getting the below errors:
Log Details (ERROR)
Mon Feb 11 2019 14:31:42 GMT+1100 (Australian Eastern Daylight Time)
Error doing job: SSL error errno:1 reason: SSLV3_ALERT_CERTIFICATE_UNKNOWN
File “uvloop/sslproto.pyx”, line 504, in uvloop.loop.SSLProtocol.data_received
File “uvloop/sslproto.pyx”, line 204, in uvloop.loop._SSLPipe.feed_ssldata
File “uvloop/sslproto.pyx”, line 171, in uvloop.loop._SSLPipe.feed_ssldata
File “/usr/local/lib/python3.6/ssl.py”, line 689, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:841)
Thanks for the clarification. That makes sense why I had never previously run into this.
After upgrading to Hass.io to 0.87.1 on my rpi (raspbian lite) my ffmpeg camera which was working with rtsp:// ,
Stopped working.
Any one who has the same problem?
Why is 0.87.1 still not available for docker now two days later?
It just only me whom safari is crashing on states page?
in progress now
You really need to post an issue on github.
Had the same problem, and all my automations were also broken
This fixed it, cheers
Same issue for me!
I’m trying to get my RPi HassIO to update from 0.86.4 to 0.87.1 but after clicking ‘update’ it sits there (I wait thinking it’s updating) then after I wait for A LONG time I find that the Pi has crashed. I’ve tried a couple of times. Nothing in the log (which of course gets wiped at reboot) and no breaking changes for this update relate to my code. Any ideas?
