Great release and iteration on the Energy dashboard. Love the history capability…at this point HA means I don’t need Influx/Grafana (or my solar inverters web based reporting for that matter).
Wishlist: Allow us to recreate the energy distribution card but with power entities. Seeing at a glance what is happening in real time helps us run our house more efficiently
I just updated from 2021.8.8 to 2021.9.0 and got a heap of zwaveJS node errors on startup.
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='9-50-0-value-513') on device 'Alfresco Sony Plug' (Node(node_id=9)) will be skipped: Value Value(value_id='9-50-0-value-513') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=9) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='13-50-0-value-328193') on device 'Onkyo Amp Plug' (Node(node_id=13)) will be skipped: Value Value(value_id='13-50-0-value-328193') has unknown data in the following location: metadata.cc_specific.scale. A reinterview of node Node(node_id=13) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='13-50-0-value-513') on device 'Onkyo Amp Plug' (Node(node_id=13)) will be skipped: Value Value(value_id='13-50-0-value-513') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=13) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='13-50-0-value-1114625') on device 'Onkyo Amp Plug' (Node(node_id=13)) will be skipped: Value Value(value_id='13-50-0-value-1114625') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=13) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='13-50-0-value-590337') on device 'Onkyo Amp Plug' (Node(node_id=13)) will be skipped: Value Value(value_id='13-50-0-value-590337') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=13) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='29-50-0-value-513') on device 'Front House Light Switch' (Node(node_id=29)) will be skipped: Value Value(value_id='29-50-0-value-513') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=29) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='11-49-0-UNKNOWN (0x81)') on device 'Lounge Multisensor' (Node(node_id=11)) will be skipped: Value Value(value_id='11-49-0-UNKNOWN (0x81)') has unknown data in the following location: metadata.cc_specific.sensorType. A reinterview of node Node(node_id=11) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:53 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='11-49-0-UNKNOWN (0x00)') on device 'Lounge Multisensor' (Node(node_id=11)) will be skipped: Value Value(value_id='11-49-0-UNKNOWN (0x00)') has unknown data in the following location: metadata.cc_specific.sensorType. A reinterview of node Node(node_id=11) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:54 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='8-49-0-UNKNOWN (0x85)') on device 'Ensuite Multisensor 1' (Node(node_id=8)) will be skipped: Value Value(value_id='8-49-0-UNKNOWN (0x85)') has unknown data in the following location: metadata.cc_specific.sensorType. A reinterview of node Node(node_id=8) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:54 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='8-49-0-UNKNOWN (0x00)') on device 'Ensuite Multisensor 1' (Node(node_id=8)) will be skipped: Value Value(value_id='8-49-0-UNKNOWN (0x00)') has unknown data in the following location: metadata.cc_specific.sensorType. A reinterview of node Node(node_id=8) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-09-02 07:43:54 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='28-49-0-UNKNOWN (0x00)') on device 'Passage MS6' (Node(node_id=28)) will be skipped: Value Value(value_id='28-49-0-UNKNOWN (0x00)') has unknown data in the following location: metadata.cc_specific.sensorType. A reinterview of node Node(node_id=28) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
ERROR:homeassistant.config:Invalid config for [automation]: Integration 'zha' not found (See /tmp/config/configuration.yaml, line 16).
File "/usr/local/lib/python3.9/site-packages/homeassistant/components/device_automation/__init__.py", line 97, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/local/lib/python3.9/site-packages/homeassistant/requirements.py", line 76, in async_get_integration_with_requirements
raise IntegrationNotFound(domain)
grep: write error: Broken pipe
homeassistant.loader.IntegrationNotFound: Integration 'zha' not found.
I do have a bunch of automations with domain: zha in the triggers. Is that the issue?
Come on guys, if you do an update, you always have to make a backup first (or willingly disable it before updating HA). That is a legitimate way to handle updates. You can’t fool proof everything and test every device combination that is out there.
Relying on a software is nothing to be handled lightly. If you do rely on something, you take precautions for idealy anthing that could go wrong.
There is no need, to work on beta testing or finding other ways around. If you setup your installation and know you need it, backup & restore is one of your foremost things to do.
Regardless of that, you should at least wait, why this is happening for some people. There could simply be something wrong with the upload, with Github with… Discussing changes to HA and it’s update policies is way to early and, as said above, not necessary. It’s a one time thing that can always happen, if you work with software.
Btw. great release, looks promising! I’m especially curios about the new tractive integration.
fairly certain they did a rollback. I upgraded earlier, then my binary_sensor for monitoring updates sent me a notification - but it was back to 2021.8.8 version. oops. glad I was able to restore my backup.
Certainly looks that way - I had the notification to update, I clicked the button, it made a backup and started doing its thing - then I spent a good chunk of time trying to figure out why my Tesla Powerwall integration hadn’t updated with the new sensors, only to then establish that it didn’t in fact update to 2021.9, and now the update option is gone.
After some playing around with a pi3b+ here, one thing you can do to stop HA restarting is to rename automations.yaml. When it next restarts it will be in safe mode and the looping will end.
From there you can downgrade to the previous version using ha core update --version=2021.8.x in the ssh add-on terminal
Then you can rename automations.yaml back to normal and wait for the next release without having to be in safe mode.
There isn’t enough people beta testing each month. more are needed otherwise issue like this never get seen until released.
So saying no need for beta testing just means your reliant on someone else to have tested and may not use the same hardware etc
