A different take on designing a Lovelace UI
Hi @Frank_Hagenbuch, saw your dashboard, looks really cool. A little help needed, if it is possible for you. I am a complete newbie to HA. I have followed the steps in install.md. But, I can’t seem to get what to do next. How do I get matt’s dashboard and then build upon it? Really need some help here.
Hi @VietNgoc , saw your work, looks really cool. A little help needed, if it is possible for you. I am a complete newbie to HA. I have followed the steps in install.md. But, I can’t seem to get what to do next. How do I get matt’s dashboard and then build upon it? Really need some help here.
please @manishsuperhome
dont ‘spam’ the community with 3 almost identical posts for
If you’re new to the community, be welcome!
Start out by reading what is considered to be the code of conduct here.
Randomly ‘tagging’ fellows is considered to be rude and comes across as demanding help.
next, show us what you did, so we can see where you’re stranded and can push you forward
I’m trying to change the colors of my zones when seen in the history of a person. I thought adding these lines into the themes>tablet.yaml file would work but it doesn’t. When searching google, it seems like every solution I’ve found hasn’t worked.
  #Zone Colors
  state-home-color: "#7E10FF"
  state-Library-color: "#C50098"
  state-Park-color: "#00863B"
  state-Cafeteria-color: "#000DE3"
  state-Bway-color: "#543400"
  state-Dorm-color: "#0009E9"
  state-School-color: "#C50098"
State color for zones I see for the first time, I don’t even know that such a variable exists. I know there are only two default colors for person and device tracker, blue and green. Can you tell me where you found these variables? And do you use the tablet theme as a theme for the whole HA or as a separate theme for the dashboard? That’s the difference when you want to change the css for the system.
Yes, I use the tablet theme for the whole HA. ( I select it in the settings)
These colors I’ve set in my tablet.yaml file. Obviously, the names of the zones have to match.
This actually did do something to my colors but not at all what I wanted it to do. (all colors just changed but don’t match my tablet.yaml file. It’s very strange.
I followed these instructions.
Thanks Marius for the heads up. I thought I need to tag people to bring it to their attention my post, like in some other platforms. So, I tagged multiple people. Didn’t know this come off as rude. I will keep it in mind going forward thank you. As for what I have done is, I followed the steps written in install.md of matt’s github.
Then I wanted the following dashboard and further build upon it.
So, I copied the content of ui-lovelace.yaml into raw configuration editor of a new dashboard I created.
But, I got the following error
I searched around the forum and it said it is because of yaml mode.
So I opened configuration.yaml file.
I added the following code, it didn’t work.
dashboards:
    matt-tests: # Needs to contain a hyphen (-)
      mode: yaml
      filename: /homeassistant/ui-lovelace.yaml
      title: esboard
      icon: mdi:tools
      show_in_sidebar: true
      require_admin: false
changed to
 filename: config/homeassistant/ui-lovelace.yaml
but no dashboard.
changed to
  filename: ui-lovelace.yaml
still no dashboard.
I don’t know if what I messed is real basic. Real newbie at this. Please help.
not sure why your organization looks like, but you need to edit the paths to you local situation.
For me, I just edited it to be:
    ui-different-take:
      mode: yaml
      filename: dashboard/dashboards/ui-different-take.yaml
      title: Different
      icon: mdi:test-tube
      require_admin: true
This change requires the restart mentioned in the docs.
Also, be sure to have the theme installed (and updated) and select it.
Ofc, any other path needs to be corrected too. Like I my case, I edited the line to the button-card-templtes to be
button_card_templates: !include_dir_merge_named ../button_card_templates
  - type: custom:grid-layout
    title: Home
because I already have that, and this way it is just a drop in.
I believe the frontend will tell you what to do next, on missing templates etc, or even the wrong Theme :wink:
I’ll take all of this away again, hope you find your way. If not dont hesitate to get back here, as there are many other members that did install the theme, which can help you better than I can.
Good afternoon!
Since the 2024.7 HA update, my sidebar icons no longer color themselves correctly and the align-items: flex-end no longer seems to pin them to the bottom of the view. The only fix has been to remain at 2024.6.4. I was hoping someone would be able to quickly identify what needs to be changed, I am struggling with the page inspector in Chrome to determine exactly what needs to be modified. No matter how I try and reformat it, all 6 icons are picking up the modifications from “last-of-type”, where as pre 2024.7 they would all work with first-of, last-of, and nth-of selectors respectively. Appreciate any insight you have or pointing me in the right direction to figure it out myself, I am usually pretty good at figuring things out but this has stumped me for months.
This is all based off the older version of Mattias_Persson 's theme, with the sidebar icons, before he switched to the bottom bar. Here is everything from that themes.yaml up to that point for context.
    #                     CARD-MOD                     #
      card-mod-theme: tablet
      card-mod-root: |
        #view {
          background: url('/local/background.png') !important;
          background-size: cover !important;
      card-mod-view-yaml: |
          hui-view {
            background: none !important;
        #              GRID CARD HEADINGS               #
        grid-layout$:
          hui-grid-card:
              /* default */
              h1 {
                font-size: 2.4vw !important;
                line-height: 0 !important;
                font-weight: 500 !important;
                color: rgba(255, 255, 255, 0.8) !important;
                padding: 1vw 0 2vw 0 !important;
                letter-spacing: 0.006vw !important;
              /* portrait */
              @media screen and (max-width: 1200px) {
                h1 {
                  font-size: 3.3vw !important;
                  line-height: 1.1vw !important;
              /* phone */
              @media screen and (max-width: 800px) {
                h1 {
                  font-size: 5.5vw !important;
                  line-height: 6vw !important;
                  margin: 2vw 0 0 0 !important;
        #               SWIPE CARD MARGIN               #
            $swipe-card$:
                div {
                  height: 100%;
              hui-horizontal-stack-card$:
                  hui-conditional-card {
                    margin: 1px !important;
        #            SIDEBAR VERTICAL-STACK             #
        grid-layout$hui-vertical-stack-card$: |
          #root {
            background-color: rgba(0, 0, 0, 0.06);
            border-radius: 0;
            border-right: 0.1vw solid rgba(58, 69, 73, 0.2);
            min-height: 100vh;
          /* phone */
            #root {
              background-color: rgba(0,0,0,0);
              border-right: none;
              min-height: 100%;
              margin-left: -0.8%;
              margin-bottom: -6%;
        #             SIDEBAR LAUNDRY TIMER             #
        grid-layout$hui-vertical-stack-card$hui-conditional-card:
              display: flex;
              justify-content: center;
            /* phone */
              hui-conditional-card > button-card {
                zoom: 250%;
                width: 100%;
                filter: contrast(85%);
        #             SIDEBAR BOTTOM ICONS              #
        grid-layout$hui-vertical-stack-card$hui-grid-card:
            hui-grid-card {
              display: flex;
              flex: auto;
              align-items: flex-end;
            /* phone */
              hui-grid-card {
                position: absolute;
                right: 5.5vw;
            #root {
              width: 100%;
              padding: 0 13% 25% 13%;
            /* phone */
              #root {
                padding: 0 0 0 55%;
         #conditional color - Camera
          $hui-button-card:first-of-type$: |
            {% if is_state('sensor.template_recent_outside_motion', 'True') %}
              ha-card, ha-state-icon {
                color: rgb(35, 78 ,106) !important;
                opacity: 1 !important;
                animation: update 1.5s ease-out infinite;
              ha-card:hover {
                filter: brightness(130%);
                animation-play-state: paused;
              @keyframes update {
                0% {
                  transform: scale(1);
                40% {
                  transform: scale(1.08);
                50% {
                  transform: scale(0.98);
                55% {
                  transform: scale(1.02);
                60% {
                100% {
         #conditional color - Music
          $hui-button-card:nth-of-type(2)$: |
            {% if is_state('media_player.main_floor', 'playing') %}
              ha-card:hover {
              @keyframes update {
                0% {
                40% {
                50% {
                55% {
                60% {
                100% {
         #conditional color - Devices
          $hui-button-card:nth-of-type(3)$: |
            {% if is_state('binary_sensor.template_upstairs_vaccuum_color', 'dummyvaluetoturnthisoff') %}
              ha-card:hover {
              @keyframes update {
                0% {
                40% {
                50% {
                55% {
                60% {
                100% {
         #conditional color - Weather
          $hui-button-card:nth-of-type(4)$: |
              ha-card:hover {
              @keyframes update {
                0% {
                40% {
                50% {
                55% {
                60% {
                100% {
         #conditional color - Network Info
          $hui-button-card:nth-of-type(5)$: |
            #{% if not is_state('sensor.template_hass_version', 'Latest') %}
            {% if is_state('sensor.template_hass_version', 'Latest') %}
              ha-card:hover {
              @keyframes update {
                0% {
                40% {
                50% {
                55% {
                60% {
                100% {
         #conditional color - Vaccuum
          $hui-button-card:last-of-type$: |
            {% if is_state('binary_sensor.template_mainfloor_vaccuum_color', 'on') or is_state('binary_sensor.template_upstairs_vaccuum_color', 'on') %}
              ha-card:hover {
              @keyframes update {
                0% {
                40% {
                50% {
                55% {
                60% {
                100% {
      card-mod-card: |
        .header .card-header {
          letter-spacing: 0.005em;
          font-size: 1.6em;
          font-weight: 500;
          padding: 1em 0 0 1.68em;
          line-height: initial;
          cursor: default;
        .content .card-content {
          padding: var(--card-content-padding);
Before 2024.7, the 6 icons would stick to the bottom of the screen, but now they move with the sidebar text. And they should all be white, except the 6th icon which is active because the Vacuum is going. Instead all 6 get the modifications for card 6, if that makes sense.
Thank you for any pointers!
Hi All
First time poster here, slowly building a dash for myself but getting stuck at certain places. Looking to see if someone on here can help me out with an issue i’m having with custom button card. What i am trying to do is to have a custom button card upon tap use browser mod and then display another set of button cards. I am able to do this but for some reason the pop up has this space on the right hand side that i cannot seem to remove. I have been trying for quite sometime and have had no success. Just wondering if someone here can help out.
My code is below
type: custom:button-card
template:
  - base
entity: light.study_led_lightstrip
icon: mdi:test-tube
show_state: true
aspect_ratio: 1/1
tap_action:
  action: fire-dom-event
  browser_mod:
    service: browser_mod.popup
      title: Test Title
      content:
        type: custom:layout-card
        layout_type: custom:grid-layout
        layout:
          margin: 0 0 0 0  # Remove margin
          gap: 0  # Remove gap between items
          grid-template-columns: repeat(2, 1fr)
          grid-template-rows: repeat(auto-fill, minmax(100px, 1fr))
          mediaquery:
            '(max-width: 800px)':
              grid-template-columns: 100%
        cards:
          - type: custom:auto-entities
            filter:
              include:
                - entity_id: light.study_led_lightstrip
                  options:
                    icon: mdi:lightbulb
                    show_state: true
                    show_label: false
                    label: |
                        return states['fan.deck_fan'].attributes.percentage + '%';
                    aspect_ratio: 1/1
                    padding: 0 0 0 0  # Set padding to 0 to eliminate gaps
                    state:
                      - value: 'on'
                        styles:
                          card:
                            - height: 100px
                            - width: 100%  # Set width to 100% to fill the grid cell
                            - padding: 0  # Set padding to 0
                        icon:
                          - color: rgb(0, 175, 0)
                    template:
                      - base
                  options:
                    icon: mdi:lightbulb
                    show_state: true
                    show_label: false
                    label: |
                    aspect_ratio: 1/1
                    state:
                      - value: 'on'
                        styles:
                          card:
                            - height: 100px
                            - width: 100%
                            - padding: 0
                        icon:
                    template:
                      - base
                  options:
                    icon: mdi:lightbulb
                    show_state: true
                    show_label: false
                    label: |
                    aspect_ratio: 1/1
                    padding: 0 0 0 0
                    state:
                      - value: 'on'
                        styles:
                          card:
                            - height: 100px
                            - width: 100%
                            - padding: 0
                        icon:
                    template:
                      - base
                  options:
                    icon: mdi:lightbulb
                    show_state: true
                    show_label: false
                    label: |
                    aspect_ratio: 1/1
                    padding: 0 0 0 0
                    state:
                      - value: 'on'
                        styles:
                          card:
                            - height: 100px
                            - width: 100%
                            - padding: 0
                        icon:
                    template:
                      - base
            card:
              type: grid
              columns: 2
            card_param: cards
The result looks like this
Button card
I´m not quite sure if this can help you, but you may can take a look on a similar approach over a pop up integration. When I press these “Draußen” button the pop up with additional four lights occur. Normaly transparent background but for better comparsion with grey background.
bg2
browser_mod:
    timeout: 22000
    title: Draußen
    style: >
      --popup-background-color: transparent;
    content:
      type: custom:mod-card
      card_mod:
        style:
          layout-card:
            $grid-layout:
                  #root {
                    margin: 15px !important;
      card:
        layout:
          #grid-template-columns: 15vw
          grid-template-columns: 21vw
          #grid-template-rows: 20vw 20vw
          grid-template-areas: |
            "entrance entrance entrance"
          mediaquery:
            #phone
            "(max-width: 800px)":
              grid-template-columns: 20px 80vw 10px
              #grid-template-rows: 1fr
                ". entrance ."
            #tablet
            "(max-width: 2000px)":
        cards:
      #                 entrance-ROOM                   #
         - type: grid
           #title: entrance-room
           view_layout:
             grid-area: entrance
           columns: 1
           cards:
              - type: grid
                columns: 2
                cards:
                  - type: custom:button-card
                    entity: light.haustur
                    double_tap_action:
                      action: block
                    styles:
                      custom_fields:
                        timer:
                          - top: 118px
                    custom_fields:
                      icon: >
                        <ha-icon icon="phu:wall-lantern"
                        style="color:var(--button-card-light-color);"></ha-icon>
                    variables:
                      timer: timer.draussen
                    template:
                      - light
                      - timer
                    entity: light.terrasse_draussen
                    double_tap_action:
                      action: block
                    template:
                      - light
                      - icon_porch
                    entity: light.garage
                    double_tap_action:
                      action: block
                    styles:
                      custom_fields:
                        timer:
                          - top: 118px
                    custom_fields:
                      icon: >
                        <ha-icon icon="phu:rooms-carport"
                    variables:
                    template:
                      - light
                      - timer
                    entity: light.garage_seite
                    double_tap_action:
                      action: block
                    template:
                      - light
                      - icon_porch
@zs2766 兄弟,请问能分享一下这个空调的程式码吗? 如果可以的话十分感激。
Thanks for this info. Your approach is similar to mine. I looked at your code and tried to use it for my dashboard and got it working however the popped up icon sizes are too big for my dashboard. I tried looking at how to reduce the size and tried a few things but could not figure it out. Can you help with that by any chance ?
the onyl idea I have is to add: “columns: 4”. Then the icon are shrinked.
        cards:
      #                 entrance-ROOM                   #
         - type: grid
           view_layout:
             grid-area: entrance
           columns: 4
           cards:
If i do that on mine i still get the same space left on the side. Do you mind sharing your code on github by any chance so that i can look at it and see if i can work something out ? Maybe even incorporate some of what your doing
@VietNgoc I noticed your dash uses something like this as well. Any chance you could look at this and tell me where i might be going wrong ?
size: 100% I think this option affects the icons. Try removing or adjusting the size?
Does anyone else still use the Markdown card like Mattias used for displaying the number of devices that are currently in an ‘on’ state? I’ve used it for some time on my dashboard, inspired by Mattias’, and always have a template error in my log when HA restarts. I’m sure it’s due to some state/s not being available when the template is evaluated, but i’m not sure what I would have to change to stop this happening? My code is:
              - type: markdown
                content: |-
                  {% set lights = [
                    states.light.lounge_background_lights,
                    states.light.lounge_bay_window_lights,
                    states.light.lounge_ceiling_light,
                    states.light.lounge_table_lamp,
                    states.switch.kitchen_light,
                    states.light.office_ceiling_lights,
                    states.light.toilet_light,
                    states.light.loft_light,
                    states.light.desk_light
                  {% set devices = [
                    states.switch.tumble_dryer,
                    states.media_player.rx_v675_main,
                    states.media_player.lounge_tv
                  {% set lights_on = lights | selectattr('state','eq','on') | list %}
                  {% set lights_name = lights | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
                  {% set devices_on = devices | selectattr('state','search','(on|playing)') | list %}
                  {% set devices_name = devices_on | map(attribute='name') | join(', ') %}
                  {% if (lights_on | length == 0) and (devices_on | length == 2) %}
                    {{ devices_name | replace(', ', ' and ') }} are on
                  {% elif (lights_on | length == 0) and (devices_on | length > 0) %}
                    {{ devices_name | regex_replace(',([^,]*)$', ' and\\1') }} is on
                  {% elif (lights_on | length == 1) and (devices_on | length == 1) %}
                    {{ lights_name }} and {{devices_name }} are on
                  {% elif (lights_on | length == 1) and (devices_on | length > 1) %}
                    {{ lights_name }}, {{ devices_name | regex_replace(',([^,]*)$',' and\\1') }} are on
                  {% elif (lights_on | length > 1) and (devices_on | length == 1) %}
                    {{ lights_on | length }} lights and {{ devices_name }} are on
                  {% elif (lights_on | length > 1) and (devices_on | length > 1) %}
                    {{ lights_on | length }} lights, {{ devices_name | regex_replace(',([^,]*)$',' and\\1') }} are on
                  {% elif (lights_on | length == 1) and (devices_on | length == 0) %}
                    {{ lights_name }} is on
                  {% elif (lights_on | length > 1) and (devices_on | length == 0) %}
                    {{ lights_on | length }} lights are on
                    <font color='#6a7377'>Everything is turned off</font>
and the error that logs on restart of HA:
homeassistant.exceptions.TemplateError: UndefinedError: 'None' has no attribute 'state'
As soon as HA finishes loading, the card displays correctly on my dashboard, it just logs that error every time there is a restart.
Create what you have in content as a template sensor itself, then use its state in markdown.
something like this… you can then use it for other templates using individual attributes
2024-11-04 20.20.05
