2022.11: A heck of a release!
I seem to have lost access to HA from both phone and computer. My installation is on a RPi4 and have both the internal and external links set via duckdns.org. When I try the usual link in my browser I get “Unable to connect to Home Assistant.” and if I click rety I get “403: Forbidden”.
I am able to ssh into HA and have tried restarting HA core and host, unfortunately without effect. I’m tempted to try and revert to 2022.10 but will see if anyone has any ideas I can test. Thanks!
edit: I fixed it by removing ip_bans.yaml. Somehow some IP’s got added during the update?
Core 2022.11.1 broke my people locations. My person.xxx entities were not updating, and were not shown anywhere on the map. Rolling back to yesterday’s backup fixed the issue.
hm… what tracker are you using?
I have three location tracking entities - two times mobile and one other gps tracker - all three are working as expected with this version.
So I don’t expect this to be a general issue
Two mobiles, two individuals. Neither reported location after several moves. Sorry, but also not sorry, to hear it’s just me.
fixed this: we have to re-configure the integration, and can only do that by re-installing, or by manually editing the config_entry. I did the latter and it is fixed. No release issue.
I updated from 2022.11 to 2022.11.1 and my system never came back up afterward. The web UI won’t load. Anyone have tips to troubleshoot? I’m running a NUC with Home Assistant OS.
➜  ~ ha core restart
Processing... Done.
Post "http://supervisor/core/restart": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
➜  ~ ha core stop
Processing... Done.
Error: Unknown error, see supervisor
➜  ~ ha core start
Processing... Done.
➜  ~ ha supervisor logs
22-11-04 07:47:14 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-11-04 07:47:44 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-11-04 07:47:48 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-11-04 07:47:50 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
22-11-04 07:49:32 ERROR (MainThread) [supervisor.auth] None as password is not supported!
22-11-04 07:49:33 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.10/site-packages/sentry_sdk/integrations/aiohttp.py", line 126, in sentry_app_handle
    reraise(*_capture_exception(hub))
  File "/usr/local/lib/python3.10/site-packages/sentry_sdk/_compat.py", line 56, in reraise
    raise value
  File "/usr/local/lib/python3.10/site-packages/sentry_sdk/integrations/aiohttp.py", line 116, in sentry_app_handle
    response = await old_handle(self, request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 138, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 204, in token_validation
  File "/usr/src/supervisor/supervisor/api/utils.py", line 60, in wrap_api
    answer = await method(api, *args, **kwargs)
  File "/usr/src/supervisor/supervisor/api/auth.py", line 64, in auth
    if not await self._process_basic(request, addon):
  File "/usr/src/supervisor/supervisor/api/auth.py", line 39, in _process_basic
    auth = BasicAuth.decode(request.headers[AUTHORIZATION])
  File "/usr/local/lib/python3.10/site-packages/aiohttp/helpers.py", line 154, in decode
    raise ValueError("Unknown authorization method %s" % auth_type)
ValueError: Unknown authorization method NTLM
on the new Oral B integration… I am an old-fashioned manual brusher, but it apparently spotted a drivers-by, or a neighbor:
Scherm­afbeelding 2022-11-04 om 16.28.53
my neighbors are at least 40 meters aways on 1 side of the BT extender, and more than triple that on all other sides…
thats probably why it frequently shows:
wondering if that isnt very costly on the system. can we somehow measure that? If its constantly polling, that would hurt wouldn’t it?
Yes I had the same issue and error with iAqualink. I downgraded back to 10.5 and it worked again.
I can’t find if 11.1 fixes this or what I need to watch. I won’t upgrade until this part is fixed…
Bluetooth LE doesn’t poll, it’s push… sort of. The system is basically just listens to broadcasts, and the devices broadcast regardless of someone listening.
understood. sort of… so, when the entities are unavailable, the HA system does actually do nothing, until some sort of push signals it to change to something else?
Ive now disabled the Oral B integration to prevent anything from happening.
Seems a terrible and undesirable privacy breach though… wonder what others ‘see’ of our own instances/devices…
It’s just listening to all Bluetooth messages, regardless if oral b is integrated or not.
That’s Bluetooth LE… that’s what you sign up for when you buy the devices.
yay :slight_smile:
Getting information when and how often your neighours brush their teeth…
That’s the side-effect of “not so smart” smarthome-stuff…
just think, what you could discover in an appartment with ~40 other parties… I am question myself atm, if I SHOULD start with the bloothooth stuff at all…
What I found out …
after clicking the glance card the stream shows in the same size as the glance card. If you hover it you see a small rectangle bottom right. Clicking on this gives fullscreen.
So far so good. Is it possible to start the streaming window fullscreen or with a given size?
chris
Do you have some informations abou Roborock S6 MaxV support?
I noticed a similar authentication error on my system after the update, but I’m not using this integration. My whole system is offline, though.
Are there release notes for 2022.11.1 anywhere? I can’t seem to find them.
Since upgrading to 2022.11 ZHA has failed to start with reloads of HA (including with the update). A full reboot of the host more often works, but not every time.
Here is a sample log entry relating to the issue:
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:172
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 18:17:55 (5 occurrences)
Last logged: 22:42:47
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 1 of 3)
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 2 of 3)
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 3 of 3)
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 664, in _skip_bootloader
    result = await responses.get()
  File "/usr/local/lib/python3.10/asyncio/queues.py", line 159, in get
    await getter
asyncio.exceptions.CancelledError
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
    self.application_controller = await app_controller_cls.new(
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
    await app.startup(auto_form=auto_form)
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 124, in startup
    await self.connect()
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 106, in connect
    await znp.connect()
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 706, in connect
    self.capabilities = (await self._skip_bootloader()).Capabilities
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 663, in _skip_bootloader
    async with async_timeout.timeout(CONNECT_PROBE_TIMEOUT):
  File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 129, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
    raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
I’m running HA OS 2022.11.1 installed on a RPi 4. Issue started with 2022.11.
Yes, i upgraded to 2022.11.1 today, noticed 30 minutes ago that my cards with tap actions on pictures (transparent btw.) does not work anymore.
In my opinion this has to be a bug… did you solve it yet withouth changing/reposition images/click spot?
