I‘m using duckdns
It worked till now
Same for me, stuck on authentication. Clicking the “connect” button, does not redirect to the browser.
Latest companion beta, hassio 100.2, iOS 13.2 public beta 3.
I see this on discord:
@olbjan there is an issue around onboarding locally where it will give an issue when only internal url is entered and an external with https:// is added. Https seems fine though. That was on b63
I think he means http is fine though so maybe try getting off WLAN and changing the internal URL to your external one…
Thanks for your reply David,
Actually i am using my external URL (https) and i am not using WLAN.
Robbie says it’s iOS13 specific and he hopes to have it fixed tomorrow. Weird because I’m on iOS13 Beta
Allright, thanks for the info, using the 1.5 app for now till the next beta arrives.
Same here on IOS iPhone and iPad running IO13. last Beta version from yesterday App is stuck on authorization.
I am using HA version 0.100.1 on Hassbian.
Gr. Remco
there certainly are important differences between iOS beta and release: I was on beta, and all my notifications were blocked because ‘Endpoint’ issues, and errors about that in the log. Also, my Life360 notifications stopped working (I think it was after beta 13.1, not sure though).
After having ditched the beta, and the release 13.1.2 arrived, all was solved.
so, maybe that could frustrate the ongoings here also?
Must add this was with the release App 1.5.1.
Havent update my operational Hassio system to 0.100 because all what has been shared here. My 2 other system are on 0.100 and the release app shows these just fine.
New update is there
It’s working now
Having API manager problems as well. It just won’t connect. Reverted to 63 again which works fine. Will try again later if I have more time.
Also only using external url with https (no nginx and no cloud)
build 68 fixed it for me
b68 works, thank you for a fast fix!
Is this beta working with 0.100 without the workaround?
Edit:
I should read the release notes more carful
anyone experiencing below issues during onboarding using b68?
the URL field displayed for 1 sec then disappeared, leaving keyboard on and unable to dismiss the keyboard
Since latest béta everything is 100% fine!
I’m seeing the same thing
Working for me on my phone and ipad. Had to reset the app (bottom of app settings - top red “Reset” ) on both devices after the update then set up the URL and login details before it would work correctly.
I removed the mobile app integration from HA, restarted, deleted the app, reinstalled again, went through the onboarding process and everything works, great app! awesome work! many thanks to the programer!
Running iOS 13.1.2 and I am seeing a previous issue with input Boolean selecting. Tap sometimes latches correctly or it can toggle on then straight back off. Was seeing this when I tried the beta of ios13 but running vanilla iOS 13 and b63 was fine.
Same issue on beta 68. Keyboard stays open and can’t reset app or login. Full delete of the app too and no change.
