After a lot of struggling, trying so many things, I could remove the errors below:
2021-09-03 10:56:11 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_basic] The 'value_template' option is deprecated, please replace it with 'state_value_template'
I updated some tasmotas from 9.1.0 to 9.5.0 and the error were gone.
But if you remember, all came from trying to update from 2021.8.8 to 2021.9.2 (or 2021.9.1). This error was not present in 2021.8.8, I could remove those errors, I am still in 2021.8.8, since the update was not completed, and supervisor still doesn’t start:
There is an unkown error…
Configuration is validated with no errors.
2021-09-04 16:53:49 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration openmediavault which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-04 16:53:49 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration saver which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-04 16:53:49 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-04 16:53:49 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Above are the only errors present related to custom integrations, which have been always there not causing any problem at all. So I got lost why the supervisor is not starting.
Do you see anything that I can see or do?
