With this release the database connection seems somehow broken. Any tip is welcome. Log says:
2023-04-07 17:02:17.436 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (MySQ
Ldb.OperationalError) (1205, 'Lock wait timeout exceeded; try restarting transaction')
[SQL: INSERT INTO states (entity_id, state, attributes, event_id, last_changed, last_changed_ts, last_updated,
last_updated_ts, old_state_id, attributes_id, context_id, context_user_id, context_parent_id, origin_idx, con
text_id_bin, context_user_id_bin, context_parent_id_bin, metadata_id) VALUES (%s, %s, %s, %s, %s, %s, %s, %s,
%s, %s, %s, %s, %s, %s, %s, %s, %s, %s)]
[parameters: (None, '��', None, None, None, None, None, 1680879686.0760186, None, None, None, None, None, None
, None, None, None, None)]
(Background on this error at: https://sqlalche.me/e/20/e3q8)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1964, in _exec_single_context
self.dialect.do_execute(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 748, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 206, in execute
res = self._query(query)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 319, in _query
db.query(q)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/connections.py", line 254, in query
_mysql.connection.query(self, query)
MySQLdb.OperationalError: (1205, 'Lock wait timeout exceeded; try restarting transaction')
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 129, in session_scope
yield session
File "/usr/src/homeassistant/homeassistant/components/recorder/auto_repairs/schema.py", line 78, in _validat
e_table_schema_supports_utf8
session.flush()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 4155, in flush
self._flush(objects)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 4291, in _flush
with util.safe_reraise():
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/langhelpers.py", line 147, in __exit__
raise exc_value.with_traceback(exc_tb)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 4252, in _flush
flush_context.execute()
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/unitofwork.py", line 467, in execute
rec.execute(self)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/unitofwork.py", line 644, in execute
util.preloaded.orm_persistence.save_obj(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/persistence.py", line 93, in save_obj
_emit_insert_statements(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/persistence.py", line 1184, in _emit_insert_sta
tements
yield session
session.flush()
rec.execute(self)
tements
And this multiple times. Any help is highly welcome.
I am using a mysql db outside of the home assistant docker container.
