2024.7: Time to resize your cards!
My utility power meters and utility app no longer work after upgrading to Core 2024.7.
I attached screenshots before and after update.
Here are my command line commands in configuration.yaml that create the sensors for the utility app and meters.
command_line:
  - sensor:
      unique_id: xcel_meter_power
      name: "Smart Electric Meter Power"
      #command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'"
      command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'"
      unit_of_measurement: "W"
      device_class: "power"
      scan_interval: 5
      command_timeout: 5
  - sensor:
      unique_id: xcel_meter_consumption
      name: "Smart Electric Meter Consumption"
      command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'"
      unit_of_measurement: "kWh"
      value_template: "{{ value | multiply(0.001) | round(3)}}"
      device_class: "energy"
      state_class: "total_increasing"
      #scan_interval: 86400
      scan_interval: 5
      command_timeout: 5
  - sensor:
      unique_id: xcel_meter_productiion
      name: "Smart Electric Meter Production"
      command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'"
      scan_interval: 5
      command_timeout: 5
utility_meter:
  daily_energy:
    source: sensor.smart_electric_meter_consumption
    cycle: daily
    #cron: "* * 9 * *"
    tariffs:
      - offpeak
      - midpeak
      - peak
  monthly_energy:
    #cycle: monthly
    cron: "* * 9 * *"
    tariffs:
      - offpeak
      - midpeak
      - peak
Screenshot before applying Core 2024.7:
Screenshot after applying Core 2024.7:
