2023.12: Welcome home!
FWIW my USB speakers connected via 3.5mm audio jack on the HA Blue stopped working. Just like the solution for Bluetooth at 2023.12: Welcome home! - #21 by NormandyHA I had to shut down my HA server (HA Blue Odroid N2+), unplug all USB devices except my external M.2 SSD boot drive, restart HA, and re-connect my USB devices including the USB speakers to get them working again.
@SanderKo85 Agreed. This was the 1st thing I noticed about the update. The current temp is far more important to know than the target temp. Plus It does not fit well on the mobile app - the font size it too big.
@frenck - Can we please have the choice of the old and new format?
The solution to the mode problem has been mentioned multiple times in this topic.
The only issue that remains is for auto generated dashboards and that is being looked at.
@tom_l Sorry, but thatā€™s not what I was talking about.
In your example the temperature (27C) should be large and in the centre so that it is easily viewable. The target temp (21C) should be small. These should be swapped over. Currently, when viewed on the mobile app all I see is the target temp. Iā€™m more interested in the current temp - which I cannot see.
A system run by one of the main Admins is not the real world. Your system is set up by someone who knows all the inner workings of the code.
The best thing would be if you go to the home of a random user and install the beta there - and you wonā€™t be allowed to leave until it works for them too. Sounds like a good format for a TV show or YouTube channel actually :smiling_imp:
It is what the message you were replying to was about. Also the font sizes will very likely change in next monthā€™s release.
Like many others on the beta testing team I certainly donā€™t know anything about the inner workings of the HA source. Yet I run the beta on my production system too. For the same reason. To test it.
My message wasnā€™t a aimed at all beta testers, it was a reply to Frenck, who I assume does know more than 99.9% of users about the inner workings of the code.
Beta testers are great, thank all of you! Iā€™m thinking about joining that team actually. Not sure how I want to set that up though. Iā€™m running in a VM so maybe separate snapshots/clones would work best? What happens to my history if I run a beta for two days and then decide whatever issue I met canā€™t be tolerated anymore and I roll back?
Please please please please please please
MAKE THE OLD VERSION OF THE THERMOSTAT AVAILABLE AGAIN!
If there is no intention to modify the new one!!
PLEASE PLEASE PLEASE PLEASE PLEASE!!!
There is a feature request for it. Please vote!
The count is 74 at the moment!
Youā€™ve already been told there is intention to do this. There is no need to keep repeating yourself.
Iā€™d imagine someone with the right skill set could put it up in HACS as a custom card. Be patient or do it yourself.
Not sure where this feedback should go.
I love the new ā€œbeautiful new login pageā€ however I feel the escape key should do the same behaviour as clicking previous once a user has been clicked to get back to the user selection (Other login options has a previous that would benefit the same)
I canā€™t see myself using this login screen much but this felt like intuitive behaviour to me the first time I tested to me.
Frankly I am not sure whether the target or the actual temp should be the emphasis.
Surely a thermostatā€™s main purpose is to allow you to set your desired room temp. Therefore the emphasis on target is right. It is not a thermometer.
Agreed. I donā€™t have an A/C system with a digital display in my current house but my old house did, and the display was always the set/desired temp.
I vote for this too. The actual temperature should be the important one, like before. This is also how the real thermostat is showing things. (i.e. bosch CT200). Please change this or at least make it configurable. For the rest, very nice card.
This is how your thermostat shows things. Mine on the other hand:
ebdd644188c39bec28ba3e9aac918a16b4b11491_2_690x442
Read carefully. I said IF there is no intention. I didnā€™t say BECAUSE there is no intention.
Furthermore I will try to keep it on the front burner until itā€™s resolved satisfactory
You already know there is an intention to look at this. There is no ā€œifā€. We heard you the first time. There is no reason to keep spamming this topic with your complaints.
Hence we have to camps and only one option. Would it not be nice to have both options.
( as might noticed by now I really liked to old classic version of the thermostat :laughing:)
