At least replace this:
card:
- type: entities
with this:
card:
type: entities
card:
- type: entities
with this:
card:
type: entities
Yeah I saw it after i posted it and i was trying to fix it. Finally it works⌠Thanks a lot!!
@DavidFW1960, sorry for direct mentioning, you wanted to use "config-template-card"
for:
"secondary_info"
or "card-mod"
(see examples above)."icon_template"
) in config (if possible);"Custom UI"
(never used by myself so far, I am still learning, but I know that it may be used for this);"device_class"
for this ("signal_strength"
may be? Update: seems NO).Means - you may not use "config-template-card"
at all.
Yep Iâll try that tomorrow as well as a few of your other suggestions.
Deprecated so not doing thatâŚ
Maybe⌠Iâll need to investigate that. The sensor is an MQTT sensor⌠Iâll look into that.
No problem. I appreciate your help and ideas. I will respond after I have a go at it in the morning. Bed time now.
Oh. I did not know that ))). Heard a lot about using it, planned it - and now it seems to be uselessâŚ
Yeah so I canât get this right.
- entity: sensor.coffee_maker_firmware
type: 'custom:multiple-entity-row'
show_state: false
styles:
width: 66%
icon: "${coffee >= 100 ? 'mdi:wifi' : coffee >= 80 ? 'mdi:wifi-strength-3' : coffee >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
entities:
- entity: sensor.coffee_maker_status
styles:
width: 15%
- entity: sensor.sonoff1_2914_wifi_connect_count
styles:
width: 15%
- entity: sensor.sonoff1_2914_signal
styles:
width: 35%
- entity: sensor.sonoff1_2914_rssi
styles:
width: 35%
secondary_info: "${( coffee >= 100 ? 'Excellent' : coffee >= 80 ? 'Good' : coffee >= 60 ? 'Fair' : 'Weak' )}"
Looks like this:
With no styling it looks like the toothbrush one.
Iâm also mindful of how it looks on a mobile device.
Iâd like to use percentages so it doesnât screw up the mobile device as well.
Ideally Iâd like all the columns to align with each other whereas right now if the RSSI is 100% the get thrown out of alignment and it right fills the whole row:
Tried setting
styles:
width: 150px
and also
styles:
width: 35%
but they just look the same.
Finally the device_class is signal_strength and the icon doesnât change so I think I need to stick with the template. Just saw your edit lol!!
Anyway so my only remaining issue is aligning the text in the right 4 columnsâŚ
35px
In case of using percentage you get a relative size - relative to the initial one which is different for all entities.
As I understood HA cannot define which icon to use since levels depend on type of connectivity.
px size is different on different screen sizes so I want it to be a percentage of the card width.
Iâd like the say Coffee to be 25% of card width and the 4 columns to east be 25% of the rest of the width and entered in each column.
Can you show me how to do that?
I will try to simulate your case and post here my results.
Just FWIW, on my iPad with no styling at all it looks like this:
No, there are slight differences⌠I am trying to simulate, wait a little.
Yeah youâre right⌠slight shiftâŚ
Here 2 templates:
"secondary_info"
.decluttering_templates:
decl_test_david:
card:
type: 'custom:config-template-card'
variables:
varDEVICE: 'parseFloat(states[''[[SENSOR_DEVICE]]''].state)'
entities:
- '[[SENSOR_DEVICE]]'
- '[[VALUE_DEVICE_NAME]]'
- '[[SENSOR_DEVICE_STATUS]]'
- '[[SENSOR_DEVICE_WIFI_CONNECT_COUNT]]'
- '[[SENSOR_DEVICE_SIGNAL]]'
- '[[SENSOR_DEVICE_RSSI]]'
card:
type: 'custom:mod-card'
style:
multiple-entity-row:
hui-generic-entity-row:
.info.pointer .secondary {
{% if states('[[SENSOR_DEVICE]]')|int >= 100 %}
color: green;
{% elif states('[[SENSOR_DEVICE]]')|int >= 80 %}
color: orange;
{% elif states('[[SENSOR_DEVICE]]')|int >= 60 %}
color: red;
{% else %}
color: magenta;
{% endif %}
card:
entity: '[[SENSOR_DEVICE]]'
show_state: false
icon: >-
${varDEVICE >= 100 ? "mdi:wifi" : (varDEVICE >= 80 ?
"mdi:wifi-strength-3" : (varDEVICE >= 60 ? "mdi:wifi-strength-2" :
"mdi:wifi-strength-1")) }
secondary_info: >-
${ varDEVICE >= 100 ? "Excellent" : (varDEVICE >= 80 ? "Good" :
(varDEVICE >= 60 ? "Fair" : "Weak"))}
entities:
- entity: '[[SENSOR_DEVICE_STATUS]]'
styles:
width: 23px
- entity: '[[SENSOR_DEVICE_WIFI_CONNECT_COUNT]]'
styles:
width: 23px
- entity: '[[SENSOR_DEVICE_SIGNAL]]'
styles:
width: 48px
- entity: '[[SENSOR_DEVICE_RSSI]]'
styles:
width: 38px
decl_test_david_2:
card:
variables:
entities:
card:
style:
hui-generic-entity-row: |
.entities-row div.entity:nth-child(1) div::before {
color: green;
content: "Excellent\A";
color: orange;
content: "Good\A";
color: red;
content: "Fair\A";
{% else %}
color: magenta;
content: "Weak\A";
{% endif %}
line-height: var(--mdc-typography-body1-line-height, 1.5rem);
text-align: center;
white-space: pre;
.entities-row div.entity:nth-child(1) div {
color: transparent;
line-height: 0px;
card:
show_state: false
icon: >-
secondary_info: last-changed
entities:
- entity: '[[SENSOR_DEVICE]]'
styles:
width: 55px
styles:
width: 23px
styles:
width: 23px
styles:
width: 48px
styles:
width: 38px
Both templates use the "config-template-card"
"secondary-info"
section (the 1st template).Alternatively you may change the icon in the Config in an "icon_template"
section (if possible).
How to use the templates:
type: entities
entities:
- type: 'custom:decluttering-card'
template: decl_test_david
variables:
- SENSOR_DEVICE: sensor.test_david_1_device
- VALUE_DEVICE_NAME: Coffee
- SENSOR_DEVICE_STATUS: sensor.test_david_1_device_status
- SENSOR_DEVICE_WIFI_CONNECT_COUNT: sensor.test_david_1_wifi_connect_count
- SENSOR_DEVICE_SIGNAL: sensor.test_david_1_signal
- SENSOR_DEVICE_RSSI: sensor.test_david_1_rssi
How it looks like on desktop (Chrome) for both templates:
How it looks like in iPhone 5s (Safari):
Since the 2nd option is a kind of trick, I would recommend you to use the 1st option - it is more reliable.
Of course, those "::before"
& "content"
CSS things are supported with many browsers, but you decide yourself which option to choose.
P.S. I really like the "multiple-entity-row"
- but it does not show "last-changed"
for every item, this is rather important for me.
Omg!!!
I will give it a whirl. I do like the look of the second one and I donât need secondary_info but can just leave that off⌠I will report back
THANK YOU
David, welcome!
If you decide to proceed with the 2nd option - consider changing the icon in the sensor itself (Config â icon_template) and then do not use the "config-template-card"
You may even decide to create a new template sensor with values âExcellentâ etc instead of using those "::before"
& "content"
CSS things. Then the "card-mod"
will be used only for colourizing the âExcellentâ etc column.
The simpler - the better, I thinkâŚ
Ummm⌠why? I donât see an option to do that. The sensor is created by the Tasmota integration.
Hmm yes but why?
Tried this:
dec_sonoff:
card:
variables:
varDEVICE: 'parseFloat(states[''[[SENSOR_DEVICE_RSSI]]''].state)'
entities:
card:
style:
{% if states('[[SENSOR_DEVICE_RSSI]]')|int >= 100 %}
color: green;
{% elif states('[[SENSOR_DEVICE_RSSI]]')|int >= 80 %}
color: orange;
content: "Good\A";
{% elif states('[[SENSOR_DEVICE_RSSI]]')|int >= 60 %}
color: red;
content: "Fair\A";
{% else %}
color: magenta;
content: "Weak\A";
{% endif %}
text-align: center;
white-space: pre;
color: transparent;
line-height: 0px;
card:
show_state: false
icon: >-
entities:
styles:
width: 55px
styles:
width: 23px
styles:
width: 23px
styles:
width: 48px
styles:
width: 38px
type: entities
entities:
template: dec_sonoff
variables:
- SENSOR_DEVICE: sensor.coffee_maker_firmware
- SENSOR_DEVICE_STATUS: sensor.coffee_maker_status
- SENSOR_DEVICE_WIFI_CONNECT_COUNT: sensor.sonoff1_2914_wifi_connect_count
- SENSOR_DEVICE_SIGNAL: sensor.sonoff1_2914_signal
- SENSOR_DEVICE_RSSI: sensor.sonoff1_2914_rssi
And get this:
I cut and pasted all those entities into dev-tools states and they are all there
I see⌠Of course, you may create a template sensor which repeats the original one. But may be using the "config-template-card"
is better - you decide!
I heard that using custom cards with templating based on JS, Ninjia2 needs more CPU usage, and this may be crucial on slow systems.
This is just an option.
Iâm afraid that using "card-mod"
for some particular card one day may stop working - just because an internal structure of the card is changed. So I prefer to choose a âusualâ way of doing something rather than those CSS tricks with "::after"
, "::before"
& "content"
Regarding âCannot read propertyâ.
Do you have the "decluttering-card"
& "card-mod"
installed?
Also, I see that the template & the card are in one âcode pageâ - are they in one file?
In GUI mode (which is not yaml mode) the template must be before the âdashboardâ section, and the code for a card must be inside some âviewâ section.
Ah that will explain it. I have them exactly as shown and both are installed. So I need to move the template to the top?
I use GUI mode but store and edit the raw file.
So I need to move the template above view:
title: Home
swipe_nav:
wrap: true
animate: swipe # could also use fade or flip
swipe_amount: 15
Here?
