2023.11 To-do: Add release title
Well done on the multiple task lists.
I’ve been waiting for that forever!
However, I’d love to have a command to automatically sort the lists in alphabetical order.
Hi @CChris
I already did: Restrict acces on to-do list card
Is there any way to trigger automation when a task is done on a to-do list? Something like shopping-list-updated event?
Seems I am another who has been bricked by this update.
I applied the update in the usual way last night (before bed).
This morning when I looked at the dashboard most of my views had progress spinners.
I tried the back up screen and there was simply a red button in the middle - I forget what it said - so that plan was scuppered.
I tried to reboot the device via the interface and it didn’t appear to do anything.
Later I lost patience and physically rebooted the RaspberryPi and now when I try to reach the URL I get a message of This site can’t be reached
My system is a Raspberry Pi 4, which is booting from an external USB 512GB SSD.
Until now it was running fine for over a year.
What can I do now to get this system back up?
Thankfully I have backups on a separate nas drive
Mike
You just answered your own question.
After the upgrade the sensor.processor_use sometimes shows 0 which was not the case before. Someone also recognized that? I’m running HAOS in a VM on Proxmox.
I was really looking forward to the extra conditions that can be used for displaying elements but I’m gutted - they don’t apply to chips! :frowning_face:. Especially the restriction by user. I don’t suppose there’s any plan to extend these to the conditions available for chips?
Great work! Since Todo’s are entities now, shouldn’t they be a Helper? Imho it is inconsistent where local entities can be found:
Schedule = Helper
Calendar = Integration
Input select = Helper
Todo = Integration
I believe that all these “local entities” should come from either integrations or helpers, but I see no benefit to mixing both types.
Doh! Just noticed that there’s an update in HACS for this. So I have everything I wanted. Sorry for being so premature! :rofl:
This is something i would also like to be able to do. We would need the list items availabe as an atribute or something not just the amount of items in the list. Hopefully it will be available in the future.
Yes, have the same on an RPI4.
I saw that mentioned on Discord during the beta. Can’t see any resolution though
I think we’re more likely to get a responding service, as entities with lots of attributes are frowned opon these days.
@tom_l - which bit is that then mate? I am not keen on sarcasm, and TBH the comment was not helpful at all, especially given that you’re a moderator.
After all, like many others here, I rely on Home Assistant for a good few things in my home, including all lighting, so I would like to get it fixed as quickly and easily as possible.
I was hoping someone might suggest I try something other than a full wipe, reinstall and then install of a back-up. Especially as the Back-up Restore screen is not accessible - and not at all now because the while system is offline!
Also, looking above I am not the only person who has had an issue upgrading here, why did this issue occur in the first place, what can a person do to avoid this in future?
Boot to a prompt (assume you can plug your Pi in to a monitor/TV)
ha core update --version 2023.10.5
Replace 2023.10.5 with the version you had previously if it wasn’t that.
He wasn’t being sarcastic. The solution to get your system back up is to restore, which you implied you were going to do with this comment:
If you were hoping for something other then “restore”, then you should have said that. People aren’t mind readers here.
Stand back a moment and try to understand that text does not always read the same way to different people.
Thanks for adding To-do lists, are you planning to add features to them? I would appreciate, like for example in google tasks, to have the possibility to schedule them with a date and at least a note field where to put some additional detail to the entry. Also the user indication (user who created the entry) will be great!
Anyhow thatks for all your efforts, I love HA!
I had this problem too for a while, but it seems to have fixed itself:
The processor use curve still looks a little bit different than before. Looks like if the CPU load varies less than it did before the update.
Set is only a function and a test, it is not a filter. Same w/ tuple.
Hi Petro,
I appreciate the answer, and do not want a flame war. but I did say these things in my original message
and
and I asked:
Maybe sarcasm was a big word, how about we settle for his answer was not at all helpful?
