2022.4: Groups! Groups! Groups!
Please stop posting the same link!
Just updated HA to 2022.4.0. After restart I got this error:
Unable to set up dependencies of telegram. Setup failed for dependencies: telegram_bot
I was so excited with the new features that I took my chance and updatedā€¦andā€¦gree integration stopped working, esphome lost all configured devices source code :scream: and File editor couldnt access any filesā€¦I was lucky to have recent backup.
Iā€™m never updating to anything with a zero in its version number. Never!
Same issue. See above. I donā€™t understand why this has not been identified during release testing. Seems that something is wrong here.
Perhaps you should join beta and be part of that testing.
Oh my.
I originally chose HA because I could configure it all in text and back up man readable files to restore things. Now youā€™re going away from just that.
Much as I hate YAML am I allowed to be sad?
For Switch as X, is there a way to ā€œreverseā€ the options? IE if Switch is on then lock is locked, if switch is off then lock is unlocked?
As an example I have a shelly 1 that Iā€™m using with a drop bolt lock. For safety reasons, the lock must be on if there is power, if there is no power then the lock will automatically unlock.
Come on people. Iā€™m so over people complaining about x.0 releases. Each month there are often 5-8 updates after a .0. While I usually update to .0, because Iā€™m impatient, I always understand that there are possibilities of issues. The more common an integration is, the less likely an issue, but thatā€™s no guarantee. If you canā€™t handle the possibility of an outage or issue, just wait a few weeks. Maybe make a personal policy of only updating to X.3 releases, etc.
Thanks everyone who continue to put out great stuff each month.
same here on supervised installation
Looks like Sun integration doesnā€™t work after the update. Integration shows up in the list but it doesnā€™t have any entities - i.e., sun.sun doesnā€™t exist any more.
Edit: it came back after restart.
it does work and exist on my install
I have upgraded to 2022.4 . Statistics and history are not yet available 2:20h after upgrade.
How long does the database upgrade take (size mariadb is +/- 2GB :: events 725 Mb, states 1 GB, statistics 103 Mb)? Is there any message displayed when upgrade database is finished?
UPDATE: I just got the following errors :
Canā€™t read Supervisor data:
22:02:27 ā€“ (WARNING) Home Assistant Supervisor
/store return code 500
22:02:27 ā€“ (ERROR ) Home Assistant Supervisor
The recorder queue reached the maximum size of 30000; Events are no longer being recorded
22:02:20 ā€“ (ERROR) Recorder
==> should I reboot home assistant?
Nonsense, esphome is a separate addon and although the source files are in /config/esphome, they arenā€™t touched by core.
Again nonsense.
Logger: homeassistant.components.media_player
Source: components/media_player/__init__.py:1165
Integration: Media Player (documentation, issues)
First occurred: 21:45:57 (3 occurrences)
Last logged: 21:46:11
media_player.forked_daapd_server allows media browsing but its integration (forked_daapd) does not
So there is no sun.sun in dev tools/stats? Not anyone elses experience. Please check.
I really appreciate all the works that devs put into home assistantā€¦
But its gonna be more and more pain in the ass to check all breaking changes everytimeā€¦
And and more and more often things break after monthly update :frowning:
I knew about gpio / dht sensor but now telegramā€¦ last month card mod didnt work anymore.
Dont wanna be partypooper because really appreciate all the work but sometimes think that more thinking about releases / breaking changes can be doneā€¦
It wasnā€™t showing up it entities list and dev tools. Came back after restart though. Probably just an issue with first start after update.
Nonsense or not, thatā€™s what happened. After the upgrade I clicked on ESPHome addon and saw empty list of devices. Tried restarting HA as well as whole system and nothing. I have also noticed that Samba addon couldnt access the config folder (permissions?) while it could access everything else.
After Reboot Fritz Box Connect fails. Password Error. I can 't fix it.
Are the yaml files in config/esphome?
