There are a few differences, I tried to outline them all in this issue on the repository for the custom component. Since they use different domains, it should technically be possible to run both integrations at the same time while you migrate.
Perfect, that answer is a) really helpful, sounds b) quite comfortable (Iâm gonna compare and potentially go the registry hack and restart way) and came c) very quickly.
Does it? Iâve just added bluetooth proxy to a couple of spare esp32âs, nothing bluetoothy is available via the esphome integration and trying to add the Bluetooth integration fails with âno unconfigured bluetooth devices connectedâ or similar
I think you also need âhardware:â in your config if you want that functionality and donât use default_config.
This was demonstrated in the stream. You do not need to add the Bluetooth integration if you do not have a dongle. The supported bluetooth devices that the bluetooth_proxy picks up will appear as if by magic in Home Assistant, ready to be configured, in the same way they would if you were using a dongle - without having to add the Bluetooth integration.
Scheduler! Yes! Love it! But why is the UI limit to such strict times? Also, the UI doesnât seem to work ok the iOS companion app or mobile Safari very well⌠canât select a time on the table
The esphome device doesnât need its own bluetooth config entry. Everything it needs to connect the esphome device to the bluetooth manager is stored in the esphome config entry.
Amazing update, thanks guys!
The Bluetooth remotes using ESP32s is quite interesting and Iâm wondering: are devices associated to an specific bluetooth adapter/remote? Like, I added a bluetooth LED using a USB adapter that has been iffy because its quite far, if I put an ESP32 bluetooth remote close to it, do I need to remove / re-add the LED device?
If not, will it automatically use that one communicate with it? How does HA know which one to use? Does it have some sense of the signal level to each device from each adapter/remote?
This was explained in the stream, that HA keeps a track of what adaptor has a stronger signal - so it knows which adaptor to use to communicate to the device with.
However the ESP32s right now are passive only, you cannot control a device with a bluetooth_proxy - yet. But that is being worked on.
Great! This implementation seems really amazing, very flexible and poweful⌠Kudos guys!
Looking forward to being able to use ESP32 remotes for active connectionsâŚ
Great update!
Frustrating timing for me - just this week I swapped coordinator and did a full repair đ¤Ś
Thanks but the need for the hardware
key is documented in both the Hardware integration and the default_config
integration.
In contrast, the schedule
key is not documented in the default_config
integration. That omission may trip up users who donât use default_config
and prefer to cherry-pick its integrations individually.
For those users itâs common practice to review default_config
's documentation whenever thereâs a monthly release to see if any new integrations were added (in August it was bluetooth
). However, for Septemberâs release, schedule
isnât mentioned in default_config
's documentation but itâs definitely part of the default_config
integration.
Nice work all, especially excited to try out the weekly schedule!
Happy birthday Home Assistant!
Great release yet again.
The weekly schedule helper has enabled me to delete hundreds of lines of code and countless input_booleans, input_datetimes and template sensors.
Some things that would be nice to have (feature request here):
- A Scheduler card for displaying and setting schedules.
- Finer grained control. 30 minutes is too coarse to be of any use for my irrigation control.
Maybe help them get the documentation up to date? Anyone can submit a PR on any of the documentation pages, its not that difficult, there are some links at the bottom of every page for thatâŚ
ESP32-C3 support didnât make it for todayâs release. It is in the works.
I know how but I donât have the time for it. However you seem to know how as well so perhaps you can spare the time to do it.
Wonder if using the bluetooth proxy is related to how matter can provision new devices using Bluetooth connections between the individual devices
Once again, all good stuff! Excellent update!
I do wish History would include that elusive âAllâ option, though.
Also, Iâm a little confused by the Processor and memory usage addition to the Hardware page. It seems like a simplified duplication of effort/functionality, especially when we can already do the following quite easily:
Anybody has an issue with shelly.light? I have a dimmer that after the upgrade show the following error:
Unable to prepare setup for platform shelly.light: Platform not found (cannot import name âATTR_WHITE_VALUEâ from âhomeassistant.components.lightâ (/usr/src/homeassistant/homeassistant/components/light/init.py)).
