is it zoomed on the tablet (like is the browser zoom set to higher than 100%?)
at the top of the UI-lovelace.yaml there is the “mediaquery” section where it decides how to layout the UI based on what the resolution of the display is set to. I would say it is treating your laptop like a phone because the resolution reported is too low. to test you could set the “max-width” in the media query section to be lower to force it to use the “full screen” version
Hi, this is such a good dashboard, thank you so much! My fonts do not seem to be the same as yours, where do I find the font files for SF fonts and where do I add these files to? Thanks in advance!
Hey All,
Still pluggin through this massive dashboard setup. This is more of a debugging question, but how can I use the browser console to watch or output (via console or otherwise) some of the values in these scripts? (eg. “variables” array in button_card_templates.) I am trying to thoroughly understand this code so I can modify it for my situation.
@chezpaul2 - Great layout. This is close to what I am looking for.
@Mattias_Persson Hi, is it possible to show the loader spinning wheel during particular states? I have a door lock that have ‘locked’ ‘unlocking’ ‘unlocked’ ‘locking’, I want to always show spinning wheel during ‘locking’ and ‘unlocking’. Thanks.
This looks great and I’ve started experimenting with it. Can anyone give me some help as to where I can reduce the vertical gap between rows? I’d like to bring them closer to each other (for example the 2 rows belonging to a single grid card are too far apart for me)
One more thing.
This seems to fix the spacing between title and first row (highlighted in yellow) but the gap between first and second row is still too big (highlighted in red). I would ideally like minimal spacing between rows like this: A different take on designing a Lovelace UI - #2255 by chezpaul2
