1hr14m to complete the update this time. Definitely not a hardware issue.
No release notes section for 2025.7.3? Ah, already answered a few posts above mine.
Hm⦠this release killed my HA⦠interesting though: all was working, even sound was working (iāve got sound notifications on my speakers) except GUI - no dashboards were loaded - constant loading circle. Iāve had to use my nightly backup to restore to working condition. Second time update went fine⦠go and figureā¦
and, raw editor no-scroll is still not corrected. iāll report that to github. Itās extremely annoying.
With or without backup enabled?
Regarding time to update
Assuming (which I know it does) log.fault is created on the restart it took 3 minutes to update on a Pi5 with 8GB of RAM.
Last log entry on restart (log.1 - final write before a restart) :
2025-07-22 11:45:35.347 ERROR (MainThread) [homeassistant.components.automation.low_level_alert]
First log entry on restart (.log - first entry) :
2025-07-22 11:48:38.833 WARNING (SyncWorker_0) [homeassistant.loader]
I always backup before updating. The restart is not my problem. Restarting takes about 30seconds on my machine. I have SMB into the directories where the backups are generated and to the config folder. The backup time was the start time I use because my backups also do not take long. I have a server running nvmeās @gen4 speeds so everything is usually lightening quickā¦except random Core updates.
Never had an issue with a core update taking very long - only when I install the first beta of the month do I run a full backup and that only adds a few minutes to it.
So - if you are always backing up then the issue is either with the backup procedure and not the core update itself OR an internet issue dragging the image down from Github,.
I would like to have that privilege to only backup on the new month. I have a database file that is constantly churning (currently sitting at 6gb) and the data is critical. I used to do backups similar to what youāre doing but there was one time, all it takes is one time, where I didnāt recover from an update. Lost a lot of data and this is still with nightly backups.
I do a nightly backup. For any .x version I simply use the command line to roll back so my data is kept intact.
Unless there is a database schema change (and with that I mean a field dropped or truncated, or an index redefined - not something a .x release should contain) the command line is the quickest and safest way to roll back.
I was looking for that ācommand lineā commands today when my HA crashed⦠at the end i restored image from proxmox. But, would you mind sharing the CLI procedure?
ha core update --version x.y.z
Ohā¦sorry, i missunderstoodā¦i know this one⦠i thought that he means restore from backupā¦that is what i was looking for (from cli).
Has anyone been using the native amazon integration instead of the HACS version. how doe sit compare?
If you search on the forum there are a few comparison threads already on this thatāll prob give you a good overviewā¦
edit: for example How does the new `Alexa Device` integration differ from the existing `Alexa Media Player` integration
I couldnāt find it on GH so I created an issue for it:
Youāre looking in Core instead of Frontend. Issue was raised here YAML editor fails to focus search result when searching Ā· Issue #25437 Ā· home-assistant/frontend Ā· GitHub
dāoh didnāt realize the front end has its own repo, thanks
Can confirm this is fixed in 2025.7.3.
i have updated and now i have multiple integrations not working. the problem appears to be because for some reason HA cannot reach the internet. I can ssh into in but i cannot ping anything other than the ips in my local network.
there is this weird nameserver in /etc/resolv.conf
nameserver 172.30.32.3
if I replace that with 1.1.1.1 then i can ping google from ha, but it still doesnāt work.
To make matters worse, i try to restore from backup and that doesnāt work either:
So what can I do to get my system back?
What install type are you running?
