Just a warning my DB is dead this morning, not 100% sure it was this that did it because it was fine until 4:12am this morning then died.
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM events WHERE events.event_id IN
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM events WHERE events.event_id IN
The system will rename the corrupt database file //config/home-assistant_v2.db to //config/home-assistant_v2.db.corrupt.2021-09-06T03:12:48.885687+00:00 in order to allow startup to proceed
Ah makes sense, I copied the corrupt DB to my windows machine and ran an integrity check on my original DB I backed up before making the change and no errors.
On the corrupt one;
*** in database main ***
On tree page 35983 cell 15: 2nd reference to page 118249
On tree page 35983 cell 14: 2nd reference to page 86028
On tree page 35983 cell 13: 2nd reference to page 86110
On tree page 35983 cell 12: 2nd reference to page 86177
On tree page 35983 cell 11: 2nd reference to page 86379
On tree page 35983 cell 10: 2nd reference to page 86531
On tree page 35983 cell 9: 2nd reference to page 86539
On tree page 35983 cell 8: 2nd reference to page 86547
On tree page 35983 cell 7: 2nd reference to page 86557
On tree page 35983 cell 6: 2nd reference to page 86566
On tree page 35983 cell 5: 2nd reference to page 87831
On tree page 35983 cell 4: 2nd reference to page 118137
On tree page 35983 cell 3: 2nd reference to page 118236
On tree page 35983 cell 2: 2nd reference to page 118245
and
wrong # of entries in index ix_states_old_state_id
So it was not happy
EDIT - Just checked my new DB from the dump and no errors so hopefully all good now
Hi, did you solve this ? Since the 2021.9 update, all my picture elements show a loading indicator (blue spinning circle). Sometimes its pretty instant but other times it takes 1-5 seconds.
I use some 100x100 PNG files for icons (all in the www folder)
Maybe yes, but I think the whole point of the Energy dashboard is expenses (costs) management.
We have support for electrical energy and gas.
Gas can be used to produce energy, so does pellet, coal, wood, and other sources, but we don’t have support for all of them.
I think that support for water usage would be a nice addition. I’ll create a feature request and we can discuss that in the proper place.
No, apparently as it is a custom integration, it will not be supported or fixed. So the issue has raised with the owner of the custom card (custom:config-template-card).
Yes, it worked for my case. After manual update currency of broken energy cost sum entity(in my case - sensor.energy_meter_d_main_cost) from EUR to my configured currency RUB - calculation of energy cost is working again!
As of 2021.9.3 the energy meter tab stopped showing values (the previous history exists).
The only hint in the log is the following:
Entity sensor.daily_energy_offpeak from integration utility_meter has state class total_increasing, but its state is not strictly increasing.
Using shelly EM and energy meter with peak/offpeak configuration and those exact entities for the energy tab (daily_energy peak and daily_energy offpeak).
It seems that those properties don’t populate until the next update comes in from the end device. I switched the socket off and then back on again and the units populated and the entity started counting up. Many thanks for your help
I don’t think anything is 100% sure unless you try. I updated to 2021.9.2 with a Rpi3b+ with no issues. The memory usage reported is running high-ish (above 80%), I don’t recall it being that high in the past.
Between increasing CPU and memory (and increasing complexity of, and reliance on, my setup) as time goes on it may be time to start planning my move on from the RPi3.
After last update I cannot access anymore to XIAOMI Gateway and all related devices.
`2021-09-06 15:46:35 ERROR (SyncWorker_6) [xiaomi_gateway] Cannot connect to Gateway
2021-09-06 15:34:11 ERROR (MainThread) [homeassistant.components.xiaomi_miio.device] DeviceException during setup of xiaomi device with host : Unable to discover the device
Also if says check credentials : the credentil are ok !
Is there any straightforward way to track the energy consumption for constant energy consumers like my pond pump controlled by a switch device?
Like setting a power attribute for that switch or something?
The same would be neat for device_trackers, if the device is online → count/integrate its constant energy consumption.
I have a Zigbee stick plugged in the USB port of my Syno 918+. Since upgrading to 2021.8 the USB stick has been useless due to “Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)” error. Upon upgrading to 2021.9.3, it is recognized as Z-wave stick.
Z-Wave JS
Do you want to setup CP2102 USB to UART Bridge - /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0, s/n: 0001 - Silicon Labs - 10C4:EA60 with the Z-Wave JS add-on?
