Custom-Cards stopped working, rolled back and still not working. Re-installed Custom cards and fixed the issue. Logged a bug and the developer contacted me for me info. Re-applied the update and this time a message flashed up quickly about a new front-end or some thing similar (reloaded the page and went away too fast for me to grab it) and now it is all working again.
Thanks everybody for all the effort they have put into this update.
But that does not set this the theme to dark for all users upon login.
Also selecting default, none, Backend-selected doe not give me the dark by default for all users.
is it to be expected that upon disabling the polling, all entities become unavailable? I would think that to be an issue… they should stay in their last state, and await the next manual poll? Just tested this with Buienradar, and all turned Unknown
Collapsed attributes: Previously, all themes automatically used our light theme as the base to build on. As of today, themes can be based on our default dark theme as well!
But there is still no selectable default theme, isn’t it? Why?
E.g. to assign this theme to a special view, if main theme is another one. In cards, I can set each theme, but not the buoild in HA ones.
To unclutter the more information entity dialog from these attributes a bit, the attributes will now show up collapsed into a bar and can be revealed with a click.
Can I switch off this behavior? I don’t want to click on “more” every time and to see everything on one view directly as before.
Disable polling updates on any integration
Is there a service for this as well, to switch off and on for a given integration?
Since the Update my history graphs no longer work. I just get the loading animation on my sensor cards. There seem to be no entries in the log regarding recorder errors. Did I miss a change to the recorder or the db? I’m using the Maria db add-on.
Hi all, does anybody know what i need to change for my KNX sensors to get them work again? Invalid config for [knx]: [create_sensors] is an invalid option for [knx]. Check: knx->knx->weather->0->create_sensors. (See ?, line ?). Please check the docs at https://www.home-assistant.io/integrations/knx
I could not find the solution in the docs so far just that it has to do with “create sensors”…
By “starting home page”, are you referring to your first Lovelace page?
If so, I’ve got the same issue.
First page loads blank but all the rest load no problem.
