No, container.
as of yesterday (was it the update to 2023.6.2� must be given the command_line changes in it) my command_line cpu temp sensor stopped working.
command_line:
# https://github.com/adamoutler/HassOSArgonOneAddon/issues/14#issuecomment-880629120
- sensor:
unique_id: cpu_temp_command_line
# name: Cpu temp (read)
command: >
read -r val </sys/class/thermal/thermal_zone0/temp;echo ${val}
value_template: >
{{value|multiply(0.001)}}
unit_of_measurement: °C
not using system monitor, as that is not compatible with the MiniPC architecture
its not the syntax of the command_line itself, Ive had those changed during the beta, and it worked flawlessly before:
more detail:
anyone else seeing this same behavior?
must be something going wrong when they added Fix manual update for Command Line by gjohansson-ST ¡ Pull Request #94433 ¡ home-assistant/core ¡ GitHub and I didnt check its effect�
issue: command_line no longer updates ¡ Issue #94706 ¡ home-assistant/core ¡ GitHub
No problem here on 6.2 (x86):
command_line:
- sensor:
name: CPU Temperature
command: cat /sys/class/thermal/thermal_zone2/temp
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(2) }}"
ok let me try that different command
I just had to restart to get it to show, and because I dont use the name: field in the config, had expected it to show up under its unique_id name
- sensor:
unique_id: cpu_minipc_temp_command_line
command: cat /sys/class/thermal/thermal_zone0/temp
value_template: >
however, had a hard time finding itâŚ
seems a further PR is in order to at least have it adopt the naming scheme of template:
next Ill add it to recorder and see if it tracks the temp at all.
as the link in my post explains, the âreadâ is an optimal version, so I would hope it to get back online
Is it? I couldât find that in your links. However, that command is how it is described in the documentation.
this link to the GitHub
Ok, thanks
The option is only available for hassos
btw, now look whatâs happening, we have life back again (still my original âreadâ command_line sensor):
and as I should have noticed before, the state was probably right, at least upon restart, but the history graph was immobilized:
cant explain what is happening yet, both at least report the same
Confession
wish I could retract the aboveâŚ
as I typed the above sentence on my original âreadâ sensor, it started to dawn on me. During that update to 2023âŚ6.2 I had changed the entity_id of my sensor, but forgotten to change that in my recorder included filter:
- sensor.cpu_temp #_read
my apologies, Ill retract/close the issue right awayâŚ
No, also for supervised.
No, itâs not available for supervised. Maybe with an rpi, but definitely not with bare bones Debian on a generic x64 platform.
It is, you just need to make sure systemd-dbus works, and the data disk is mounted correctly (slave).
https://www.home-assistant.io/common-tasks/supervised/#network-storage
Apparently my os agent is out of date, but I mounted the normal way. Good to know, maybe Iâll update the os agent some day.
https://github.com/home-assistant/supervisor/blob/8b4e8e9804e3d9d920badcc843d2b9fe273c1e2b/supervisor/host/manager.py#L116-L117 This is how is validated, when that returns True, you can use the feature.
It is dealt with numerous times in this thread.
Thatâs great Nick, maybe I missed it
no errors in the logs
Yep, youâre not alone. I started this thread a few days ago. Thanks for the GitHub issue link!
After applying 2023.6.2, our default and dwains dashboards will not load and display âCustom-element doesnât exist.â We rolled back to 2023.6.1 to recover the dashboards.
Thank you in advance for your support, and I look forward to your comments!
