Database connection broken in 2023.6.2 !!!
Hi all,
As soon as I upgraded my install to core 2023.6.2 the recorder stopped working, reason being it can’t connect to my external MariaDB any more.
After trying with no success to make it work I had to revert to 2023.6.1 using a backup.
Did anyone else notice this behaviour?
I did not see any mention on the release notes relative to the recorder or database access, so why did this happen?
My recorder is set up using:
db_url: mysql://<user>:<pwd>@<mariadb_ip>:<mariadb_port>/<db_name>?charset=utf8mb4
The strangest thing is that while still trying to figure out what was going on with 2023.6.2 I connected to home assistant via ssh and sucessfully conected to the db from home assistant shell as you can see:
➜ ~ mysql -h <ip> -P <port> -u <user> -p<pwd>
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 1337
Server version: 10.3.37-MariaDB Source distribution
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> exit
Bye
➜ ~ uname -a
Linux a0d7b954-ssh 6.1.29 #1 SMP PREEMPT_DYNAMIC Wed May 24 18:54:58 UTC 2023 x86_64 Linux
➜ ~ ll
total 0
lrwxrwxrwx 1 root root 7 Jun 15 11:17 addons -> /addons
lrwxrwxrwx 1 root root 7 Jun 15 11:17 backup -> /backup
lrwxrwxrwx 1 root root 7 Jun 15 11:17 config -> /config
lrwxrwxrwx 1 root root 6 Jun 15 11:17 media -> /media
lrwxrwxrwx 1 root root 6 Jun 15 11:17 share -> /share
lrwxrwxrwx 1 root root 4 Jun 15 11:17 ssl -> /ssl
Anyone has any ideia of what is going on?
Here’s the logs from HASS regarding the failing connection:
`2023-06-15 10:42:26.910 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2023-06-15 10:43:13.796 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2023-06-15 10:44:14.112 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2023-06-15 10:44:27.449 ERROR (Recorder) [homeassistant.components.recorder.core] Error during connection setup: (MySQLdb.OperationalError) (2002, "Can't connect to server on 'xxx.xxx.xxx.xxx' (115)")
(Background on this error at: https://sqlalche.me/e/20/e3q8) (retrying in 3 seconds)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 145, in __init__
self._dbapi_connection = engine.raw_connection()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 3293, in raw_connection
return self.pool.connect()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 452, in connect
return _ConnectionFairy._checkout(self)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 1268, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 716, in checkout
rec = pool._do_get()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/impl.py", line 168, in _do_get
with util.safe_reraise():
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/util/langhelpers.py", line 147, in __exit__
raise exc_value.with_traceback(exc_tb)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/impl.py", line 166, in _do_get
return self._create_connection()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 393, in _create_connection
return _ConnectionRecord(self)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 678, in __init__
self.__connect()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 902, in __connect
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/pool/base.py", line 898, in __connect
self.dbapi_connection = connection = pool._invoke_creator(self)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/create.py", line 637, in connect
return dialect.connect(*cargs, **cparams)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/default.py", line 616, in connect
return self.loaded_dbapi.connect(*cargs, **cparams)
File "/usr/local/lib/python3.11/site-packages/MySQLdb/__init__.py", line 123, in Connect
return Connection(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/MySQLdb/connections.py", line 185, in __init__
super().__init__(*args, **kwargs2)
MySQLdb.OperationalError: (2002, "Can't connect to server on 'xxx.xxx.xxx.xxx' (115)")
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 924, in _setup_recorder
self._setup_connection()
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1397, in _setup_connection
Base.metadata.create_all(self.engine)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/sql/schema.py", line 5796, in create_all
bind._run_ddl_visitor(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 3243, in _run_ddl_visitor
with self.begin() as conn:
File "/usr/local/lib/python3.11/contextlib.py", line 137, in __enter__
return next(self.gen)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 3233, in begin
with self.connect() as conn:
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 3269, in connect
return self._connection_cls(self)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 147, in __init__
Connection._handle_dbapi_exception_noconnection(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 2431, in _handle_dbapi_exception_noconnection
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
self.__connect()
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (2002, "Can't connect to server on 'xxx.xxx.xxx.xxx' (115)")
(Background on this error at: https://sqlalche.me/e/20/e3q8)`
I see a lot of references to python… did anything change on python side?
Thanks in advance for any assistance,
-jprates
