It’s most likely a custom integration. See Tom’s response
EDIT: stickied post to talk about the issues:
@petro, I don’t use custom integration except music assistant.
Your logs should indicate what is misbehaving. Have you looked in your logs yet?
Till now, I didn’t find the root cause into the logs. I will ding into all logs when the case will come again.
Yes, my issue with History Graphs flat lining in v2024.7 seems to be caused by the iCloudv3 integration - I’ve disabled the integration & rebooted and all my History Graphs have sprung into life.
Bit annoying as I only recently installed iCloudv3 as a solution for tracking an old iPhone6 as the native HA Companion app device_tracker on iOS 12.5.7 simply doesn’t work.
@petro ,
This is in reference to, “2024.7: Time to resize your cards! - #95 by wptracy”
I homed in on the command line failure for my sensors, and entered it manually in a terminal window.
It fails with:
myown # OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /con
fig/xcelcerts/myown/key.pem
curl: (35) OpenSSL/3.3.0: error:0A000410:SSL routines::ssl/tls alert handshake failure
myown #
Odd thing is, the command also fails in a working home assistant with the same error, but the meters work and the utility app works in that home assistant. Even though I get these same logs in the working home assistant on Core 2024.6.4.
I used to be able to manually enter the curl command and got results.
I don’t know how 2024.6.4 is able to read the smart meter with the configuration.yaml command lines.
So maybe this isn’t the problem.
Logger: homeassistant.components.command_line.utils
Source: components/command_line/utils.py:56
integration: Command Line (documentation, issues)
First occurred: 7:44:42 AM (627 occurrences)
Last logged: 8:03:24 AM
Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'
Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
I’m unable to include the entire log file because it’s 44K charaters.
The limit is 32K charaters.
Here is a portion of the log file:
2024-07-05 07:44:42.116 WARNING (MainThread) [async_upnp_client.profiles.dlna] Only InstanceID 0 is supported
2024-07-05 07:44:42.206 WARNING (MainThread) [async_upnp_client.profiles.dlna] Only InstanceID 0 is supported
2024-07-05 07:44:42.207 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:42.258 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'
2024-07-05 07:44:42.292 WARNING (MainThread) [async_upnp_client.profiles.dlna] Only InstanceID 0 is supported
2024-07-05 07:44:42.310 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:42.338 WARNING (MainThread) [async_upnp_client.profiles.dlna] Only InstanceID 0 is supported
2024-07-05 07:44:42.553 ERROR (MainThread) [pysqueezebox.server] Failed communicating with LMS: <class 'aiohttp.client_exceptions.ClientConnectorError'>
2024-07-05 07:44:43.504 ERROR (MainThread) [homeassistant.components.google_cloud.tts] File /config/home-374813-17d2698e35f3.json doesn't exist
2024-07-05 07:44:43.504 ERROR (MainThread) [homeassistant.components.tts.legacy] Error setting up platform: google_cloud
2024-07-05 07:44:45.602 ERROR (MainThread) [pysqueezebox.server] Failed communicating with LMS: <class 'aiohttp.client_exceptions.ClientConnectorError'>
2024-07-05 07:44:47.684 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:47.688 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'
2024-07-05 07:44:47.850 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:52.659 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:52.713 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'
2024-07-05 07:44:52.736 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:57.387 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:57.531 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'
2024-07-05 07:44:57.549 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:44:58.893 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'alexa_media' calls async_forward_entry_setup for integration, alexa_media with title: [email protected] - amazon.com and entry_id: 1773e0b30e695f50c3c8e57add149782, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/alexa_media/__init__.py, line 625: config_entry.async_create_task(, please create a bug report at https://github.com/alandtse/alexa_media_player/issues
2024-07-05 07:45:00.293 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'alexa_media' calls async_forward_entry_setup for integration, alexa_media with title: [email protected] - amazon.com and entry_id: 1773e0b30e695f50c3c8e57add149782, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/alexa_media/media_player.py, line 188: config_entry.async_create_task(, please create a bug report at https://github.com/alandtse/alexa_media_player/issues
2024-07-05 07:45:00.459 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args ('/usr/local/lib/python3.12/site-packages/pytz/zoneinfo/Africa/Abidjan', 'rb') inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/sensor.py, line 450: timezone = pytz.timezone( (offender: /usr/local/lib/python3.12/site-packages/pytz/__init__.py, line 108: return open(filename, 'rb')), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 190, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2118, in async_forward_entry_setup
result = await self._async_forward_entry_setup(entry, domain, True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2152, in _async_forward_entry_setup
await entry.async_setup(self.hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 586, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 130, in async_setup_entry
return await component.async_setup_entry(entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 195, in async_setup_entry
return await self._platforms[key].async_setup_entry(config_entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 331, in async_setup_entry
return await self._async_setup_platform(async_create_setup_awaitable)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 361, in _async_setup_platform
awaitable = create_eager_task(awaitable, loop=hass.loop)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 37, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File "/config/custom_components/alexa_media/sensor.py", line 162, in async_setup_entry
return await async_setup_platform(
File "/config/custom_components/alexa_media/sensor.py", line 151, in async_setup_platform
return await add_devices(
File "/config/custom_components/alexa_media/helpers.py", line 53, in add_devices
add_devices_callback(devices, False)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 513, in _async_schedule_add_entities_for_entry
task = self.config_entry.async_create_task(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1126, in async_create_task
task = hass.async_create_task_internal(
File "/usr/src/homeassistant/homeassistant/core.py", line 830, in async_create_task_internal
task = create_eager_task(target, name=name, loop=self.loop)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 647, in async_add_entities
await add_func(coros, entities, timeout)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 598, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 912, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1361, in add_to_platform_finish
await self.async_added_to_hass()
File "/config/custom_components/alexa_media/sensor.py", line 541, in async_added_to_hass
self._process_raw_notifications()
File "/config/custom_components/alexa_media/sensor.py", line 382, in _process_raw_notifications
list(map(self._fix_alarm_date_time, self._n_dict.items()))
File "/config/custom_components/alexa_media/sensor.py", line 450, in _fix_alarm_date_time
2024-07-05 07:45:03.201 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration alexa_media with title: [email protected] - amazon.com and entry_id: 1773e0b30e695f50c3c8e57add149782, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
Stack (most recent call last):
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2122, in async_forward_entry_setup
_report_non_awaited_platform_forwards(entry, "async_forward_entry_setup")
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1175, in _report_non_awaited_platform_forwards
report(
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 151, in report
_LOGGER.warning(msg, stack_info=True)
2024-07-05 07:45:03.214 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration alexa_media with title: [email protected] - amazon.com and entry_id: 1773e0b30e695f50c3c8e57add149782, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-07-05 07:45:03.223 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration alexa_media with title: [email protected] - amazon.com and entry_id: 1773e0b30e695f50c3c8e57add149782, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-07-05 07:45:03.225 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration alexa_media with title: [email protected] - amazon.com and entry_id: 1773e0b30e695f50c3c8e57add149782, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-07-05 07:45:03.295 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'
2024-07-05 07:45:03.345 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
2024-07-05 07:45:03.401 ERROR (MainThread) [homeassistant.components.command_line.utils] Command failed (with return code 1): OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'
All those stack traces are from alexa media player, you should update the integration.
As for command_line, your commands are all failing. I’d start by fixing the commands outside HA, then apply the fixes in HA.
Just installed the July 5 update. My Tapo P100’s are working again after a power cycle.
Thank you!
Edit:
They quit working after an hour or so.
I don’t know why pyLoad gets a platinum rating for the perfect integration. I can’t get it installed and the documentation is just very poor:angry:![]()
I updated alexa media payer and got rid of those errors.
I tried executing the curl command on another raspberry pi and got good results.
The failing curl version on homeassistant is 8.7.1
The working curl version on a non-homeassistant is 7.88.1
~ # curl -V
curl 8.7.1 (aarch64-alpine-linux-musl) libcurl/8.7.1 OpenSSL/3.3.0 zlib/1.3.1 brotli/1.1.0 zstd/1.5.6 c-ares/1.28.1 libidn2/2.3.7 libpsl/0.21.5 nghttp2/1.62.0
Release-Date: 2024-03-27
Protocols: dict file ftp ftps gopher gophers http https imap imaps ipfs ipns mqtt pop3 pop3s rtsp smb smbs smtp smtps telnet tftp ws wss
Features: alt-svc AsynchDNS brotli HSTS HTTP2 HTTPS-proxy IDN IPv6 Largefile libz NTLM PSL SSL threadsafe TLS-SRP UnixSockets zstd
Here is the good result of fetching data from the smart meter via a non homeassistant raspberry pi
the working curl version on raspberry pi is 7.88.1
the failing curl version on homeassistant is 8.7.1
I also provided a curl --trace troublshoot log of the failing homeassistant below.
wptracy@Rpi5-1-logitechmediaserver:~ $ OPENSSL_CONF=/home/wptracy/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /home/wptracy/xcelcerts/myown/cert.pem --key /home/wptracy/xcelcerts/myown/key.pem
<Reading
xmlns="urn:ieee:std:2030.5:ns"
href="/upt/1/mr/2/r">
<qualityFlags>01</qualityFlags>
<timePeriod>
<duration>1</duration>
<start>1720205348</start>
</timePeriod>
<value>5496602</value>
</Reading>
wptracy@Rpi5-1-logitechmediaserver:~ $ curl -V
curl 7.88.1 (aarch64-unknown-linux-gnu) libcurl/7.88.1 OpenSSL/3.0.13 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh2/1.10.0 nghttp2/1.52.0 librtmp/2.3 OpenLDAP/2.5.13
Release-Date: 2023-02-20, security patched: 7.88.1-10+deb12u6
Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: alt-svc AsynchDNS brotli GSS-API HSTS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL threadsafe TLS-SRP UnixSockets zstd
curl with --trace troubleshoot log
# cat troubleshoot
== Info: Trying 10.0.0.226:8081...
== Info: Connected to 10.0.0.226 (10.0.0.226) port 8081
== Info: ALPN: curl offers h2,http/1.1
== Info: Cipher selection: ECDHE-ECDSA-AES128-CCM8
=> Send SSL data, 5 bytes (0x5)
0000: 16 03 01 02 00 .....
== Info: TLSv1.3 (OUT), TLS handshake, Client hello (1):
=> Send SSL data, 512 bytes (0x200)
0000: 01 00 01 fc 03 03 57 1f 57 e7 62 be e2 6b eb 1f ......W.W.b..k..
0010: d4 f4 e4 3a 7f 2b 8a f7 0e c5 c5 46 99 2f 4d 5a ...:.+.....F./MZ
0020: d4 34 c9 15 d5 03 20 c2 57 c0 c2 a8 a2 6c d3 60 .4.... .W....l.`
0030: 40 3d 03 e7 53 05 b1 a8 8c 90 97 f2 34 19 f4 9d @=..S.......4...
0040: 47 1d 61 51 48 c9 02 00 08 13 02 13 03 13 01 00 G.aQH...........
0050: ff 01 00 01 ab 00 0b 00 04 03 00 01 02 00 0a 00 ................
0060: 16 00 14 00 1d 00 17 00 1e 00 19 00 18 01 00 01 ................
0070: 01 01 02 01 03 01 04 00 10 00 0e 00 0c 02 68 32 ..............h2
0080: 08 68 74 74 70 2f 31 2e 31 00 16 00 00 00 17 00 .http/1.1.......
0090: 00 00 31 00 00 00 0d 00 30 00 2e 04 03 05 03 06 ..1.....0.......
00a0: 03 08 07 08 08 08 1a 08 1b 08 1c 08 09 08 0a 08 ................
00b0: 0b 08 04 08 05 08 06 04 01 05 01 06 01 03 03 03 ................
00c0: 01 03 02 04 02 05 02 06 02 00 2b 00 05 04 03 04 ..........+.....
00d0: 03 03 00 2d 00 02 01 01 00 33 00 26 00 24 00 1d ...-.....3.&.$..
00e0: 00 20 b9 3c 70 5e bc c2 11 fa f7 e3 df 3e 12 d3 . .<p^.......>..
00f0: 78 11 b9 fe b4 9b 67 f9 bf 47 3a 8a 4e a6 34 04 x.....g..G:.N.4.
0100: 27 42 00 15 00 fa 00 00 00 00 00 00 00 00 00 00 'B..............
0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
<= Recv SSL data, 5 bytes (0x5)
0000: 15 03 03 00 02 .....
== Info: TLSv1.3 (IN), TLS alert, handshake failure (552):
<= Recv SSL data, 2 bytes (0x2)
0000: 02 28 .(
== Info: OpenSSL/3.3.0: error:0A000410:SSL routines::ssl/tls alert handshake failure
== Info: Closing connection
newCert #
Here is the curl --trace on the working non homeassistànt raspberry pi.
wptracy@Rpi5-1-logitechmediaserver:~/xcelcerts $ OPENSSL_CONF=/home/wptracy/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --trace troubleshoot --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /home/wptracy/xcelcerts/myown/cert.pem --key /home/wptracy/xcelcerts/myown/key.pem
<Reading
href="/upt/1/mr/1/r">
<timePeriod>
<start>1720207911</start>
</timePeriod>
<value>-4122</value>
</Reading>
wptracy@Rpi5-1-logitechmediaserver:~/xcelcerts $ cat troubleshoot
== Info: Connected to 10.0.0.226 (10.0.0.226) port 8081 (#0)
== Info: ALPN: offers h2,http/1.1
0000: 01 00 01 fc 03 03 b6 96 4a 82 9d 37 bb 82 1e b9 ........J..7....
0010: a9 b5 11 9f 1a 8d a9 b7 e7 62 2c 3f dd 8c 5e 38 .........b,?..^8
0020: ee 43 9f 03 e0 7e 20 c6 eb 70 b0 5b b8 41 24 f1 .C...~ ..p.[.A$.
0030: 62 02 ff 6e a6 2f e8 3f 36 1f f5 65 be 8d 58 5d b..n./.?6..e..X]
0040: ef 3d c5 57 df 46 94 00 0a 13 02 13 03 13 01 c0 .=.W.F..........
0050: ae 00 ff 01 00 01 a9 00 0b 00 04 03 00 01 02 00 ................
0060: 0a 00 16 00 14 00 1d 00 17 00 1e 00 19 00 18 01 ................
0070: 00 01 01 01 02 01 03 01 04 00 10 00 0e 00 0c 02 ................
0080: 68 32 08 68 74 74 70 2f 31 2e 31 00 16 00 00 00 h2.http/1.1.....
0090: 17 00 00 00 31 00 00 00 0d 00 2a 00 28 04 03 05 ....1.....*.(...
00a0: 03 06 03 08 07 08 08 08 09 08 0a 08 0b 08 04 08 ................
00b0: 05 08 06 04 01 05 01 06 01 03 03 03 01 03 02 04 ................
00c0: 02 05 02 06 02 00 2b 00 09 08 03 04 03 03 03 02 ......+.........
00d0: 03 01 00 2d 00 02 01 01 00 33 00 26 00 24 00 1d ...-.....3.&.$..
00e0: 00 20 81 b9 4f 73 74 25 a9 35 54 b6 a4 b0 c3 85 . ..Ost%.5T.....
00f0: 29 de d5 8a 17 1a 94 64 cb 46 6d 8f 05 3e 1d 66 )......d.Fm..>.f
0100: 38 63 00 15 00 fa 00 00 00 00 00 00 00 00 00 00 8c..............
0000: 16 03 03 08 01 .....
== Info: TLSv1.3 (IN), TLS handshake, Server hello (2):
<= Recv SSL data, 82 bytes (0x52)
0000: 02 00 00 4e 03 03 66 88 4a 27 a1 d8 29 ec 6f 79 ...N..f.J'..).oy
0010: b8 42 7c d1 d6 37 12 84 6e 87 36 11 df de 1e 5a .B|..7..n.6....Z
0020: 9a 99 3f 52 35 0f 20 c6 57 8c d3 ff ad e8 58 af ..?R5. .W.....X.
0030: 75 6f 51 46 bf 6d 9c 38 fc ee 53 b8 2d db 66 6a uoQF.m.8..S.-.fj
0040: 0f 00 c0 b3 ca 69 b5 c0 ae 00 00 06 00 0b 00 02 .....i..........
0050: 01 00 ..
== Info: TLSv1.2 (IN), TLS handshake, Certificate (11):
<= Recv SSL data, 1802 bytes (0x70a)
0000: 0b 00 07 06 00 07 03 00 01 b1 30 82 01 ad 30 82 ..........0...0.
0010: 01 54 a0 03 02 01 02 02 03 43 25 8c 30 0a 06 08 .T.......C%.0...
0020: 2a 86 48 ce 3d 04 03 02 30 44 31 0b 30 09 06 03 *.H.=...0D1.0...
0030: 55 04 06 13 02 55 53 31 0e 30 0c 06 03 55 04 0a U....US1.0...U..
0040: 0c 05 49 74 72 6f 6e 31 19 30 17 06 03 55 04 03 ..Itron1.0...U..
0050: 0c 10 49 45 45 45 20 32 30 33 30 2e 35 20 4d 49 ..IEEE 2030.5 MI
0060: 43 41 31 0a 30 08 06 03 55 04 05 13 01 37 30 20 CA1.0...U....70
0070: 17 0d 32 32 30 32 30 38 31 38 34 36 31 37 5a 18 ..220208184617Z.
0080: 0f 39 39 39 39 31 32 33 31 32 33 35 39 30 30 5a .99991231235900Z
0090: 30 00 30 59 30 13 06 07 2a 86 48 ce 3d 02 01 06 0.0Y0...*.H.=...
00a0: 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 c7 af 2d .*.H.=....B....-
00b0: 44 b3 7a 9b 31 26 42 9b 3d ad a9 5b df a5 7b 7b D.z.1&B.=..[..{{
00c0: ea 23 81 c9 7e 4b 89 53 29 ed e2 31 4a b1 0d 4e .#..~K.S)..1J..N
00d0: ff 34 06 3b b1 ea 39 49 19 6f 0a 59 8b 69 63 69 .4.;..9I.o.Y.ici
00e0: 27 35 a3 42 80 bb f8 3e 30 96 2b 18 0c a3 77 30 '5.B...>0.+...w0
00f0: 75 30 1a 06 03 55 1d 20 01 01 ff 04 10 30 0e 30 u0...U. .....0.0
0100: 0c 06 0a 2b 06 01 04 01 82 be 1c 01 01 30 0e 06 ...+.........0..
0110: 03 55 1d 0f 01 01 ff 04 04 03 02 07 80 30 13 06 .U...........0..
0120: 03 55 1d 23 04 0c 30 0a 80 08 44 56 ee 91 8e 6c .U.#..0...DV...l
0130: c6 d8 30 32 06 03 55 1d 11 01 01 ff 04 28 30 26 ..02..U......(0&
0140: a0 24 06 08 2b 06 01 05 05 07 08 04 a0 18 30 16 .$..+.........0.
0150: 06 0a 2b 06 01 04 01 81 ae 60 0c 01 04 08 00 00 ..+......`......
0160: 00 66 00 43 25 8c 30 0a 06 08 2a 86 48 ce 3d 04 .f.C%.0...*.H.=.
0170: 03 02 03 47 00 30 44 02 20 68 43 d7 b3 7a 2a 1b ...G.0D. hC..z*.
0180: f2 bc bd a2 8e d8 22 b7 a8 23 f4 49 ad f1 dd 85 ......"..#.I....
0190: b9 8f 51 e9 8a 91 06 7a 1b 02 20 6c 68 f7 ad f3 ..Q....z.. lh...
01a0: a3 0d 6f aa d8 1a d5 36 a6 47 41 5e f0 c3 ee 3b ..o....6.GA^...;
01b0: 1f 8d cb 8e f1 b5 e6 1d 15 74 ee 00 01 e7 30 82 .........t....0.
01c0: 01 e3 30 82 01 88 a0 03 02 01 02 02 01 07 30 0a ..0...........0.
01d0: 06 08 2a 86 48 ce 3d 04 03 02 30 43 31 0b 30 09 ..*.H.=...0C1.0.
01e0: 06 03 55 04 06 13 02 55 53 31 0e 30 0c 06 03 55 ..U....US1.0...U
01f0: 04 0a 0c 05 49 74 72 6f 6e 31 18 30 16 06 03 55 ....Itron1.0...U
0200: 04 03 0c 0f 49 45 45 45 20 32 30 33 30 2e 35 20 ....IEEE 2030.5
0210: 4d 43 41 31 0a 30 08 06 03 55 04 05 13 01 31 30 MCA1.0...U....10
0220: 20 17 0d 32 31 30 34 31 32 31 37 35 34 31 34 5a ..210412175414Z
0230: 18 0f 39 39 39 39 31 32 33 31 32 33 35 39 35 39 ..99991231235959
0240: 5a 30 44 31 0b 30 09 06 03 55 04 06 13 02 55 53 Z0D1.0...U....US
0250: 31 0e 30 0c 06 03 55 04 0a 0c 05 49 74 72 6f 6e 1.0...U....Itron
0260: 31 19 30 17 06 03 55 04 03 0c 10 49 45 45 45 20 1.0...U....IEEE
0270: 32 30 33 30 2e 35 20 4d 49 43 41 31 0a 30 08 06 2030.5 MICA1.0..
0280: 03 55 04 05 13 01 37 30 59 30 13 06 07 2a 86 48 .U....70Y0...*.H
0290: ce 3d 02 01 06 08 2a 86 48 ce 3d 03 01 07 03 42 .=....*.H.=....B
02a0: 00 04 be b5 cd a2 a6 41 73 6b 90 75 21 62 1d 66 .......Ask.u!b.f
02b0: 46 a7 08 01 99 77 1a 32 ea 76 f1 59 21 b7 b0 3a F....w.2.v.Y!..:
02c0: d4 ee 0a 08 15 06 b0 4b 75 ec 2e ca 1a d4 60 1a .......Ku.....`.
02d0: ce e3 07 85 74 88 4c 64 69 9c f8 0a ad 45 c9 50 ....t.Ldi....E.P
02e0: 64 c6 a3 6a 30 68 30 0e 06 03 55 1d 0f 01 01 ff d..j0h0...U.....
02f0: 04 04 03 02 02 04 30 1a 06 03 55 1d 20 01 01 ff ......0...U. ...
0300: 04 10 30 0e 30 0c 06 0a 2b 06 01 04 01 82 be 1c ..0.0...+.......
0310: 01 01 30 12 06 03 55 1d 13 01 01 ff 04 08 30 06 ..0...U.......0.
0320: 01 01 ff 02 01 00 30 11 06 03 55 1d 0e 04 0a 04 ......0...U.....
0330: 08 44 56 ee 91 8e 6c c6 d8 30 13 06 03 55 1d 23 .DV...l..0...U.#
0340: 04 0c 30 0a 80 08 4b 45 f8 24 df 63 5f 38 30 0a ..0...KE.$.c_80.
0350: 06 08 2a 86 48 ce 3d 04 03 02 03 49 00 30 46 02 ..*.H.=....I.0F.
0360: 21 00 a3 83 3f 04 4f 53 06 75 5f fe db a6 ff 46 !...?.OS.u_....F
0370: b8 b3 e4 a6 a9 44 6a 84 9d 1a ae af d6 1e 77 fd .....Dj.......w.
0380: f4 4c 02 21 00 9a a7 d7 56 66 89 f6 46 e2 b5 07 .L.!....Vf..F...
0390: 3c d7 5b 79 bd bd 1f 54 b2 9f d7 97 6b b2 e4 65 <.[y...T....k..e
03a0: 70 fb 1b 17 72 00 01 c7 30 82 01 c3 30 82 01 69 p...r...0...0..i
03b0: a0 03 02 01 02 02 01 01 30 0a 06 08 2a 86 48 ce ........0...*.H.
03c0: 3d 04 03 02 30 2b 31 0e 30 0c 06 03 55 04 0a 0c =...0+1.0...U...
03d0: 05 49 74 72 6f 6e 31 19 30 17 06 03 55 04 03 0c .Itron1.0...U...
03e0: 10 49 45 45 45 20 32 30 33 30 2e 35 20 52 6f 6f .IEEE 2030.5 Roo
03f0: 74 30 20 17 0d 32 30 31 30 31 36 32 31 34 37 32 t0 ..20101621472
0400: 36 5a 18 0f 39 39 39 39 31 32 33 31 32 33 35 39 6Z..999912312359
0410: 35 39 5a 30 43 31 0b 30 09 06 03 55 04 06 13 02 59Z0C1.0...U....
0420: 55 53 31 0e 30 0c 06 03 55 04 0a 0c 05 49 74 72 US1.0...U....Itr
0430: 6f 6e 31 18 30 16 06 03 55 04 03 0c 0f 49 45 45 on1.0...U....IEE
0440: 45 20 32 30 33 30 2e 35 20 4d 43 41 31 0a 30 08 E 2030.5 MCA1.0.
0450: 06 03 55 04 05 13 01 31 30 59 30 13 06 07 2a 86 ..U....10Y0...*.
0460: 48 ce 3d 02 01 06 08 2a 86 48 ce 3d 03 01 07 03 H.=....*.H.=....
0470: 42 00 04 22 bd 6b 3f 25 cb 0f 05 7c 41 66 b9 b7 B..".k?%...|Af..
0480: c2 af 16 83 1a db 20 ca 7e d2 48 1a 13 46 1b 9e ...... .~.H..F..
0490: 07 d3 cd d8 e0 52 b4 eb 5c 0c f9 70 30 ab 41 00 .....R..\..p0.A.
04a0: e0 df d8 37 b9 1f 7f 4b 33 81 5b 9e f8 7d 50 bd ...7...K3.[..}P.
04b0: 75 31 41 a3 64 30 62 30 0e 06 03 55 1d 0f 01 01 u1A.d0b0...U....
04c0: ff 04 04 03 02 01 06 30 14 06 03 55 1d 20 01 01 .......0...U. ..
04d0: ff 04 0a 30 08 30 06 06 04 55 1d 20 00 30 12 06 ...0.0...U. .0..
04e0: 03 55 1d 13 01 01 ff 04 08 30 06 01 01 ff 02 01 .U.......0......
04f0: 01 30 11 06 03 55 1d 0e 04 0a 04 08 4b 45 f8 24 .0...U......KE.$
0500: df 63 5f 38 30 13 06 03 55 1d 23 04 0c 30 0a 80 .c_80...U.#..0..
0510: 08 4e 04 ef c2 4a b2 aa e7 30 0a 06 08 2a 86 48 .N...J...0...*.H
0520: ce 3d 04 03 02 03 48 00 30 45 02 21 00 9d d3 02 .=....H.0E.!....
0530: fb 00 e7 e4 42 f9 04 43 48 fd 24 74 4a 79 62 9b ....B..CH.$tJyb.
0540: 6c 6b 99 62 42 2b 11 59 ca a8 31 ce 79 02 20 1f lk.bB+.Y..1.y. .
0550: 3e 66 fe 45 14 2e b6 f2 9a 0e 41 c4 b7 33 6e d4 >f.E......A..3n.
0560: 87 dd 04 e0 2d b6 02 84 0d a1 3b c9 ce 7c 8b 00 ....-.....;..|..
0570: 01 98 30 82 01 94 30 82 01 39 a0 03 02 01 02 02 ..0...0..9......
0580: 01 01 30 0a 06 08 2a 86 48 ce 3d 04 03 02 30 2b ..0...*.H.=...0+
0590: 31 0e 30 0c 06 03 55 04 0a 0c 05 49 74 72 6f 6e 1.0...U....Itron
05a0: 31 19 30 17 06 03 55 04 03 0c 10 49 45 45 45 20 1.0...U....IEEE
05b0: 32 30 33 30 2e 35 20 52 6f 6f 74 30 20 17 0d 32 2030.5 Root0 ..2
05c0: 30 31 30 31 36 32 31 32 34 34 38 5a 18 0f 39 39 01016212448Z..99
05d0: 39 39 31 32 33 31 32 33 35 39 35 39 5a 30 2b 31 991231235959Z0+1
05e0: 0e 30 0c 06 03 55 04 0a 0c 05 49 74 72 6f 6e 31 .0...U....Itron1
05f0: 19 30 17 06 03 55 04 03 0c 10 49 45 45 45 20 32 .0...U....IEEE 2
0600: 30 33 30 2e 35 20 52 6f 6f 74 30 59 30 13 06 07 030.5 Root0Y0...
0610: 2a 86 48 ce 3d 02 01 06 08 2a 86 48 ce 3d 03 01 *.H.=....*.H.=..
0620: 07 03 42 00 04 69 80 38 13 42 17 39 ce 80 13 90 ..B..i.8.B.9....
0630: 0b 3d 51 66 d3 f6 e4 5a bb a1 84 6f 54 7f d6 23 .=Qf...Z...oT..#
0640: c6 2e 4f 87 00 03 b2 02 ed d2 90 a1 d3 c1 51 a0 ..O...........Q.
0650: cd 43 e5 ef 73 fd 28 c1 fd 64 3e 27 48 84 39 a3 .C..s.(..d>'H.9.
0660: 6a 89 32 9b ae a3 4c 30 4a 30 0e 06 03 55 1d 0f j.2...L0J0...U..
0670: 01 01 ff 04 04 03 02 01 06 30 14 06 03 55 1d 20 .........0...U.
0680: 01 01 ff 04 0a 30 08 30 06 06 04 55 1d 20 00 30 .....0.0...U. .0
0690: 0f 06 03 55 1d 13 01 01 ff 04 05 30 03 01 01 ff ...U.......0....
06a0: 30 11 06 03 55 1d 0e 04 0a 04 08 4e 04 ef c2 4a 0...U......N...J
06b0: b2 aa e7 30 0a 06 08 2a 86 48 ce 3d 04 03 02 03 ...0...*.H.=....
06c0: 49 00 30 46 02 21 00 b8 42 eb ab c0 bc fc 37 75 I.0F.!..B.....7u
06d0: 69 f2 f4 09 79 3a d7 4d 22 a9 96 0b 56 da 8f 86 i...y:.M"...V...
06e0: 2e 95 33 6f 0b 76 6b 02 21 00 f1 ca 01 91 24 dd ..3o.vk.!.....$.
06f0: de 1c e7 92 ac 6f f0 08 5f 0a c6 c2 ca db b0 3e .....o.._......>
0700: f9 5a 67 ca 5f d0 e3 39 ce b4 .Zg._..9..
== Info: TLSv1.2 (IN), TLS handshake, Server key exchange (12):
<= Recv SSL data, 149 bytes (0x95)
0000: 0c 00 00 91 03 00 17 41 04 07 9a 48 ba f8 83 ee .......A...H....
0010: 20 ec d9 cb a3 ad 20 ba f5 e0 d6 24 3f 6c 09 7d ..... ....$?l.}
0020: a0 06 6d b3 66 96 69 fd b5 08 7c 2d 55 cd e3 20 ..m.f.i...|-U..
0030: 8f d1 49 05 37 ab ed a8 09 a1 05 f5 0f bf 98 be ..I.7...........
0040: 84 66 de b1 4c db ee 5a 59 04 03 00 48 30 46 02 .f..L..ZY...H0F.
0050: 21 00 ba 2d 60 62 98 48 e3 55 69 11 c4 52 b1 e3 !..-`b.H.Ui..R..
0060: 0b df fb e9 ed 89 2e b2 e9 4b 08 12 ee 8f 7f 88 .........K......
0070: 1e 5a 02 21 00 c1 2a 58 8a 5e 50 8c ec 48 45 06 .Z.!..*X.^P..HE.
0080: 33 03 2e 09 b3 21 fd 28 5f 75 d1 66 69 da 5e ff 3....!.(_u.fi.^.
0090: ae 14 40 ba ff ..@..
== Info: TLSv1.2 (IN), TLS handshake, Request CERT (13):
<= Recv SSL data, 12 bytes (0xc)
0000: 0d 00 00 08 01 40 00 02 04 03 00 00 .....@......
== Info: TLSv1.2 (IN), TLS handshake, Server finished (14):
<= Recv SSL data, 4 bytes (0x4)
0000: 0e 00 00 00 ....
0000: 16 03 03 01 cd .....
== Info: TLSv1.2 (OUT), TLS handshake, Certificate (11):
=> Send SSL data, 461 bytes (0x1cd)
0000: 0b 00 01 c9 00 01 c6 00 01 c3 30 82 01 bf 30 82 ..........0...0.
0010: 01 65 a0 03 02 01 02 02 14 5f c3 dc 6c 75 05 a2 .e......._..lu..
0020: 21 81 7b 78 17 70 20 62 dc 4c ea b0 f3 30 0a 06 !.{x.p b.L...0..
0030: 08 2a 86 48 ce 3d 04 03 02 30 1f 31 1d 30 1b 06 .*.H.=...0.1.0..
0040: 03 55 04 03 0c 14 4d 65 74 65 72 52 65 61 64 65 .U....MeterReade
0050: 72 48 61 6e 43 6c 69 65 6e 74 30 1e 17 0d 32 33 rHanClient0...23
0060: 30 32 31 33 31 36 30 35 33 35 5a 17 0d 32 36 30 0213160535Z..260
0070: 32 31 31 31 36 30 35 33 35 5a 30 1f 31 1d 30 1b 211160535Z0.1.0.
0080: 06 03 55 04 03 0c 14 4d 65 74 65 72 52 65 61 64 ..U....MeterRead
0090: 65 72 48 61 6e 43 6c 69 65 6e 74 30 59 30 13 06 erHanClient0Y0..
00a0: 07 2a 86 48 ce 3d 02 01 06 08 2a 86 48 ce 3d 03 .*.H.=....*.H.=.
00b0: 01 07 03 42 00 04 99 a8 ba 47 45 9a 7c 73 59 73 ...B.....GE.|sYs
00c0: 70 99 1f e7 27 18 c9 69 62 29 f8 39 89 e0 17 c9 p...'..ib).9....
00d0: 45 22 7c 12 b4 b1 70 59 2d 36 37 d2 31 b1 7b ff E"|...pY-67.1.{.
00e0: df be ca 87 cd b6 6e 68 a6 3d 2a 37 a7 34 a2 12 ......nh.=*7.4..
00f0: 9e 27 3f af 1d 60 a3 7f 30 7d 30 1d 06 03 55 1d .'?..`..0}0...U.
0100: 0e 04 16 04 14 5d ad c5 d0 1d 2b 35 46 55 eb 16 .....]....+5FU..
0110: 56 b4 d4 37 9b 8a 6c 2c b9 30 1f 06 03 55 1d 23 V..7..l,.0...U.#
0120: 04 18 30 16 80 14 5d ad c5 d0 1d 2b 35 46 55 eb ..0...]....+5FU.
0130: 16 56 b4 d4 37 9b 8a 6c 2c b9 30 0f 06 03 55 1d .V..7..l,.0...U.
0140: 13 01 01 ff 04 05 30 03 01 01 ff 30 1a 06 03 55 ......0....0...U
0150: 1d 20 01 01 ff 04 10 30 0e 30 0c 06 0a 2b 06 01 . .....0.0...+..
0160: 04 01 82 be 1c 02 02 30 0e 06 03 55 1d 0f 01 01 .......0...U....
0170: ff 04 04 03 02 07 80 30 0a 06 08 2a 86 48 ce 3d .......0...*.H.=
0180: 04 03 02 03 48 00 30 45 02 20 44 2d a3 25 da e1 ....H.0E. D-.%..
0190: 39 3b 6f 8a b3 d9 18 85 f6 c9 51 6e 30 38 c5 9a 9;o.......Qn08..
01a0: 30 eb b4 fb df 47 4d 25 16 b1 02 21 00 90 8c ec 0....GM%...!....
01b0: a2 3d 35 2b f2 f9 b9 a2 cd 16 b1 e9 70 20 a1 09 .=5+........p ..
01c0: 15 c4 0d 2f 62 4b fd 77 1e 90 a9 bc 87 .../bK.w.....
0000: 16 03 03 00 46 ....F
== Info: TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
=> Send SSL data, 70 bytes (0x46)
0000: 10 00 00 42 41 04 55 43 10 d6 91 e5 e2 0c 7a 65 ...BA.UC......ze
0010: 42 89 d9 ea 1a 83 3d ce 58 7f f9 00 12 93 19 96 B.....=.X.......
0020: 3e 23 9a da 6b 8d ce aa c0 92 c0 27 e4 a2 35 cf >#..k......'..5.
0030: 15 b0 56 25 f2 fd 4e be c0 31 9b 62 ec e3 ca e3 ..V%..N..1.b....
0040: 93 75 9a 6f 71 c4 .u.oq.
0000: 16 03 03 00 50 ....P
== Info: TLSv1.2 (OUT), TLS handshake, CERT verify (15):
=> Send SSL data, 80 bytes (0x50)
0000: 0f 00 00 4c 04 03 00 48 30 46 02 21 00 ab b5 ae ...L...H0F.!....
0010: ee 90 bd f9 38 ee 55 af 4a 17 4c 61 69 28 44 4a ....8.U.J.Lai(DJ
0020: 64 48 49 ad 65 83 de b3 d5 19 8b bf 83 02 21 00 dHI.e.........!.
0030: c7 d8 56 8e 81 ce 12 2b a7 14 7e e8 73 6e 44 8c ..V....+..~.snD.
0040: f1 a7 e5 5c 3a 25 0c 17 d7 22 68 a8 e1 ca d9 2e ...\:%..."h.....
0000: 14 03 03 00 01 .....
== Info: TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
=> Send SSL data, 1 bytes (0x1)
0000: 01 .
0000: 16 03 03 00 20 ....
== Info: TLSv1.2 (OUT), TLS handshake, Finished (20):
=> Send SSL data, 16 bytes (0x10)
0000: 14 00 00 0c 0b 0f 82 7b 9a 73 fd b8 55 bc 93 49 .......{.s..U..I
== Info: TLSv1.2 (IN), TLS handshake, Finished (20):
<= Recv SSL data, 16 bytes (0x10)
0000: 14 00 00 0c fa 9a ed 8c 7b b0 ff 20 8d 4b 57 28 ........{.. .KW(
== Info: SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-CCM8
== Info: ALPN: server did not agree on a protocol. Uses default.
== Info: Server certificate:
== Info: subject: [NONE]
== Info: start date: Feb 8 18:46:17 2022 GMT
== Info: expire date: Dec 31 23:59:00 9999 GMT
== Info: issuer: C=US; O=Itron; CN=IEEE 2030.5 MICA; serialNumber=7
== Info: SSL certificate verify result: self-signed certificate in certificate chain (19), continuing anyway.
== Info: using HTTP/1.x
0000: 17 03 03 00 6b ....k
=> Send header, 91 bytes (0x5b)
0000: 47 45 54 20 2f 75 70 74 2f 31 2f 6d 72 2f 31 2f GET /upt/1/mr/1/
0010: 72 20 48 54 54 50 2f 31 2e 31 0d 0a 48 6f 73 74 r HTTP/1.1..Host
0020: 3a 20 31 30 2e 30 2e 30 2e 32 32 36 3a 38 30 38 : 10.0.0.226:808
0030: 31 0d 0a 55 73 65 72 2d 41 67 65 6e 74 3a 20 63 1..User-Agent: c
0040: 75 72 6c 2f 37 2e 38 38 2e 31 0d 0a 41 63 63 65 url/7.88.1..Acce
0050: 70 74 3a 20 2a 2f 2a 0d 0a 0d 0a pt: */*....
0000: 17 03 03 01 7e ....~
<= Recv header, 17 bytes (0x11)
0000: 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d HTTP/1.1 200 OK.
0010: 0a .
<= Recv header, 37 bytes (0x25)
0000: 44 61 74 65 3a 20 46 72 69 2c 20 30 35 20 4a 75 Date: Fri, 05 Ju
0010: 6c 20 32 30 32 34 20 31 39 3a 33 31 3a 35 31 20 l 2024 19:31:51
0020: 47 4d 54 0d 0a GMT..
<= Recv header, 21 bytes (0x15)
0000: 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 Content-Length:
0010: 32 35 34 0d 0a 254..
<= Recv header, 35 bytes (0x23)
0000: 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 Content-Type: ap
0010: 70 6c 69 63 61 74 69 6f 6e 2f 73 65 70 2b 78 6d plication/sep+xm
0020: 6c 0d 0a l..
<= Recv header, 2 bytes (0x2)
0000: 0d 0a ..
<= Recv data, 254 bytes (0xfe)
0000: 3c 52 65 61 64 69 6e 67 0d 0a 20 20 20 20 20 78 <Reading.. x
0010: 6d 6c 6e 73 3d 22 75 72 6e 3a 69 65 65 65 3a 73 mlns="urn:ieee:s
0020: 74 64 3a 32 30 33 30 2e 35 3a 6e 73 22 0d 0a 20 td:2030.5:ns"..
0030: 20 20 20 20 68 72 65 66 3d 22 2f 75 70 74 2f 31 href="/upt/1
0040: 2f 6d 72 2f 31 2f 72 22 3e 0d 0a 20 20 20 20 3c /mr/1/r">.. <
0050: 71 75 61 6c 69 74 79 46 6c 61 67 73 3e 30 31 3c qualityFlags>01<
0060: 2f 71 75 61 6c 69 74 79 46 6c 61 67 73 3e 0d 0a /qualityFlags>..
0070: 20 20 20 20 3c 74 69 6d 65 50 65 72 69 6f 64 3e <timePeriod>
0080: 0d 0a 20 20 20 20 20 20 20 20 3c 64 75 72 61 74 .. <durat
0090: 69 6f 6e 3e 31 3c 2f 64 75 72 61 74 69 6f 6e 3e ion>1</duration>
00a0: 0d 0a 20 20 20 20 20 20 20 20 3c 73 74 61 72 74 .. <start
00b0: 3e 31 37 32 30 32 30 37 39 31 31 3c 2f 73 74 61 >1720207911</sta
00c0: 72 74 3e 0d 0a 20 20 20 20 3c 2f 74 69 6d 65 50 rt>.. </timeP
00d0: 65 72 69 6f 64 3e 0d 0a 20 20 20 20 3c 76 61 6c eriod>.. <val
00e0: 75 65 3e 2d 34 31 32 32 3c 2f 76 61 6c 75 65 3e ue>-4122</value>
00f0: 0d 0a 3c 2f 52 65 61 64 69 6e 67 3e 0d 0a ..</Reading>..
== Info: Connection #0 to host 10.0.0.226 left intact
homeassistant and non-homeassistant openssl and curl versions:
non homeassistant (the working system):
wptracy@Rpi5-1-logitechmediaserver:~/xcelcerts/myown $ openssl version
OpenSSL 3.0.13 30 Jan 2024 (Library: OpenSSL 3.0.13 30 Jan 2024)
wptracy@Rpi5-1-logitechmediaserver:~/xcelcerts/myown $ curl -V
homeassistant core 2024.7 (the non-working system)
System information
IPv4 addresses for end0: 10.0.0.10/24
IPv6 addresses for end0: 2601:282:1900:3a50::3b86/128, 2601:282:1900:3a50:5032:4688:fa59:a573/64, fe80::a393:263c:2785:789/64
IPv4 addresses for wlan0:
OS Version: Home Assistant OS 12.3
Home Assistant Core: 2024.7.0
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
~ # openssl version
OpenSSL 3.3.0 9 Apr 2024 (Library: OpenSSL 3.3.0 9 Apr 2024)
~ # curl -V
Fantastic that we now can resize cards but I together with several people want to be able to resize the sections as well. Trying to squeeze it in with screen size of 1024x600 (Google Nest Hub) is very important. Now the sections just stay the same and its just whitespace so actually the resize of card doesn’t solve the real problem in my opinion. Would it be possible to be able to set grid-section-min-width to something else than 320px and not have it static?
good suggestion, you should add it to the feature request section if its not there already.
I’ve been seeing what seems to be the same issue - in my case, long-term statistics seem to stop updating shortly after 4am local time (NZST); this has happened two days in a row. The recorder still seems to be capturing all the data - just no statistics are being generated during this period, so anything that pulls data from long-term statistics stops seeing any updates. Restarting HA makes it start working again - but it doesn’t fill in the gap at all, so there can end up being a big jump at the time of the restart (the energy dashboard shows all the “missed” usage lumped into the hour in which I restarted HA).
I see 2024.7.1 has been released; nothing in the release notes stood out as a potential fix for this issue, but I’ve installed it - so I guess we’ll see if that makes any difference.
I couldn’t see anything relevant in the logs around the time that statistics stopped updating, so if it still happens on 2024.7.1 I’ll investigate cranking up the log verbosity for the recorder, statistics and any other relevant component.
Good to see that generic thermostat can now be set up as a helper in the UI, but why does it only allow you to select a switch entity as the actuator and not a fan, whereas it is possible to configure a generic thermostat with a fan via YAML?
I can confirm that updating to 2024.7.1 won’t fix the issue, it just happened again. Third day in a row, at around 4AM the CPU usage jumps from 1% to 15% and graphs stop updating.
Easy, so before the change the integration created switches for each activity, and it was easy to add them as buttons for use on touch screens and do what you wanted. It also meant that I could add only the activities I wanted to particular dashboards, with this change and select, I now have a drop down box that doesn’t work all that well on touchscreens and also shows all activities which is not what I want. Also it was very easy to use in scenes and to expose the switch entities to say Google for voice activation, now, not so much.
For example, I have 8 activities and on my media dashboard I only display (as buttons) the 5 that are relevant. I could also simply expose the activities I wanted to Google to turn on and off with voice. Now to work with Google again for every activity I must create switches and automations for something that before this, just worked.
Now to get back to how I want, with a simple button to start a activity or to have Google respond when I want to start a activity via voice, then I have to create a template switches, scripts/automation and input booleans, in YAML mostly. Because of this change, now I have to create remote.turn_on service calls, select service calls or create templates switches instead of a switch the integration already was making and was working. How has this made anything easier for anyone? It’s a massive backwards step in useability.
Before I could just add a button or expose that said switch to Google or plonk it on my dashboard through the UI. As I said, it has now made useability terrible for no apparent reason other than someone wanted to remove to switch code because " we don’t need multiple ways to switch activities"… Well I did…
Below is some discussions on how much work this has now (and since this change was announced) created when before this the switches were created automatically. It’s gone from a basic task to now be a right royal pain.
And I am not the only one:
The Logitech Harmony switch platform is being removed : r/homeassistant (reddit.com)
Deprecated Harmony Switch platform? What?! Please help : r/homeassistant (reddit.com)
#BringBackTheSwitches
You don’t have to do any of that for the buttons.
Use the button tap action to select the option in the select entity you want. Done.
type: button
show_name: true
show_icon: true
tap_action:
action: call-service
service: select.select_option
entity_id: select.activity_mode
option: Mode One
entity: select.activity_mode
type: button
show_name: true
show_icon: true
tap_action:
option: Mode Two
Change the data/option and name for each of the other buttons.
This can all be done from the card ui.
Not sure about the Google Voice. You may need scripts for that.
Same for me and there is nothing relevant in the logs.
I dont have iclouds integration, what kind of code cause the issue ?
Is the docker image being updated ok or is version integration working as expected? I have the version integration to use docker hub stable but it is showing 2024.7.0 and not the recent 2024.7.1. I have a web site version that is showing the newer version.
If I check against Package home-assistant · GitHub and that has 2024.7.1 as stable, but homeassistant/home-assistant Tags | Docker Hub doesn’t have 2024.7.1 and stable hasn’t been updated in 3 days.
I tried 2024.7.1 and still go the qbittorrent issue so I’ve opened a new github issue on core for it - FYI this is why the sensor went missing:
2024-07-06 07:51:17.831 ERROR (MainThread) [homeassistant.components.sensor] Error adding entity sensor.qbittorrent_all_torrents for domain sensor with platform qbittorrent
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1362, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1007, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1133, in _async_write_ha_state
state, attr, capabilities, shadowed_attr = self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1068, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1013, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 533, in state
value = self.native_value
File "/usr/src/homeassistant/homeassistant/components/qbittorrent/sensor.py", line 170, in native_value
return self.entity_description.value_fn(self.coordinator)
File "/usr/src/homeassistant/homeassistant/components/qbittorrent/sensor.py", line 101, in <lambda>
value_fn=lambda coordinator: count_torrents_in_states(coordinator, []),
File "/usr/src/homeassistant/homeassistant/components/qbittorrent/sensor.py", line 181, in count_torrents_in_states
return len(torrents)
TypeError: object of type 'NoneType' has no len()
