I wonder if everyone reading this understands what this NFS setting does.
It defines an NFS share which enables anyone with an IP address. Unless you are able to use some advanced Kerberos authentication. NFS is really primitive in its original scheme.
Do you want to make a directory on your Synology open with read/write access to anyone with an IP address of the local network? Go ahead. You will not be protected by username and password.
I recommend setting up a Samba share at it requires a basic username and password. I would only use NFS if the directory never contains any data containing confidential data and it is OK that it gets deleted. That may be OK for a media directory with songs you can always add again
If you use such directory for Home Assistant Backup then you put all your secrets and passwords used in your Home Assistant then I would not put it in an NFS share and especially not one where you do not even limit access to a single IP address.
I am using Firefox. When I click on āAdd-onsā I get a spinning wheel and it never loads. I then can click into everything else but not backups and I get the spinning wheel again.
If I close my browser down and open it again, login to HA I can go into my backups, but if I try and click on āAdd-onā I get the spinning wheel again and canāt click into backups again.
I cleared everything, history cache, xyz and this still happens.
If I use edge browser then all is good. Just happening in Firefox browser.
Itās because of the core update that has changed the default configuration used by the add-ons. Therefore to load all add-ons with the up-to-date configuration you need to restart the full HA environment. As add-ons donāt restart with a HA-core restart. Nothing to do with the supervisor updates.
Same here. I lost ALL automations on the UI when updating from 2023.6.1 to 2023.6.2. Also they did not trigger, although they all were present in the automations.yaml. After another reboot the automations were back on the UI and triggering.
The message tells you everything you need to know. Iām not sure why people find it confusing. Addons have a configuration. Something changed in that configuration. In order for the addon to use that new configuration, it needs to restart.
Whatever addon thatās not āupdatingā has a bug. I.e. you most likely have a custom addon thatās not updating because soemthing on it is out of date.
