So I’m getting 2 database related errors, see below.
Logger: homeassistant.components.recorder.core
Source: components/recorder/migration.py:993
Integration: Recorder (documentation, issues)
First occurred: 12:35:43 (1 occurrences)
Last logged: 12:35:43
Database error during schema migration
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1900, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 736, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 206, in execute
res = self._query(query)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 319, in _query
db.query(q)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/connections.py", line 254, in query
_mysql.connection.query(self, query)
MySQLdb.OperationalError: (1205, 'Lock wait timeout exceeded; try restarting transaction')
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 742, in _migrate_schema_and_setup_run
migration.migrate_schema(
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 154, in migrate_schema
_apply_update(hass, engine, session_maker, new_version, current_version)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 856, in _apply_update
_migrate_columns_to_timestamp(session_maker, engine)
File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 993, in _migrate_columns_to_timestamp
result = session.connection().execute(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 280, in execute
return self._execute_20(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1705, in _execute_20
return meth(self, args_10style, kwargs_10style, execution_options)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/elements.py", line 334, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1572, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1943, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2124, in _handle_dbapi_exception
util.raise_(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/compat.py", line 211, in raise_
raise exception
db.query(q)
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (1205, 'Lock wait timeout exceeded; try restarting transaction')
[SQL: UPDATE states set last_updated_ts=IF(last_updated is NULL,0,UNIX_TIMESTAMP(CONVERT_TZ(last_updated,'+00:00',@@global.time_zone)) ), last_changed_ts=UNIX_TIMESTAMP(CONVERT_TZ(last_changed,'+00:00',@@global.time_zone)) where last_updated_ts is NULL LIMIT 250000;]
(Background on this error at: https://sqlalche.me/e/14/e3q8)
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:130
First occurred: 12:35:23 (1 occurrences)
Last logged: 12:35:23
Error executing query: (MySQLdb.OperationalError) (1205, 'Lock wait timeout exceeded; try restarting transaction') [SQL: UPDATE states set last_updated_ts=IF(last_updated is NULL,0,UNIX_TIMESTAMP(CONVERT_TZ(last_updated,'+00:00',@@global.time_zone)) ), last_changed_ts=UNIX_TIMESTAMP(CONVERT_TZ(last_changed,'+00:00',@@global.time_zone)) where last_updated_ts is NULL LIMIT 250000;] (Background on this error at: https://sqlalche.me/e/14/e3q8)
