https://raw.githubusercontent.com/major/MySQLTuner-perl/master/mysqltuner.pl
Yes, thank you for your confirmation, as Iāve flashed again my sd card yesterday, it was a SD failure. I backup on onedrive so it was easy to setup again but Iāve already ordered a SSD drive to migrate to a SSD.
You can share your theme and top bar settings to the bottom border ?
I had the top bar moved down for a few years, but after the HA 2023.4 update it went back up and I have no idea how to get it back down.
i also get the same. in addition to that, i get black block at the bottom and when i reload the page at first i dont any chips at the top of the page.
Where is the side bar menu?
Iāve read this blog and I can see that there is a problem with the companion app for swiping right for the menu BUT i get the same issue using Edge. I have hide the side bar on in my profile so how do I get to the menus?
If I try Chrome and log in, the menu is there but as soon as I hide it in Profiles for that login I canāt get it back. I am running out of browsers!
What am I missing?
And therefore I canāt backup or re-instate or upgrade or⦠anything.
Just updated to 2023.4.1.
I am seeing this in the log:
2023-04-07 22:00:28.055 ERROR (Recorder) [homeassistant.components.recorder.models.context] Error converting ulid adapt_lgt:b'Z&SB':interval:b'76' to bytes: ULID must be a 26 character string: adapt_lgt:b'Z&SB':interval:b'76'
File "/usr/src/homeassistant/homeassistant/components/recorder/models/context.py", line 19, in ulid_to_bytes_or_none
return ulid_to_bytes(ulid)
File "src/ulid_transform/_ulid_impl.pyx", line 22, in ulid_transform._ulid_impl._ulid_to_bytes
ValueError: ULID must be a 26 character string: adapt_lgt:b'Z&SB':interval:b'76'
2023-04-07 22:01:57.874 ERROR (Recorder) [homeassistant.components.recorder.models.context] Error converting ulid adapt_lgt:b'Z&SB':interval:b'7X' to bytes: ULID must be a 26 character string: adapt_lgt:b'Z&SB':interval:b'7X'
ValueError: ULID must be a 26 character string: adapt_lgt:b'Z&SB':interval:b'7X'
2023-04-07 22:01:58.029 ERROR (Recorder) [homeassistant.components.recorder.models.context] Error converting ulid adapt_lgt:b'Z&SB':interval:b'7X' to bytes: ULID must be a 26 character string: adapt_lgt:b'Z&SB':interval:b'7X'
EDIT: Found related github issue: MariaDB/Recorder issue after updating to 2023.4 Ā· Issue #91019 Ā· home-assistant/core Ā· GitHub .
EDIT2: Usually I update HACS components before upgrading. I didnāt, but I should have. I restarted HA, then updated the components, problem gone. Probably related to Adaptive Lighting.
Thx. Will run it now.
Update seems still be active, recorder still not running.
Sure can: š£ Rounded - Dashboard guide
@arifroni, I had the same. It was because of an older custom button-card version. Updating it will fix the empty space at the bottom.
Post 39: āIt is in breaking changes. You just may not realize it.ā
Post 72: āSuper hoping this is a temporary feature loss with the complete removal of polymer?ā
Post 94: "WARNING: Polymer will be removed from window in Home Assistant 2023.5.
Post 118: āWARNING: Polymer will be removed from window in Home Assistant 2023.5.ā
So, which post tells me what is Polymer and why should I care?
somehow I get the feeling youāre pulling my legā¦
but, letās put it this way: If you donāt see the warning in Inspector, you neednāt care.
btw, If you really want to know, thereās a link in the Blogpost to the Polymer library. Maybe you didnt spend the 2 minutes to actually read it?
To be fair it is in the section of the blog that starts with āIf you are a custom integration developerā
Any idea how to repair the alexa / cloud integration after release change? Integration now longer works. Alexa cant reach the devices any longer. Home Assistant cant manage the integration also, the manage entities page keeps loading forever.
i have version 3.5 of button card but it doesnāt solve the black bar problem.
Same here. The entity states are in english (before is in Portuguese) and the rest os the UI is in Portuguese.
Any solution?
Never had problems with new releases before but ever since 2023.4.1 my HA keeps restarting at different intervals. Iām running on a Thinclient, Proxmox with HA in container. Hopefully it will be fixed.
Please look through your logs for issues and errors and fix or report them to github. Donāt assume things will be fixed especially when we donāt have reported issues.
Introducing global macros is a real feature.
Updated my observations regarding using macros.
Macros may be used in configuration (for template sensors, for instance), in Lovelace (for cards supporting jinjia, for card-mod), in blueprints, in Dev tools->template.
Hi Petro,
Thanks, I know. Just a bit busy at the moment. But I found a couple of errors in the log that I will Google first:
> Logger: homeassistant.components.lovelace
> Source: components/lovelace/__init__.py:115
> Integration: Dashboards ([documentation](https://www.home-assistant.io/integrations/lovelace), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+lovelace%22))
> First occurred: 14:31:43 (1 occurrences)
> Last logged: 14:31:43
> Lovelace is running in storage mode. Define resources via user interface
> and:
> Ended unfinished session (id=222 from 2023-04-08 12:30:18.271400)
> 14:31:45 ā (WAARSCHUWING) Recorder
> The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
hmm, restart is picky todayā¦
2023-04-08 15:13:42.578 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /homeassistant/restart request
2023-04-08 15:15:11.776 WARNING (MainThread) [homeassistant.core] Timed out waiting for shutdown stage 1 to complete, the shutdown will continue
2023-04-08 15:15:11.779 WARNING (MainThread) [homeassistant.core] Shutdown stage 1: still running: <Task pending name='Task-108068' coro=<async_enable_report_state.<locals>.report_states() running at /usr/src/homeassistant/homeassistant/components/google_assistant/report_state.py:43> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()]> cb=[set.remove()]>
