hi,
my tahoma integration gives the following error after the update : -Failed to set up: Import error-, is this related to the problem Tetienne mentioned?
Did you filter the entities in recorder somewhat? Logbook here loads in under 5 seconds, Rpi4, 260+ entities recorded( out of over 3000)
Iām not sure any consumer thermostat reports in decimals for degrees Fahrenheit. Thus, the default behavior for homekit climate devices should be to show whole numbers. Do I have to make a separate manual climate entity or is there a way to change how this is displayed?
No. I tried 1.1.2 and it breaks the layout of all entity cards
They start wrapping down on next line and the whole thing becomes a mess. I can repeatedly trigger the bug by adding and removing the component
Looks like this update has completely nuked the Ecovacs integration. It doesnāt even come up in the āAdd Integrationsā search anymore.
I have no idea if it was related but right after I updated I attempted to set up a Tradfri shortcut button using a blueprint and shortly after all of my automations were gone as well as the option to select automations in the configuration tab. Restored to 2021.5.5 and all is wellā¦ I may re-try after a day or two to see if anyone else has similar issues.
Oh yes. I have heavy filtering to keep database small. It is currently 187 MB.
That is correct (in most cases). If the coordinator triggers an update, all entities related/listening/derived from the same data will update their state as well.
I agreeā¦ Iām using an old Deebot integration and it canāt find it anymore.
I think your memory is off, itās never been in the integration list. Only configurable through configuration.yaml.
Did the update kill old browser support?
Like safari from ios 9.3.6?
Slow, but It was working before this update, and I was using for simple switching my devices.
Specifically, the login screen doesnāt appear.
Precisely, it goes to the login screen, gives a short āinitializingā message, then that disappears,
and no field for username, password shows up. The page just stays blank.
Looked at timestamps from Philips Hue Motion sensor versus the same sensor by MQTT. Philips Hue integration is now reporting a bit faster than MQTT. Thank you for all the hard work, I really appreciate it.
Indeed Var and Variable custom components stopped working and I use the Variable component a lot, I ended up restoring back the old version and will not upgrade until a solution is found. Too sad
Cheers
No issues to report on 3 systems
Seems like the IotaWatt integration is broken now
Cool!
But with the feature āCollapsed attributesā, I donāt think itās a good choice for those entities with only 1 or 2 attributes.
Mine is working. Do you have the latest version 3.10.5? Mine is installed through HACS if that helps.
Unless the Dev of those integrations doesnāt add the required version and update the integration, have a look at this post about modifying it yourself to get it working.
Thanks mate, I will give a try and let you know. Cheers
This broke on my machine (Windows, Python)ā¦ Got a ValueError for time_zoneā¦ Even though the time_zone is rightā¦ I suspect it has something to do with them changing to a UNIX only package for timezone? Reverting back to 2021.5.5 boots just fineā¦
2021-06-02 19:27:43 ERROR (MainThread) [root] Uncaught exception
File "c:\programdata\miniconda3\envs\homeassistant\lib\runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "c:\programdata\miniconda3\envs\homeassistant\lib\runpy.py", line 87, in _run_code
exec(code, run_globals)
File "C:\ProgramData\Miniconda3\envs\homeassistant\Scripts\hass.exe\__main__.py", line 7, in <module>
sys.exit(main())
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\__main__.py", line 314, in main
exit_code = runner.run(runtime_conf)
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\runner.py", line 118, in run
return asyncio.run(setup_and_run_hass(runtime_config))
File "c:\programdata\miniconda3\envs\homeassistant\lib\asyncio\runners.py", line 44, in run
return loop.run_until_complete(main)
File "c:\programdata\miniconda3\envs\homeassistant\lib\asyncio\base_events.py", line 616, in run_until_complete
return future.result()
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\runner.py", line 104, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\bootstrap.py", line 165, in async_setup_hass
await async_from_config_dict(
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\bootstrap.py", line 228, in async_from_config_dict
await conf_util.async_process_ha_core_config(hass, core_config)
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\config.py", line 508, in async_process_ha_core_config
await hass.config.async_load()
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\core.py", line 1716, in async_load
self._update(
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\core.py", line 1696, in _update
self.set_time_zone(time_zone)
File "c:\programdata\miniconda3\envs\homeassistant\lib\site-packages\homeassistant\core.py", line 1663, in set_time_zone
raise ValueError(f"Received invalid time zone {time_zone_str}")
ValueError: Received invalid time zone America/Vancouver
An effort should be made to avoid UNIX/LINUX only modules in python. HASS is almost completely cross-platform, except for a couple of packagesā¦ for example, the UNIX only module: āimport cryptā is used in the HOMEKIT integration, but all they do with it is generate saltsā¦ There are tons of cross-platform modules which can be used instead and would make it work on Windows and Linux. I just change it to āimport pcryptā (which is a python only version or crypt, just slower), and it works fine on windows.
Havenāt dug into why timezone suddenly stopped working on Windows, Iāll give it a few versions to see if they fix it themselves before I dig into it more.
