Saw the TestFlight build, but my valiant attempts to get this working have failed miserably. Attempting to hit “continue” to open the browser to authenticate does absolutely nothing.
Same here tried a few times
Thanks for the update, but sadly same here, doesn’t work
- updating in place - still crashed
- deleted the beta app and re-installed - wont open a browser to auth
It seems fine here. Pull down to refresh.
Apparently were expecting build 67. Waiting on Apple
67 just dropped now
Just upgraded to 67, still seems to have problems with the auth process
seems ok for me. Is this first time upgrade to 2.0 beta?
It’s a fresh reinstall of the app
Used it before 0.100
Same issue
also @N-l1
Do you guys use cloud?
Have you tried auth with internal as well as external access? Seem to remember some issue with that… (ie WLAN access and/or external via duckdns or cloud))
Same here.
Yes, I’ve tried both. I do not use cloud.
Thank for your help!
I‘m using duckdns
It worked till now
Same for me, stuck on authentication. Clicking the “connect” button, does not redirect to the browser.
Latest companion beta, hassio 100.2, iOS 13.2 public beta 3.
I see this on discord:
@olbjan there is an issue around onboarding locally where it will give an issue when only internal url is entered and an external with https:// is added. Https seems fine though. That was on b63
I think he means http is fine though so maybe try getting off WLAN and changing the internal URL to your external one…
Thanks for your reply David,
Actually i am using my external URL (https) and i am not using WLAN.
Robbie says it’s iOS13 specific and he hopes to have it fixed tomorrow. Weird because I’m on iOS13 Beta
