Also wondering what adopt was for. I adopted all 3 of mine but I don’t know if I should have don’t that. It’s not picking up any of my 3 SwitchBot bots unless I bring them close to my actual raspberry pi even if there are next to one of my new Esp32 devices.
Why are you disabling automations so often? Seems odd.
Regardless if there are particular automations you disable and re-enable manually a lot you can just put those in a dashboard. If you include automations in the UI in an entities card they still show up with a toggle.
Got it working with the v3.8 update for my LYWSD03MMC. Thanks @solyxius and @Edwin_D.
I had these installed more than a year ago (no idea what version of ATC). Connected to them via the telelink flasher, installed v3.8 and set the advertising protocol to BTHome and they started to appear in the devices & services section
Haven’t tried the plant sensors yet but this is a good start.
However I would still like to know how I can connect to the device for the log. At the moment I can only see the log when the ESP32 is connected to the laptop (via the Bluetooth proxy page - ESPHome Bluetooth Proxy). I see that the ESPs are “discovered” in ESPHome and can be adopted but not sure what this does…
Mentioning this because I didn’t see it searching the thread, but there is a pretty bad bug in the required version of zwavejs that prevents communication with certain devices (all of my Zooz brand devices in my case). The bug is documented here: META Issue: Communication problems on v10.x · Issue #4994 · zwave-js/node-zwave-js · GitHub
If you haven’t already, I recommend not updating until this is fixed if you have any Zooz devices. I wish I could safely go back and wait this out, but the next best thing is warning anyone else to avoid my fate.
Not intending to say there’s no issue… but for context, my zwave controller is a Zooz ZST10 stick, and I have ZEN15 and ZEN22 devices that have had no issues since upgrading to 2022.9.
Wow, I found myself in the same position. Would really love for Bluetooth_tracker to work again soon.
Thnx, indeed in the meantime updated as well.
I haven’t yet found the true reason for my HA crash yesterday but so far it appears to be caused by updating from 2022.8.7 to 2022.9.2
My issue is documented here.
More of a warning than error. I always seem to get a few of these.
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
hass-nabucasa 0.54.1 requires cryptography<37.0,>=2.8, but you have cryptography 37.0.4 which is incompatible.
I think I’ve run into an inconsistency in the new (beautiful) Automations view. When I select a Timer as a trigger, I can’t select “active” or “idle”, only “on”, “off”, “unavailable” or “unknown”. Shouldn’t I be able to actually see the “active” or “idle” values rather than the generic “on”, “off”?
Those are translations in your selected language. After creating it, look at the yaml and it should have active or idle. If it doesn’t, that’s a bug, if it does, it’s your language.
Here’s what in the YAML after I created the automation in the IU, no sign or active or idle:
alias: Turn kitchen timer back on again
description: "Test af automatisk slukning af lyset i køkkenet "
- platform: state
entity_id:
- automation.kitchen_light_timer
to: "off"
condition:
- condition: state
entity_id: timer.light_kitchen_timer
state: idle
- service: timer.start
data: {}
mode: single
That was embarrasing.
Updated: This time around the drop-down list boxes (from, to) only show “unavailable” or “unknown”. I had to type in “on” and “off”.
- platform: state
entity_id:
- timer.light_kitchen_timer
to: "off"
condition:
- condition: state
state: idle
data: {}
mode: single
Looks like timers don’t have state translations yet, so you have to manually put them in.
Check!
Should I point this out to someone or put a comment about missing state translation somewhere?
/// Bjarne
You can create an issue for it on github.
The esphome proxies only support non-connectable/passive devices at this time. Support for connectable/devices that need an active connection is coming in the future.
You’ll have to add multiple adapters (usb to Ethernet extensions are great way to achieve this) to the local instance if you want additional connectable range at this time.
I have a dozen Zooz devices and they’re all working fine after this update. Maybe a sporadic issue?
It definitely could be. Possibly related to the Wave controller hardware even. I’m using an Aeotec Stick and it seems one of the posters above has no problems using a Zooz controller.
