@GFactor I updated to 2022.4.1 a couple hours ago and while the devices say they are online, they are not working. I still see a lot of delivery errors where it also state something has a BUSY state.
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [34, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xfffd>, 0, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xbb64>, 0, 0, 0, b'\xe4\xf9i\x07\xff\xff.!\x00\x00\x00', 0, 175, 255, 219, 1, 245, 13, -25]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy.zdo] [0xbb64:zdo] ZDO request ZDOCmd.NWK_addr_req: [00:21:2e:ff:ff:07:69:f9, 0, 0]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 228 under 144 request id, data: b'e400f96907ffff2e210000000000'
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xbb64>, ep: 0, profile: 0x0000, cluster_id: 0x0000, data: b'e4f96907ffff2e21000000'
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 144, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0xBB64 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xe4\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_request' failure: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] retrying 'aps_data_request' in 0.5s
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 132, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=20612 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xe3\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy.device] [0x5084] Delivery error for seq # 0xe3, on endpoint id 0 cluster 0x8000: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_confirm (0,)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 97: e9
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x61 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x5f72 endpoint=0>, status: 0xe9
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 97 req id frame: TXStatus.MAC_NO_ACK
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Trying manual source route: [0]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (32, 97, <DeconzSendDataFlags.RELAYS: 2>, <DeconzAddressEndpoint address_mode=2 address=0x5F72 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x94\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0, [0])
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 97]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [34, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xfffd>, 0, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x6b6a>, 0, 0, 0, b'\x96\xf9i\x07\xff\xff.!\x00\x00\x00', 0, 175, 255, 221, 1, 245, 13, -55]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy.zdo] [0x6b6a:zdo] ZDO request ZDOCmd.NWK_addr_req: [00:21:2e:ff:ff:07:69:f9, 0, 0]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy.util] Duplicate 150 TSN
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x6b6a>, ep: 0, profile: 0x0000, cluster_id: 0x0000, data: b'96f96907ffff2e21000000'
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 95: e9
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x5f 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xbb64 endpoint=0>, status: 0xe9
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 95 req id frame: TXStatus.MAC_NO_ACK
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (32, 95, <DeconzSendDataFlags.RELAYS: 2>, <DeconzAddressEndpoint address_mode=2 address=0xBB64 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xdb\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0, [0])
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 95]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (26, 137, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0xB819 endpoint=1>, 260, 2820, 1, b'\x00\x88\x00\x0b\x05\x0f\x05\x08\x05\x05\x05', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] retrying 'aps_data_request' in 1.5s
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (26, 139, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x3B92 endpoint=1>, 260, 2820, 1, b'\x00\x8a\x00\x0b\x05\x0f\x05\x08\x05\x05\x05', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [34, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xfffd>, 0, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x5f72>, 0, 0, 0, b'\x97\xf9i\x07\xff\xff.!\x00\x00\x00', 0, 175, 255, 214, 1, 245, 13, -69]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy.zdo] [0x5f72:zdo] ZDO request ZDOCmd.NWK_addr_req: [00:21:2e:ff:ff:07:69:f9, 0, 0]
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 151 under 145 request id, data: b'9700f96907ffff2e210000000000'
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x5f72>, ep: 0, profile: 0x0000, cluster_id: 0x0000, data: b'97f96907ffff2e21000000'
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 145, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x5F72 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x97\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (26, 141, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0xAFEC endpoint=1>, 260, 2820, 1, b'\x00\x8c\x00\x0b\x05\x0f\x05\x08\x05\x05\x05', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 142, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x459F endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xd6\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 120: 00
2022-04-08 09:57:09 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x78 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xa244 endpoint=0>, status: 0x00
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 144, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0xBB64 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xe4\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 38>, 144]
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_confirm (0,)
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 131: 00
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x83 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x6b6a endpoint=0>, status: 0x00
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 133, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x0298 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x92\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 133]
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 143: e1
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x8f 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x243f endpoint=0>, status: 0xe1
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 143 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Trying manual source route: [0]
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (32, 143, <DeconzSendDataFlags.RELAYS: 2>, <DeconzAddressEndpoint address_mode=2 address=0x243F endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x9d\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0, [0])
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 143]
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 134, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x243F endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x9c\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_request' failure: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy.device] [0x243f] Delivery error for seq # 0x9c, on endpoint id 0 cluster 0x8000: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 145, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x5F72 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x97\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] retrying 'aps_data_request' in 1.0s
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 135, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x3FB7 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xf8\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:10 DEBUG (MainThread) [zigpy.device] [0x3fb7] Delivery error for seq # 0xf8, on endpoint id 0 cluster 0x8000: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (26, 137, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0xB819 endpoint=1>, 260, 2820, 1, b'\x00\x88\x00\x0b\x05\x0f\x05\x08\x05\x05\x05', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0)
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_request' failure: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy.device] [0xb819] Delivery error for seq # 0x88, on endpoint id 1 cluster 0x0b04: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:11 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xB819:1:0x0b04]: failed to get attributes '['active_power', 'apparent_power', 'rms_current', 'rms_voltage']' on 'electrical_measurement' cluster: [0xb819:1:0x0b04]: Message send failure
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (26, 139, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x3B92 endpoint=1>, 260, 2820, 1, b'\x00\x8a\x00\x0b\x05\x0f\x05\x08\x05\x05\x05', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0)
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy.device] [0x3b92] Delivery error for seq # 0x8a, on endpoint id 1 cluster 0x0b04: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:11 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x3B92:1:0x0b04]: failed to get attributes '['active_power', 'apparent_power', 'rms_current', 'rms_voltage']' on 'electrical_measurement' cluster: [0x3b92:1:0x0b04]: Message send failure
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 145, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x5F72 endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\x97\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] retrying 'aps_data_request' in 1.5s
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (26, 141, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0xAFEC endpoint=1>, 260, 2820, 1, b'\x00\x8c\x00\x0b\x05\x0f\x05\x08\x05\x05\x05', <DeconzTransmitOptions.USE_APS_ACKS|USE_NWK_KEY_SECURITY: 6>, 0)
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy.device] [0xafec] Delivery error for seq # 0x8c, on endpoint id 1 cluster 0x0b04: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
2022-04-08 09:57:11 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xAFEC:1:0x0b04]: failed to get attributes '['active_power', 'apparent_power', 'rms_current', 'rms_voltage']' on 'electrical_measurement' cluster: [0xafec:1:0x0b04]: Message send failure
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (29, 142, <DeconzSendDataFlags.NONE: 0>, <DeconzAddressEndpoint address_mode=2 address=0x459F endpoint=0>, 0, <ZDOCmd.NWK_addr_rsp: 0x8000>, 0, b'\xd6\x00\xf9i\x07\xff\xff.!\x00\x00\x00\x00\x00', <DeconzTransmitOptions.USE_NWK_KEY_SECURITY: 2>, 0)
2022-04-08 09:57:11 DEBUG (MainThread) [zigpy.device] [0x459f] Delivery error for seq # 0xd6, on endpoint id 0 cluster 0x8000: Couldn't enqueue send data request: Command.aps_data_request, status: Status.BUSY
