Im still On 2023.4.6 due to ZHA issues
Iāve gotten the same error, but trying to connect to NAS storage exposed from my router running FreshTomato. I have tried both with and without authentication enabled, with no luck either way.
Iāve also gotten a different error (āMounting backup did not succeed. Check host logs for errors from mount or systemd unit mnt-data-supervisor-mounts-backup.mount for details.ā ), but regardless Iāve so far been unable to connect to the shares, though I can connect fine from my Windows machines and Mac on the same network.
Synology NAS too, I set my shared folder NFS to allow all local traffic R/W access without authentication.
Works for me.
Path: /volume1/My Share Folder Name/
fisch55
(Fisch55)
June 8, 2023, 6:07pm
229
Mounted my NASā¦to home assistant
Is ist possible to record the Frigate files to the NAS?
crzynik
(Nicolas Mowen)
June 8, 2023, 6:08pm
230
yes, you need to create a media volume named frigate
Regarding deprecation of Google Nest - I am totally confused. The deprecation reads: The Google Nest YAML configuration has been fully removed. You should ensure you have imported your configuration and credentials into the UI before upgrading.
There are no instructions on how to do this upgrade.
The link to the current Nest Integration Documentation displays a āConfiguration.Yamlā at the end of the process.Google Nest - Home Assistant
Soā¦ Who needs to upgrade? Apparently even if weāve upgraded we still have a reference to Configuration.Yaml on our integrations page? How do we tell if we need to upgrade, and how do we do it?
fisch55
(Fisch55)
June 8, 2023, 6:23pm
232
mmmmm something went wrongā¦
Just did the update, but somehow my MQTT is not working correct. Iāve seen the braking change about last_reset_value_template, but in my configuration I donāt use that.
Am I the only one or do more people have problems with MQTT after updating?
wmaker
(Tommy Long)
June 8, 2023, 7:02pm
234
Samsung TV Remote -
From the release notes: " The Samsung TV now has a remote entity, allowing you to send remote key presses directly to your TV!"
Thought I would give it a try. The samsung doc has an example:
service: remote.send_command
device_id: 72953f9b4c9863e28ddd52c87dcebe05
command:
- KEY_MENU
So my first problem was trying to determine what the device id should be in my case.
I found it in .storage/core.device_registry
"id": "9da6e65f04777cf3468579811960d198",
"identifiers": [
"samsungtv",
"08f0d180-0077-1000-877d-4844f777bb7c"
"manufacturer": "Samsung",
the device_id is: 9da6e65f04777cf3468579811960d198
With that, the service call worked!!
If there is a better way to find out what the device_id is, I would be happy to know
pjn77
June 8, 2023, 7:03pm
235
Iām lost with network storage.
I want to mount the external drive i already have exposed as a SAMBA share through the official addon (which works fine). I want to use this extra space to store frigate recoardings.
Ive been able mout it as a media folder butā¦now what? Does this mean it becomes ātheā media storage? Or additional storage that can be used for media? No folders or files have been created in the share, and HA is working as normal.
ludeeus
(Ludeeus)
June 8, 2023, 7:05pm
236
It create a new folder under /media with the same name as you gave the mount.
For frigate, you have to name it āfrigateā.
pjn77
June 8, 2023, 7:07pm
237
Yeah ive just seen you can browse the share under ālocal storageā.
If I name it frigate does that mean it can be only used for frigate? Is the idea to have one share dedicated to frigate in addition to ones for other media?
ludeeus
(Ludeeus)
June 8, 2023, 7:09pm
238
I do not use frigate, but as I understand it, it has a strict path requirement of /media/frigate.
You can however add multiple mounts with different names to the same share.
Ok, everything seemed fine. But it is very quiet in house.
That is a major problem with this update!
VLC-TELNET quit on me. No TTS announcements. No sound from the server anymoreā¦
investigating now, somehow i feel, this will be a tough oneā¦
Created own topic for thisā¦
So after yesterdays update VLC-TELNET addon does not breathe anymore.
After almost three years flawless service, we have no more TTS announcements.
The addons says this:
s6-rc: info: service vlc: starting
s6-rc: info: service nginx: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service vlc successfully started
s6-rc: info: service nginx successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: ā¦
I can use some assist with this, please
EDIT:
Looks very similar to this:
opened 10:26AM - 07 Jun 23 UTC
closed 10:17AM - 13 Jun 23 UTC
duplicate
About one month ago my speakers does not work anymore. So I ordered new ones. Thā¦ e new one also does not work. They were both active speakers on the output jack of the Home Assistant Yellow.
I am on home assistant OS 10.2
In the official VLC addon log when I try to play it get this error message:
vlcpulse audio output error: stream connection failure: No such entity
main audio output error: module not functional
main decoder error: failed to create audio output
I did a full backup and reset everything then I started again with the backup. On first start it works after a reboot it stopped working.
Also tried a USB soundcard which also appear on the drop-down menu in VLC, but when I select it also got the same error. So I do not think that is a hardware fault.
The logs from the audio plugin
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/alsa-mixer.sh
[11:50:34] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
[11:50:35] INFO: Adjust ALSA mixer settings for /dev/snd/controlC1
cont-init: info: /etc/cont-init.d/alsa-mixer.sh exited 0
cont-init: info: running /etc/cont-init.d/filesystem.sh
cont-init: info: /etc/cont-init.d/filesystem.sh exited 0
cont-init: info: running /etc/cont-init.d/pulse-config.sh
[11:50:35] INFO: Found RaspberryPi system
cont-init: info: /etc/cont-init.d/pulse-config.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun alsa (no readiness notification)
services-up: info: copying legacy longrun pulseaudio (no readiness notification)
s6-rc: info: service legacy-services successfully started
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
W: [pulseaudio] main.c: Home directory of user 'root' is not '/var/run/pulse', ignoring.
W: [pulseaudio] caps.c: Normally all extra capabilities would be dropped now, but that's impossible because PulseAudio was built without capabilities support.
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/ for an explanation why system mode is usually a bad idea.
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card1: No such file or directory
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card0: No such file or directory
E: [pulseaudio] module-rescue-streams.c: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
opened 05:34PM - 16 Mar 23 UTC
closed 10:15AM - 13 Jun 23 UTC
[16:59:00] INFO: Service restart after closing
s6-rc: info: service legacyā¦ -services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[00:59:06] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
E: [pulseaudio] main.c: Failed to acquire org.pulseaudio.Server: org.freedesktop.DBus.Error.AccessDenied: Connection ":1.35" is not allowed to own the service "org.pulseaudio.Server" due to security policies in the configuration file
E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.ServiceUnknown: The name org.bluez was not provided by any .service files
opened 03:46AM - 20 Apr 23 UTC
closed 10:01AM - 20 Apr 23 UTC
add-on: vlc
### Describe the issue you are experiencing
Prior to the upgrade, I used the VLā¦ C add-on to play media out of the Home Assistant Blue's audio jack. I also used the vlc_telnet integration to play media out of the Home Assistant Blue's audio jack from automations. This worked 100% of the time until the OS 10.0 upgrade. Now, the VLC sidebar shows the plugin playing local files just as it did before but no audio is actually generated from the hardware output device.
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### Which add-on are you reporting an issue with?
VLC
### What is the version of the add-on?
0.1.3
### Steps to reproduce the issue
1. Install VLC add-on and Telnet_VLC (core-vlc) integration
2. Connect audio output of Home Assistant Blue to known working speaker equipment
3. Play a media file to media_player.vlc_telnet
4. Listen and you will hear no audio on the output from Hoem Assistant Blue's hardware audio jack
### System Health information
## System Information
version | core-2023.4.5
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.10
os_name | Linux
os_version | 6.1.24
arch | aarch64
timezone | America/Los_Angeles
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 5000
Installed Version | 1.32.1
Stage | running
Available Repositories | 1278
Downloaded Repositories | 5
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | September 11, 2023 at 17:00
relayer_connected | true
relayer_region | us-east-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | false
remote_server | us-east-1-9.ui.nabu.casa
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 10.0
update_channel | stable
supervisor_version | supervisor-2023.04.0
agent_version | 1.5.1
docker_version | 23.0.3
disk_total | 113.9 GB
disk_used | 10.8 GB
healthy | true
supported | true
board | odroid-n2
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.5.0), Samba share (10.0.0), VLC (0.1.3), chrony (2.5.0), Z-Wave JS (0.1.77), Terminal & SSH (9.6.1), Signal Messenger (0.66.0)
</details>
<details><summary>Dashboards</summary>
dashboards | 3
resources | 0
views | 2
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | April 10, 2023 at 00:12
current_recorder_run | April 19, 2023 at 01:19
estimated_db_size | 169.52 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
### Anything in the Supervisor logs that might be useful for us?
```txt
Logger: homeassistant.components.vlc_telnet
Source: components/vlc_telnet/media_player.py:60
Integration: VLC media player via Telnet (documentation, issues)
First occurred: 01:24:50 (1 occurrences)
Last logged: 01:24:50
Command error: Parameter volume not in range(0, 500)
### Anything in the add-on logs that might be useful for us?
_No response_
### Additional information
_No response_
Home Assistant 2023.6.0
Supervisor 2023.06.1
Operating System 10.2
Frontend 20230607.0 - latest
It took a while for me to finally figure out why I had no microphone a few weeks ago. Found input volume was set too low. Managaged to figure out issues in the CLI volume setting. All was working great. Never had any issues with speakers until now. Then yesterday I do the new update and I lost both microphone and speakers. They still show up in the audio info. I can choose my mic and speaker (bothā¦
So Iām not the only oneā¦
gerd1
(Gerd RĆ¼tten)
June 8, 2023, 7:22pm
240
Dear all
snipping from release notes 2023.6
The following integrations are now available via the Home Assistant UI:
This doesnāt work.
If i integrate it via UI a message told me, it must be done via configuration.yaml
Best regards
Gerd
frenck
(Franck Nijhof)
June 8, 2023, 7:32pm
241
Seems like you are running it as a custom integration:
And not using the one Home Assistant provides.
ā¦/Frenck
dlasher
(dlasher)
June 8, 2023, 7:40pm
242
I had the same issue, and a reboot solved it. (May as well update the agent before you reboot)
Has anyone that was having the issues with ZHA / Aqara Devices / HUSBZB-1 tried out 2023.6 yet?
I have been sitting back on 2023.4.6 because any version in 2023.5.X has made my Aqara devices completely unreliable. They just stop responding, but donāt even report that theyāre unavailable. Re-pairing makes it work for a couple hours but then they stop again.
Everything is completely rock solid in 2023.4.6.
Iām very interested in the new NFS stuff but I spent so much time during 2023.5ās run updating and rolling back and re-pairing devices that I just want to wait until I see more discussion and confirmation of this issue. It doesnāt seem like it has much attention.
GSzabados
(GƔbor Szabados)
June 8, 2023, 8:05pm
244
As the Network storage option has been added, is there any way to create a Backup to a USB connected external drive? Not to the Data drive, not to move the Data drive, but to directly to an external USB connected drive. (HDD/SSD/Pendrive)
