I donβt see how core has the functionality of the custom component either.
Iβll report a proper bug when I have 5 minutes to collate more data than βit doesnβt work. Pls fixβ for the bug ticket
Installed the 2022.7.1 and history page is now working fine with area
So great
the core mobile_app has geocoded_location if thats what youβre looking for. And then some. Distance and time to any other lat/long can easily be checked based on the current position, or relative to any other. Heck, even a travel route is easily templated. All using core integrations, all under scrutiny of HA checks.
Used the Places integrations some years ago myself, and migrated to core when all of that became an integral part of HA
Hi all,
What happend with the history when you include entities etc?
This is not shown anymore in the history. You now need always select entities, areas or devices?
I have this in my split configuration:
# βββ βββββββββββββββββββββββ βββββββ βββββββ βββ βββ
# βββ ββββββββββββββββββββββββββββββββββββββββββββ ββββ
# βββββββββββββββββββ βββ βββ βββββββββββ βββββββ
# βββ ββββββββββββββ βββ ββββββββββββ βββ βββ
# βββ ββββββββββββββ βββ βββββββ βββ βββ βββ
# HISTORY
# https://www.home-assistant.io/integrations/history/
include:
entities:
# Humidity
- sensor.buienradar_humidity
- sensor.bathroom_humidity
# Device Trackers
- sensor.kay_presence_homekit
- device_tracker.cenkay
- sensor.peter_presence_homekit
- device_tracker.peter_iphone
- light.bathroom_all
- light.bedroom_all
- light.hallway_all
- light.balcony_all
- light.toilet_all
- light.livingroom_all
- light.kitchen_all
- light.sink_all
- light.kitchen_sink
# Last messages
- sensor.alexa_last_message
- sensor.washing_machine_data
- sensor.dryer_machine_data
- sensor.dishwasher_machine_data
- fan.afzuiging_badkamer
- device_tracker.milight_hub_2
# DSMR Current Watt delived now
- sensor.dsmr_reading_electricity_currently_delivered
# Zwave Motion sensors
- binary_sensor.toilet_detection
- binary_sensor.bathroom_detection
- binary_sensor.hallway_detection
- binary_sensor.livingroom_detection
- binary_sensor.bedroom_detection
- binary_sensor.kitchen_detection
- binary_sensor.diningroom_detection
- binary_sensor.bedroom_door_contact
- binary_sensor.diningroom_door_contact
- binary_sensor.frondoor_door_contact
- binary_sensor.imac_door_contact
# Zwave Watt and KwH
- sensor.imac_watt
- sensor.imac_kwh
- sensor.toog_watt
- sensor.toog_kwh
- sensor.washer_watt
- sensor.washer_kwh
- sensor.hallway_watt
- sensor.hallway_kwh
- sensor.bank_watt
- sensor.bank_kwh
- sensor.dishwasher_watt
- sensor.dishwasher_kwh
- sensor.bedroom_watt
- sensor.bedroom_kwh
- sensor.peter_watt
- sensor.peter_kwh
- sensor.kay_watt
- sensor.kay_kwh
- sensor.dryer_watt
- sensor.dryer_kwh
# Sensors that have a correction
- sensor.neo_plug_imac
- sensor.neo_plug_toog
- sensor.neo_plug_balcony
- sensor.neo_plug_xmas_1
- sensor.neo_plug_hallway
- sensor.neo_plug_bedroom
- sensor.neo_plug_peter
- sensor.neo_plug_kay
- sensor.neo_plug_dryer
- sensor.neo_plug_washer
- sensor.neo_plug_dishwasher
- sensor.neo_plug_fridge
# Switches
- switch.balcony
- switch.bathroom
- switch.bedroom
- switch.toilet
- switch.hallway
- switch.cooking
- switch.diningtable
- switch.dressoir
- switch.kitchen
- switch.sink
- switch.wall
- switch.window
will try to disable automations, eventhough I do not have any fancy ones running to see if this impacts this. On HACS /3rd party integrations I use quite a few, so it is difficult to tell which one may be causing the problem. but as mentionned I have an almost empty system running for tests and I can see that there is a small leak there as well (several days scale though), hence my idea of the core system, but you may be right that this is 3rd party related.
Interesting, thanks. Perhaps itβs come on more than I knew!
Struggling to find documentation for this - could you give me a point in the right direction?
sure, start here Mobile App - Home Assistant
and then follow the links for your device
and here Feature overview | Home Assistant Companion Docs is the full documentation of the possibilities
did you miss all of those posts in this thread on the subject? Hard reallyβ¦
but yes, no more auto show all, nor currently the option to do so
you can manually rebuild that using auto-entities, though it is in no way a true replacement for what was lost on us. (it is way slower)
I would like multiple datasets with entityβs for the history and had the idea to use groups to create such urls dynamically.
http://<ip_or_hostname>:8123/history?entity_id={% for entity in expand('group.windows')|map(attribute='entity_id')|unique|list|sort -%}
{{ entity + '%2C' if not loop.last }}{{ entity if loop.last }}
{%- endfor %}
Unfortunately I canβt find a way to create a weblink or button action that supports templating.
Thanks - I think I see the disconnection here. In my case, Iβm not using the HA app as location data source, but rather a series of unconnected, external location sources instead. Unless Iβm much mistaken, this need to run this functionality on the HA server-side rather than through the native HA app means this approach wonβt work for me.
I might just not have found it yet but is there a way to use the βChange any weather unit to your preferenceβ on Climate Entities, so changing C to F or vice versa.
Or create a new βAreaβ and add all entities you want to see into this Areaβ¦
FYI for any other user also having this issue, this did the trick for me. Back to a 5 star upgrade with no issues.
Looks like 2022.7.1 fixed the issue for me with entity-less devices on the History page. I did need to clear my browser cache to completely resolve the problem.
Without 1:n areas not a solution either, if you are already using areas.
Except that would break all other areasβ¦. No option to use more than 1 area or nest areas
Aamof I have an All House area, but that holds entities not tied to a specific area in the home. Things like Alarm system or motion detection, or alarmclock settings truly all Home things.
An interesting thought though, maybe we can use it in some way indeed
You arenβt clicking on the update instructions are you?
Well fwiw, I am on latest dev nightly and still saw the erratic behavior (!ofc cleared cache etc) . Maybe itβs tougher to beat this time
2022.7.1 does not have it fixed yet - Just FYI
