How can i migrate to the core Shelly integration?
- remove from HA all Shelly devices
- remove/uninstall ShellyForHass integration
- restart HA
- configure Shelly devices
My sunrise/sunset triggers are still working…
Quick scan, this is going to be dependency hell.
So ffmpeg 7.1 needs libsdl2-dev, which needs libudev-dev, which needs libudev1, and specifially version 252.31-1~deb12u1, but as I already need debian-backports packages for hass core, version 254.16-1 is installed.
But… I think I can disable the SDL feature for this particular use as SDL is used for native video playback so I’m going to recompile the package without support for SDL…
Looks like the relevant fix for alexapy just got merged over on Gitlab, so there’s definitely progress happening on the Alexa Media Player front.
Other integrations breaking with 2024.12, FYI: Anniversaries, Frigidaire, Grocy, and Schedule State.
There has bo be somekind of backup in such cases.
Alexa Media Player 5.0.1 is released with the fix for this version and available to download/install/update to.
Verified working
yep, same here.
i am using the core integration. none of my shelly devices are working anymore with this update. logbook shows multiple errors with the shellly core integration.
Open an issue.
The PRs can be reverted.
Had/have exactly the same. So went back to 2024.11.3
Will wait for update…
Thanks for the heads up. Beside Shelly another integration that breaks. Just will be patience and wait
Can we find the steps somewhere in the documents for this transition?
No, HA documentation does not contain information about custom integrations.
Thought you mentioned in an earlier post it moved from custom to full integrated integration?
Just curious where I can find these heads up and the process to this new integration.
Thanks!
Had not notice before but experienced the same today. No automatic theme change, which has been reliable for years and years…
Haven’t found the trace yet to point to sun trigger 100%, so need to inspect further
No issues for me. All works as expected.
all shelly are dead with the update. all unavailable. After restore the whole Home Assistant all shelly are working again. This update kills shellys!
