No, I didn’t
Yes I have exalty the same. Since the update to core-2022.6.7. my system needs at least a 10 seconds more to start, resulting in several over 10 second warnings well
Which system you are running it on? I’m using an Odroid N2+.
I’m running on a Pi4B
Does the system then work properly?
I run an Odroid N2+ (Home assistant Blue) also and I also see more and more of these 10 seconds warnings.
I am not sure the startup is that much longer. We are just beeing spammed by these 10 second warnings which appear to be pointless.
BTW: When was the change, since when I cannot scroll e.g. entity list (and some other lists) anymore on desktop Chrome, etc. with cursor and page keys, and via mouse fast scrolling wheel only a few lines after which I have to wait for some time to be able to scroll in the next few lines and since I don’t have a scrollbar anymore, etc.?
Or is this only an error on my devices and I can locally get rid of this anyhow?
This is really not good anymore. And I wonder, why this is not the case e.g. on ipad safari. There I can still scroll smoothly and fast through the whole lists.
Except a longer startup time, I didn’t see any side effects
Thank you! your answer helped me!
Hi All,
After updating to core-2022.6.7 my device trackers from the companion app’s (3 off them) won’t update device tracker state in homeassistant anymore. can’t see any errors in the logs niether the companion logs
Anyone with the same issue?
Regards,
Danny
I Agree,
No difference in start up time.
Just loads of warnings!!!
No issue here using the android companion app.
mqtt lights configured with use of new format stuck in unavailable state after using Reload feature if they have availability configured
HA restart helps (until next reload)
Interesting, that other entity types (at least sensors and covers) don’t manifest this issue.
Since core 2022.6.7 my startup increased significant.
On core 2022.6.6 and before, only the fritzbox was slow ( ca 60 sec) and all other integrations where below 30 sec.
Now ca 5 integrations, including supervisor, are above the 30 seconds:
Further more, before the last update only incidentally a 10 seconds warning popped up. Now it’s structurally a whole list:
There must be a change in this latest core version that i.e. increased the time to create entities or something like that
I had this problem (or at least a similar one, since I’m not sure it was that update that caused the problem). The Companion App location sensors became disabled. You can find a the solution here HA app- phone never leaves home - #2 by dshokouhi
I don’t see anything that changed in core between 2022.6.6 and 2022.6.7 that would explain the increase. In fact there were only integration changes between the versions and no core changes:
I have this as well. If it was since 2022.6.7 or already with 2022.6.whatever, I cannot say anmyore
Setup of sensor platform dwd_weather_warnings is taking over 10 seconds.
28. Juni 2022, 20:24:26 – (WARNUNG) Sensor - Die Nachricht ist zum ersten Mal um 28. Juni 2022, 20:24:06 aufgetreten und erscheint 6 mal
Setup of binary_sensor platform homematic is taking over 10 seconds.
28. Juni 2022, 20:24:26 – (WARNUNG) Binärsensor
Setup of switch platform rest is taking over 10 seconds.
28. Juni 2022, 20:24:16 – (WARNUNG) Homematic (benutzerdefinierte Integration) - Die Nachricht ist zum ersten Mal um 28. Juni 2022, 20:24:16 aufgetreten und erscheint 21 mal
Setup of input_boolean is taking over 10 seconds.
28. Juni 2022, 20:24:07 – (WARNUNG) /usr/local/lib/python3.9/asyncio/events.py - Die Nachricht ist zum ersten Mal um 28. Juni 2022, 20:24:07 aufgetreten und erscheint 8 mal
etc. etc. Sometimes with “start cannot be finisehd, please report [list of all integrations] to the developers”
A few point releases ago I had usually 4 of 10 second pointless warnings.
Now I have something like this
2022-06-29 18:03:02 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-06-29 18:03:02 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2022-06-29 18:03:02 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2022-06-29 18:03:02 WARNING (MainThread) [homeassistant.components.scene] Setup of scene platform homeassistant is taking over 10 seconds.
2022-06-29 18:03:02 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2022-06-29 18:03:03 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-06-29 18:03:03 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2022-06-29 18:03:03 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2022-06-29 18:03:03 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-06-29 18:03:03 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
Why all these 10 seconds. Just a few months ago there were none of these. Instead there were the up to 100 IOS app errors. I actually remember that the release that fixed the IOS error log bug was the same that started the 10 seconds warnings.
There is also a problem with the way the logs are displayed in the browser. It happens often that the front end code fails to load the cache but keeps on displaying a cached version. And it is in the browser because another computer will not show same problem at same time. Only fix is to open developer tools and do a hard reload with cache flush. Not even control F5 solves the problem
