It’s been already discussed, but InfluxDB integration still not working in 2021.7.3.
Here is more detailed log:
2021-07-16 14:41:09 ERROR (MainThread) [homeassistant.setup] Setup failed for influxdb: unknown error
File "/usr/src/homeassistant/homeassistant/setup.py", line 201, in _async_setup_component
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 490, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 855, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 13, in <module>
from influxdb import InfluxDBClient, exceptions
File "/usr/local/lib/python3.9/site-packages/influxdb/__init__.py", line 10, in <module>
from .dataframe_client import DataFrameClient
File "/usr/local/lib/python3.9/site-packages/influxdb/dataframe_client.py", line 12, in <module>
import pandas
File "/usr/local/lib/python3.9/site-packages/pandas/__init__.py", line 22, in <module>
from pandas.compat import (
File "/usr/local/lib/python3.9/site-packages/pandas/compat/__init__.py", line 15, in <module>
from pandas.compat.numpy import (
File "/usr/local/lib/python3.9/site-packages/pandas/compat/numpy/__init__.py", line 7, in <module>
from pandas.util.version import Version
File "/usr/local/lib/python3.9/site-packages/pandas/util/__init__.py", line 1, in <module>
from pandas.util._decorators import ( # noqa
File "/usr/local/lib/python3.9/site-packages/pandas/util/_decorators.py", line 14, in <module>
from pandas._libs.properties import cache_readonly # noqa
File "/usr/local/lib/python3.9/site-packages/pandas/_libs/__init__.py", line 13, in <module>
from pandas._libs.interval import Interval
File "pandas/_libs/interval.pyx", line 1, in init pandas._libs.interval
ValueError: numpy.ndarray size changed, may indicate binary incompatibility. Expected 88 from C header, got 80 from PyObject
It seem’s to be this problem, or at leas somehow related: https://docs.oracle.com/javase/tutorial/java/package/namingpkgs.htmlhttps://stackoverflow.com/questions/66060487/valueerror-numpy-ndarray-size-changed-may-indicate-binary-incompatibility-exp
Also note that “Check configuration” button is not working (spinning for indefinity), but command ha core check
is working just fine.
