I rolled back to 2024.7.4 for now. Actually I thought it was broken in 2024.8.0 and fixed in .1
I think I have found the culprit. The following code will display a blank screen when saved. The if
statement when used directly under action:
will always result in a blank screen; when used under sequence:
will not result in a blank screen.
alias: New Automation
description: ''
trigger: []
condition: []
- if:
- condition: template
value_template: "{{ states('input_boolean.xxx') == 'on' }}"
then: null
mode: single
It does not matter what template
is used, as it is the if
statement which causes the issue.
I noticed that cards show the states of entity as raw data. I mean; without the unit of measure, time stamps for time entity (for sun next dawn it shows 2024-08-12T03:40:03+00:00 instead of August 12, 2024 at 5:40 AM), on/off instead of locked unlocked for locks, on/off instead of connected/disconnected for fritzbox internet connection, etcā¦
(supervisor 2024.08, core 2024.8.1)
Iāve rolled back to 2024.7 and all works fine.
Can someone help me?
Thanks for the great work
Stefano
My DB is smaller, around 9GB, but it took ~80 minutes to convert. But Iām running it on quite decent HW:
- HA as VM on ESXi (Core i9, Gen 13), 4 performance cores, 4GB of RAM
- MariaDB in docker on Synology NAS (RS2418+) and SSD Volume in RAID-0
- 10Gb link between ESX and NAS.
DB conversion is very high IOPS demanding operation, so if your DB is on normal HDD you should probably increase timing by factor of x5. CPU is less the problem in such scenario.
Is your suggestion related to this issue?
I donāt have any entities for my Yamaha because it wasnāt initialized at all.
Yes. You must have another issue.
I tired it on my DS218+ with two Samsung 8TB QVO drives.
One Core was all the time at 100% usage. Also, I guess those Drives arenāt really suitable for SQL workloadsā¦
Yes, I did read it. I changed the entity ID but the result is still the same. The only integration I added is ZHA and IRobot and with whatever_entity belongs to homeassistant I am not messing around. Itās good to know it is not an error but limitation still I am not able to update it via UI, Terminal nor VM itself. Everything freeze and the result is only killing the VM helps reboot the system. Couple or restarts did not help either. The only thing I did not try yet is changing the entity ID to something totally different like bunch of numbers or whatever nonsense characters.
Changing the entity ID wonāt help. Unique ID is a different property which can only be found by messing with the hidden storage folder.
Either way, you shouldnāt have gotten that notification for update.home_assistant_core_update
because that should be automatically generated by the system, including a unique ID which allows you to edit from the UI.
By any chance, did you define it in yaml? Can you show your configuration.yaml with any personal details & passwords masked out?
That is my configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
scripts.yaml, scenes.yaml are empty.
I donāt know anything about that themes: And there are some blueprints probably made by system for motion sensors, motion_light.yaml, notify_leaving_zone.yaml and confirmable_notification.yaml
automations.yaml
- id: '1722448417755'
alias: chodba_pohyb
description: ''
- type: motion
platform: device
device_id: 3a97b2732d5965cb4bf351df0372eabc
entity_id: 8847dbccc7403ed3a0c1d4fa2023422a
domain: binary_sensor
condition: []
- type: turn_on
device_id: da6da9f2045475a3e2dba68479a4a3d9
entity_id: 180223f81e622000f0bd8f560fb2b687
domain: light
mode: single
- id: '1722448464485'
alias: chodba_klid
description: ''
- type: no_motion
platform: device
condition: []
- type: turn_off
domain: light
mode: single
- id: '1722448851917'
alias: kuchyn_pohyb
description: ''
- type: motion
platform: device
device_id: 6c00a55febfd4921150b6fb8bd6bd9f1
entity_id: f10942b408e5112d917fb75b440aab94
condition: []
- choose:
- conditions:
- type: is_illuminance
condition: device
device_id: 0728a8c881b106ef8d1d90d8f01688f2
entity_id: 602735c498ecb9b628052e32c657c7e9
domain: sensor
below: 50
sequence:
- type: turn_on
device_id: e26fa02bd1e64642b61a387fedabdd6c
entity_id: 6804232ac54fddd31b9df02cacf08b03
domain: light
- type: turn_on
device_id: cf4caea58aefc6827a186c74d643f318
entity_id: 2d5e4260e6d9249a388be7685da20b97
domain: light
- conditions:
condition: device
domain: sensor
above: 50
sequence:
- type: turn_on
domain: light
mode: single
- id: '1722448889373'
alias: kuchyn_klid
description: ''
- type: no_motion
platform: device
condition: []
- type: turn_off
domain: light
- type: turn_off
domain: light
mode: single
- id: '1722450530275'
alias: otevrene_dvere
description: ''
- type: opened
platform: device
device_id: 90bff7249fce900fc7dd0d101c7947f7
entity_id: 1e0c86f1b8313741a9ca7f6608ede109
condition: []
- service: notify.notify
metadata: {}
title: OtevÅenĆ© dveÅe
message: NÄkdo otevÅel dveÅe
mode: single
- id: '1722464218947'
alias: loznice_svetlo
description: ''
- platform: event
event_type: ios.action_fired
event_data:
actionID: FF876831-3BB0-41C9-8D5C-BA21E0B13F1D
condition: []
- service: light.turn_on
metadata: {}
brightness_pct: 1
transition: 1
device_id:
- 0457f989248c900c1582958742e57f78
- 01a21c218f0026d3ce6bf2fd1e303d59
- delay:
hours: 1
minutes: 0
seconds: 0
milliseconds: 0
- service: light.turn_off
metadata: {}
data: {}
device_id:
mode: single
- id: '1722787881374'
alias: vypadek_proudu
description: ''
- platform: homeassistant
event: start
condition: []
metadata: {}
data: {}
entity_id: light.svetla
- service: switch.turn_off
metadata: {}
data: {}
entity_id: switch.zasuvky
- service: notify.mobile_app_telefon
metadata: {}
message: HA zapnuto
title: Reset
mode: single
- id: '1722812276975'
alias: konec_prani
description: ''
- type: no_vibration
platform: device
device_id: 6297bf3787ab4b307ab542214a51b347
entity_id: ead0b61a73e760b54aa61b3735dfc1bf
for:
hours: 0
minutes: 20
seconds: 0
condition: []
metadata: {}
message: PraÄka doprala
title: PraÄka
mode: single
- id: '1722954538293'
alias: vypnout_svetla
description: ''
- platform: zone
entity_id: person.ja
zone: zone.home
event: leave
condition: []
metadata: {}
data: {}
metadata: {}
data: {}
mode: single
- id: '1722968693641'
alias: stetka_dock
description: ''
- platform: device
device_id: 3966060ba97a2c91f48b67d969b78446
domain: vacuum
entity_id: dded4482a2b7d8ff2b5f785d1bf572c5
type: docked
condition: []
- if:
- type: is_on
condition: device
entity_id: 18b67ecd2af357226a86d806fc9e342c
then:
metadata: {}
message: Å tÄtka uklidila, vysyp jĆ koÅ”
title: Å tÄtka uklidila a mĆ” plnej koÅ”
else:
metadata: {}
entity_id:
- light.svetlo_chodba_dvere_light
- light.svetlo_kuchyn_strop_linka_light
- light.svetlo_loznice_strop_light
- light.svetlo_obyvak_strop_dvere_light
- light.svetlo_obyvak_strop_okno_light
- light.svetlo_pracovna_light
data: {}
mode: single
- id: '1722970841325'
alias: stetka_uklid
description: ''
- platform: state
entity_id:
- vacuum.stetka
to: cleaning
condition: []
metadata: {}
data: {}
entity_id:
mode: single
- id: '1723065785465'
alias: loznice_strop
description: ''
- platform: event
event_data:
actionID: 5935C980-8E8E-463A-9E7E-EC34A5B0CE52
condition: []
- type: turn_off
device_id: 0457f989248c900c1582958742e57f78
entity_id: 80d258d1c63b354ca2471f015968da58
domain: light
- type: turn_off
device_id: 01a21c218f0026d3ce6bf2fd1e303d59
entity_id: 33d6d2d3707f75239d12e4bf8748e3d6
domain: light
- type: turn_on
device_id: 3863caa0ea78ee789dde217b8ae7a64e
entity_id: 3120ebcac3b9a5a91f19cf340a29e13b
domain: light
- delay:
hours: 1
minutes: 0
seconds: 0
milliseconds: 0
- type: turn_off
domain: light
mode: single
- id: '1723285949714'
alias: stetka_zacit_vysavat
description: ''
- platform: device
device_id: c4b153833e4b4e258ca72b4df1f33017
domain: device_tracker
entity_id: 2c9bfd59ac0eba08d54505d519036d0b
type: leaves
zone: zone.home
condition: []
- service: vacuum.start
metadata: {}
data: {}
mode: single
After 2024.8.1 update, if I restart HA machine, it starts with latest 2024.7 version. Besides, I have not 2024.8 security copy, and if I have it manually, it doesnāt exist.
It is the first time I see this behaviour.
It is a known bug?
Regards
J
None. Same as Draghmar. Yamaha is not being initialized as start up. Trying with basic settings still not working.
media_player
- platform: yamaha
host: 192.168.0.188
Confirmed, then: null
line causes the blank page bug. Just change the code to not include true: null
lines.
So far everything works fine for me - with one exception: The tile-card does not properly update the status anymore.
It used to work fine and the entities still sport the proper status - but the tile card does not reflect the change from active to inactive anymore and look like the entity is active forever.
I guess thereās no way to hide the icon in badges now? The icon is taking up priceless real state, especially on mobile.
that configuration isnāt correct.
media_player:
MISSING
- platform: yamaha
host: 192.168.0.188
If you do have that in your configuration, then look in your log for errors.
The colon is there.
Not sure what happened during the copy/paste.
Log:
Logger: homeassistant.components.media_player
Source: helpers/entity_platform.py:364
integration: Media player (documentation, issues)
First occurred: August 10, 2024 at 8:47:26 PM (1 occurrences)
Last logged: August 10, 2024 at 8:47:26 PM
Error while setting up yamaha platform for media_player
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 364, in _async_setup_platform
await asyncio.shield(awaitable)
File "/usr/src/homeassistant/homeassistant/components/yamaha/media_player.py", line 167, in async_setup_platform
zone_ctrls = await hass.async_add_executor_job(_discovery, config_info)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/yamaha/media_player.py", line 136, in _discovery
for recv in rxv.find():
File "/usr/local/lib/python3.12/site-packages/rxv/__init__.py", line 19, in find
return [RXV(**ri._asdict()) for ri in ssdp.discover(timeout=timeout)]
File "/usr/local/lib/python3.12/site-packages/rxv/ssdp.py", line 72, in discover
res = rxv_details(url)
File "/usr/local/lib/python3.12/site-packages/rxv/ssdp.py", line 83, in rxv_details
res = cElementTree.XML(requests.get(location).content)
File "/usr/local/lib/python3.12/site-packages/defusedxml/common.py", line 126, in fromstring
parser.feed(text)
File "/usr/local/lib/python3.12/xml/etree/ElementTree.py", line 1706, in feed
self.parser.Parse(data, False)
ValueError: multi-byte encodings are not supported
I fear every update because Iām forced to fix stuff that worked.
Instead of a home assistant user I feel like my home assistant maintainer.
