2.0 Release Update
Ok so after removing the integration and starting the onboarding again everything seems to be working again👍.
I actually don’t know where to ask for feature requests for this app. But @robbiet480 would it be possible to add a layer of security, for example passcode and touch/faceid? That would be awesome!
Don’t you have that on your phone Jim?
Best place is probably the discord ios channel.
Don’t know if it’s the right place to ask, but after all the trouble with the app crashing I have multiple devices trackers for my phone, is there any way to clean this up?
You have to go to settings -> integrations and delete all the mobile app integrations you see there. After that restart HA and go trough onboarding again and baam u only get one mobile app integration which probably would be without _ :slight_smile: good luck to you
Hello to everyone!! :slight_smile:
Thanks a lot for the beautiful app!! :slight_smile:
I have one problem, I have deleted the integration and restarted the server and when I have configured the app again all sensor was created successfully but not the Notification service (i can’t send notification on mobile app) … :frowning:
Do you have some workaround?
Regards
Restart HA once again?
No… sorry for the stupid question!! :sob::sob:
Can’t find the latest Test Flight link. The one one official post seems to be expired or not accepting testers. Thanks.
For anyone having the issue with the initial popup disappearing as soon as you start up the app, hold one finger on the popup as soon as it appears and keep your finger pressed down on it. At the same time enter the URL and click ok with your other finger. The app will crash and when you open it back up, you’ll be able to set up without issue.
What do you mean have it on my phone? You mean on the phone itself? Ofc, but an extra layer of security on app level would be awesome (like most banking apps and some mail apps can do).
Anyways thanks again for the temporary fix you gave us last week.
Thank you so much @IK0ADR.
Everyone - now that we have an update I think it is time we all go into the app and donate. We are all very quick to complain and moan when things break but nobody is quick to say “Thanks” and donate a little.
If everyone donates a couple bucks it goes a long ways - so please donate whatever you feel is reasonable!
Remember it was the end of the world when the app stopped working, so it’s only logical it’s worth paying for :crazy_face:
Your right, just donated, this app is all worth it :+1::smile:
I am having the same problem, keyboard stays open and you can’t proceed with onboarding.
Work around for this problem if you have a bluetooth keyboard, is to connect an external bluetooth keyboard. Do the onbaording and then disconnect the bluetooth keyboard.
I’m having issues with the latest version of the app - can’t get notifications to work. Weird thing is that the app is not listed in the notifications settings at all. Works on 2 other iphones, but not on mine. Tried deleting, reseting both phone and HA…no change. Any help appreciated! thanks
@slovenc, I had that same problem (the app not even showing up in the notifications screen of Settings) with an earlier build - maybe it was 62. Have you tried the cleaning between builds scorched-earth instructions? If not, try those.
I eventually got mine working after using those instructions and re-installing from Test Flight at least twice. I’m not sure what ultimately did the trick.
thanks, yeah I tried all that, not sure when it stopped working though, because until recently I had no issues with it.
edit:
just tested another iphone and also no notification entry. Look like an issue with the latest version then?
To get the notification service endpoint you need to restart HA after onboarding, then force close the app and reopen. It will then register the service.
