No sound output VLC-TELNET after update 2023.6.0
So after yesterdays update VLC-TELNET addon does not breathe anymore.
After almost three years flawless service, we have no more TTS announcements.
The addons says this:
s6-rc: info: service vlc: starting
s6-rc: info: service nginx: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service vlc successfully started
s6-rc: info: service nginx successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/ingress.sh
[00007f3483f70760] main interface error: no suitable interface module
[00007f34841ee9b0] main libvlc error: interface "globalhotkeys,none" initialization failed
[00007f3483fa09d0] main playlist: playlist is empty
[00007f3483f70740] [http] lua interface: Lua HTTP interface
[00007f3483f75960] [telnet] lua interface: Listening on host "telnet://:4212".
cont-init: info: /etc/cont-init.d/ingress.sh exited 0
cont-init: info: running /etc/cont-init.d/secret.sh
[21:20:34] INFO: Service restart after closing
cont-init: info: /etc/cont-init.d/secret.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[21:20:34] INFO: Successfully send discovery information to Home Assistant.
2023/06/08 21:20:35 [notice] 149#149: using the "epoll" event method
2023/06/08 21:20:35 [notice] 149#149: nginx/1.22.1
2023/06/08 21:20:35 [notice] 149#149: OS: Linux 5.10.0-23-amd64
2023/06/08 21:20:35 [notice] 149#149: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2023/06/08 21:20:35 [notice] 149#149: start worker processes
2023/06/08 21:20:35 [notice] 149#149: start worker process 154
There are some errors…
The VLC media player looks, like there is nothing wrong, says it is playing a file, but no sound is coming out of the speakers.
After that attempt (only one), addon logs says this many times:
[00007f3483f96d50] vlcpulse audio output error: stream connection failure: No such entity
[00007f3483f96d50] main audio output error: module not functional
[00007f347f288fd0] main decoder error: failed to create audio output
Home Assistant 2023.6.0
Supervisor 2023.06.1
Frontend-versie: 20230607.0 - latest
Debian 11 fully up to date
OS agent 1.5.1
intel Celeron quadcore machine, onboard sound
Does anyone have an idea?
Looks very similar to this:
So I’m not the only one…
i have this problem too. I tried both the usb sound card and the output on the pi, there is no sound. It happened after I upgraded to 2023.06.
Well, no reactions from the dev’s, they are busy with command_line and bluetooth troubles. We have to wait…
This is truly unfortunate. I just moved houses and built up a new HA instance with the intention of using this feature. Hopefully they recognize this is an issue. I completely understand bugs occur.
I have created an alarm system using vlc and tts, but now the audio part is not working. I have to change the audio part of the alarm system. I guess it’s not very reliable for the alarm system.
Hello
Same error also after upgrade to HA supervisor 2023.6.0. It was working for 2 years and now we have nor TTS nor radio.
I have opened the VLC report : main decoder error: failed to create audio output Ā· Issue #4355 Ā· home-assistant/supervisor Ā· GitHub as bug and wait.
Regards
I’m having same problem with MPD trying to play audio on my Home Assistant host. I suspect same root problem, based on the timing of the failure being the same version release.
Looks like the previously mentioned bug with sound output is found and solved, we hope on a quick release now… :wink:
Thanks to all involved :+1:
Same problem.
[0000007fb37db0b0] main decoder error: failed to create audio output
[0000007fbc807d50] vlcpulse audio output error: stream connection failure: No such entity
[0000007fbc807d50] main audio output error: module not functional
This is again broken for me. It kinda plays but stutters a lot, so that I can hear it is playing.
Browser plays media ok.
Home Assistant 2023.7.3
Supervisor 2023.07.1
Operating System 10.3
Frontend 20230705.1 - latest
