i hope you keep us up to date if you got it working
would be interested in that one too.
Partybug, are you actually getting the codes for the bunker hill driveway alerts? I have two of them and have been unable to capture the codes with my ESP8266 and 433mhz receiver. I am getting codes from door sensors, fire alarm, key fobs, but nothing from the driveway alerts. Can you tell me if you did anything special with them? Thanks
@Shu,
These sort of sensors typically use Manchester encoding - which is not supported by RCSwitch to my understanding.
I have multiple temperature/humidy sensors and I am using RFLink - which requires an ardiuno mega 2560.
they have a list of devices that it works with and it is under ongoing development (although not as active as home assistant!).
You can also add RFLink to your HASS server via usb and use the HASS component - or there is a RFLink to ESP8266 project that forwards all the RFLink data to MQTT for digestion by whatever you want that uses MQTT (including HASS)
@tmharris Yes, I use the bunker hill wireless alert system Item #62447. After putting batteries in the pir, I grab the code using a uno programmed with RCSwitchâs ReceiveDemo_Simple. After getting the code I enter it into HA like the other switches.
I am needing to replace my driveway unit after a year and a half of use. I replaced the batteries this winter but it has become spotty. Sometimes I donât get an alert when a car arrives then it alerts when a car is leaving. If I have to replace the unit every year, itâs still not a bad deal. (I also seal it for the outdoors with silicone sealant.)
@touliloup From the info on the item listing it does just send the temperature value.
@ReneTode I definitely will! It should arrive in the next few weeks our postal system here in South Africa is always delayed.
@phileep Great to know you have something similar working so there is hope! I am definitely going to check out those projects and keep you guys updated.
Thanks!
Well⌠im using the webserver on the esp8266 and turning on lights using the curl post command. Only problem im facing that my esp8266 randomly getting stuck (doesnt respond to ping commands and cannot connect to webpage).
I think we are going out of the topic and will make it complex to read as it should be a list of compatible devices
I followed a tutorial and could successfully communicate between my Arduino +5100 shield. I donât have ir transmitter nor receiver⌠But I receive ir signals. Is there a special setup without ir as the blog with my setup has been removed.
Would like using the old setup from @1technophile
4 euro ⌠hard to beat price, if you compare to a 50 $ zwave sensor âŚ
I wish I could fix my 433MHz receiver, still not working
Both switches work
https://www.amazon.de/gp/product/B010DFEICC/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
I use them with a Superheterodyne 3400 Wireless Receiver connected directly on my Pi3B and the rpi_rf HA module.
I also use the well known Etekcity Radio Plug Sockets
https://www.amazon.de/gp/product/B016I3TZ58/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
One question:
Has anyone found a 433Mhz light switch that also sends a signal?
I would very much like to have the correct state in HA when the light switch is triggered manually.
@fbsdmon
thank you very much for sharing these products.
Answering your question: you can use this:
https://www.itead.cc/sonoff-touch.html is not 433 working with MQTT.
You can have more information here: Flashed Sonoff Touch with ESPEasy for control via MQTT and HA
now, please
Please do not answer here about this, because this is not a topic for doubts, just to share equipment
Well, Iâll be keeping an eye on your results too! I have exactly the same idea - slightly different sensor. Good luck!
I just wanted to share my ESP8266 MQTT transmitter 433Mhz setup, which is being overtaken with the newer WiFi RFLink setup which can also control my Ikea lights over 2.4Ghz.
Photo: (https://goo.gl/photos/Npyrs4bjzw7nMYyn8)
I add the Kerui P829 motion sensor to the list ($11,88):
In normal operation you can set it up to report movement repetitively every 5 seconds or 5 minutes (will report movement immediately, but then wait 5s or 5m until re-reporting movement).
it will blink red every 3s as soon as the power pass under 2.4V and send a low voltage signal.
It also send a signal when the battery cover is opened.
You can also deactivated the red led that illuminate the detector when movement is detected. Itâs not so important for alarm but can be useful for home-automation (you can see that led ON on the first photo in the following album)
Keriu P829 user manual and photo
Another important precision: the sensor is pet immune.
The cheap remote control that can be found on Aliexpress for ~3$ also works great:
They are programmable, you can set the code transmitted by each button by making the remote learn an emitted code (Iâve used the gateway to send a code and teach it to the remote)
Here is a list of the compatible device up to now:
The list is editable if someone else want to add his own device.
Maybe to add a link to it in the first post would help to maintain visibility of the whole topic @Partybug
i exaclt have thos remotes and only biutton a and b work how did u do exaclty?
I suppose that when you press C or D it doesnât emitt light? If itâs the case they are not programmed yet. Mine came with only one or two button pre-programmed.
Here you go for some explanation:
How can i send a code from the bridge long enough to learn the code for the remote? It seems the code is sent very short
