hi, passing from 2024.7.2 to 2024.7.3 broke my zigbee2mqtt, i restored 7.2 and loose tuya login, which has btw a stupid way to re-login with a pointless qrcode (security-wise nonsense, user/pass would be normal, maybe 2fa on top). it was like the dongle was not functional (no devices detected on map scan). usually i dig, but i was in a hurryâŚ
we have a solution for this?
updated from 2024.7.2 to 7.3 and lost all of my home-feed cards. code hasnât changed. didnât see any breaking changes. havenât heard anyone else squawk about it. i did the work around for the pop-up cards but canât figure these out.
HAâs code changed â hence the upgrade. Iâm assuming you actually meant you didnât change your config.
You wonât see third party components mentioned in the release notes. Third party components are your own risk.
Make sure to include your config when you report the issue on the third party repo. Integrations have links to the applicable repos on the integrations page.
what happens to 2024.7.4? neither available via pip nor docker.
thatâs not the first time the last release of a month is not released.
I only ever update to the latest monthly version. an update to 2024.8.0 may then fix bugs from 2024.7.3, but also bring new ones. a vicious circle
patience is not the problem. this is not the first time i have seen that the latest version has not been published and i just wanted to know why this happens.
edit: it doesnât specifically refer to 2024.7.x but i remember how bugfixes only appear in the next release because the last version was not released.
BTT: why dropping the last version of a release?
just because you see a milestone that exists in github does not necessarily mean it will be published. Given the beta starts this week most likely there may not be a milestone. However looking at the open PRs it looks like it may be planned.
What do you mean âlast versionâ. There has never been a fixed number of point releases. 2024.5 went to 2024.5.5.
2024.3 went to 2024.3.3.
There is a week until 2024.8.0 release. There is in fact time to release another 2024.7.x release if it is needed. But as you donât say what bugfix is so important to you, it is hard to speak to what need you perceive.
