wow, looks pretty nice!
how did you implement the sankey diagram? and you mind sharing the name of the fonts?
Sankey chart: Anyone using the Sankey Chart Card?
Font: a Formula1 font found on the web
Looks reallygood - do you share your config anywhere?
Can someone please help me add under the code of Sidebar.yaml Image, in my case QRCODE.
Srry, not yet, still optimizing. Might in the future
To get more entities on the dashboard, i nested multiple grid-cards inside a swipe-card so that i can swipe though the grid-cards (same principle as the conditional media area).
The problem i have now is, that iām no longer able to adjust the brightness by dragging the circle. Does anyone know how to get around this? My skills are not good enough to figure it out.
Thanks!
Edit: It seems to work fine on my android phone, where the tilt option is disabled.
This is the lovelace yaml iām using:
- type: grid
title: Stue
view_layout:
grid-area: vardagsrum
columns: 1
cards:
- type: custom:swipe-card
parameters:
speed: 550
spaceBetween: 40
threshold: 5
cards:
- type: grid
columns: 2
cards:
- type: custom:button-card
entity: light.stue_skaenk_1
template:
- light
- icon_lamp
entity: light.stue_gulvlampe_1_sofa
template:
- light
- icon_shade
entity: media_player.samsung_tv
state_display: >
if (variables.state === 'on') {
return 'TƦndt';
if (variables.state === true) {
return variables.translate_unknown;
double_tap_action: !include popup/stue_tv.yaml
template:
- base
- icon_tv
#- icon_ambilight
- loader
entity: light.stue_lille_lampe_sofa
#double_tap_action: !include popup/vardagsrum_balkong.yaml
template:
- light
- icon_hue
- loader
- type: grid
columns: 2
cards:
entity: climate.stue
double_tap_action: !include popup/stue_klima.yaml
template:
- base
- icon_climate
- circle
variables:
circle_input: >
if (entity) {
return entity.state === 'cool'
? Math.round(entity.attributes.temperature).toString()
: Math.round(entity.attributes.current_temperature).toString();
circle_input_unit: "°C"
entity: light.stue_tvbord_1
template:
- light
- icon_lamp
entity: light.skabslys_spisestue
template:
- light
- icon_wled
And the circle template:
circle:
styles:
card:
- --c-stroke-color-on: "#b0b0b0"
- --c-stroke-color-off: none
- --c-fill-color-on: none
- --c-fill-color-off: rgba(255,255,255,0.04)
- --c-stroke-width: 2.3
- --c-stroke-width-dragging: 4
- --c-font-color: "#97989c"
- --c-font-size: 14px
- --c-unit-font-size: 10.5px
- --c-font-weight: 700
- --c-letter-spacing: -0.02rem
custom_fields:
circle:
- display: initial
- width: 88%
- margin: -3% 2% 0 0
- justify-self: end
- opacity: 1
custom_fields:
circle: >
if (entity) {
let r = 22.1,
c = r * 2 * Math.PI,
tspan = '<tspan dx=".2" dy="-.4">',
domain = entity.entity_id.split('.')[0],
state = variables.state_on,
input = variables.circle_input || ' ',
unit = variables.circle_input_unit || ' ';
* CIRCLE *
let circle = (state, input, unit) => {
return `
<svg viewBox="0 0 50 50">
<style>
circle {
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${c};
stroke-dashoffset: ${typeof input === 'number' && c - input / 100 * c};
stroke-width: var(--c-stroke-width);
stroke: ${state ? 'var(--c-stroke-color-on)' : 'var(--c-stroke-color-off)'};
fill: ${state ? 'var(--c-fill-color-on)' : 'var(--c-fill-color-off)'};
text {
font-size: var(--c-font-size);
font-weight: var(--c-font-weight);
letter-spacing: var(--c-letter-spacing);
fill: var(--c-font-color);
tspan {
font-size: var(--c-unit-font-size);
#circle_value, tspan {
text-anchor: middle;
dominant-baseline: central;
</style>
<circle id="circle_stroke" cx="25" cy="25" r="${r}"/>
<text id="circle_value" x="50%" y="52%">${input}${tspan}${unit}</tspan></text>
</svg>
${domain === 'light' && `
<input id="circle_slider" type="range" min="0" max="100" value="${input}">
* LIGHT *
if (domain === 'light' && state) {
// wait 0ms for shadow dom
setTimeout(() => {
// then get elements
let elt = this.shadowRoot,
circle_slider = elt.getElementById('circle_slider'),
circle_value = elt.getElementById('circle_value'),
circle_stroke = elt.getElementById('circle_stroke');
// approximate position of thumb relative to circle
circle_slider.style.top = `${(circle_slider.value - 50) / 1.66 - 1}%`;
// debug position
let debug = false;
if (debug) circle_slider.style.opacity = 0.3;
// pass each event to handler
['click', 'input', 'mousedown', 'mouseup', 'touchstart', 'touchend'].forEach((event) => {
circle_slider.addEventListener(event, handler, { passive: true })
function handler(event) {
// "this" refers to slider
if (event.target === this) {
// bypass button-card tap_action
event.stopPropagation();
// update circle_value
circle_value.innerHTML = `${this.value}${tspan}${unit}</tspan>`;
// update stroke
circle_stroke.style.strokeDashoffset = c - this.value / 100 * c;
circle_stroke.style.strokeWidth = 'var(--c-stroke-width-dragging)';
// set cursor while dragging
if (event.type === 'mousedown' || event.type === 'input') {
this.style.cursor = 'grabbing';
} else {
this.style.cursor = 'grab';
// reset stroke width if value doesn't change
if (input == this.value && (event.type === 'click' || event.type === 'touchend'))
circle_stroke.style.strokeWidth = 'var(--c-stroke-width)';
// on release
if (event.type === 'mouseup' || event.type === 'touchend') {
// display loader if brightness is 0
if (circle_slider.value == 0 && elt.getElementById('loader')) {
elt.getElementById('loader').style.display = 'initial';
elt.getElementById('circle').style.display = 'none';
// set brightness
hass.callService('light', 'turn_on', {
entity_id: entity.entity_id,
brightness_pct: this.value
}, 0);
return circle(state, input, unit);
* PERSON *
else if (domain === 'person') {
let time = c => {
let s = (c/1e3),
m = (c/6e4),
h = (c/36e5),
d = (c/864e5);
return s < 60
? parseInt(s) + 's'
: m < 60 ? parseInt(m) + 'm'
: h < 24 ? parseInt(h) + 'h'
: parseInt(d) + 'd';
let input = states[variables.retain] === undefined || states[variables.retain].state === 'unavailable'
? time(Date.now() - Date.parse(entity.last_changed))
: time(Date.now() - Date.parse(states[variables.retain].state)),
unit = ' ';
* CLIMATE *
else if (domain === 'climate') {
* OTHER *
else if (variables.state_on) {
Iām a developer and this thing had me stuck for a bit swell, you need to add touchStartPreventDefault: false to the parameters section of the swipe-card
start_card: 1
parameters:
this is my full config fro my swipe cards
start_card: 1
parameters:
roundLengths: true
effect: coverflow
speed: 650
spaceBetween: 20
threshold: 7
coverflowEffect:
rotate: 80
depth: 300
BTW this is a perfect example of how to ask a good question.
Thank you very much! I have battled this for days now
happy to help, would love to see your full dashboard once its complete
Sure, iāll post an update when I have something worth sharing.
are you able to share your layout card config please? Iām interested in how youāve done your sidebar and top menu
i have this already in my base tempate of button-card-templates
- background-color: >
return variables.state_on
? 'rgba(255, 255, 255, 0.8)'
: 'rgba(115, 115, 115, 0.2)';
Which turns the background on to white when a device is on.
Iām looking to have the background colour change with different power values
So for example if power 50w (white) if 100w (yellow) if 200w (red)
how can i do this?
@tomcoleman try this, this gives me the following. You only need to change let power = "251"; to your own sensor. something like let power = states['sensor.YOURSENSOR'].state
styles:
card:
let power = "251";
if ((power >= 50) && (power < 100))
return '#FFFFFF';
if ((power >= 100) && (power < 200))
return '#0099cc';
if (power >= 200)
return '#ff0000';
else
return "rgba(115, 115, 115, 0.25)";
Maybe not the cleanest code, but i donāt have enough javascript knowledge to make it cleaner.
thanks i have set it to
name: <marquee behavior=scroll scrollamount="3">Kitchen PV</marquee>
entity: sensor.solax_pv_power_2
template:
- base
styles:
card:
let power = "sensor.solax_pv_power_2";
return '#FFFFFF';
return '#0099cc';
if (power >= 200)
return '#ff0000';
else
custom_fields:
icon: >
<ha-icon icon="mdi:solar-power-variant"></ha-icon>
and it shows no change
got it
its now showing
styles:
card:
let power = states['sensor.solax_pv_power_2'].state
return '#FFFFFF';
return '#0099cc';
if (power >= 200)
return '#ff0000';
else
custom_fields:
icon: >
although now cant see text clearly ! LOL
@tomcoleman You can do the same with color to change your text color.
I want to slide the 6 buttons to 6 other buttons. but something is wrong in the code. Anyone who can help me ?
parameters:
speed: 550
spaceBetween: 40
threshold: 5
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: "custom:button-card"
cards:
cards:
I have 4 buttons on a row to slide, but not 2 rows with 2 buttons. What am I doing wrong ?
do you know what that code will be ?
@tomcoleman something like this.
styles:
card:
- color: >
return '#97989c';
return '#97989c';
if (power >= 200)
return '#97989c';
else
return "#97989c";
return '#FFFFFF';
return '#0099cc';
if (power >= 200)
return '#ff0000';
else
custom_fields:
icon: >
I was looking through the code and trying to figure out how to integrate HACS updates into the footer update button/popup, and I realized that itās already partially there, or maybe just not working correctly on my install.
The HACS sensors are working correctly, showing repositories and available updates, but they donāt show up in the footer/popup.
The footer is showing a single update, but that is for ESPHome (older WLED install w/ WS2801 LEDs)
Iāve looked through popup/footer_updates.yaml and I see a reference to a hacs_installed variable, but nothing for sensor.hacs.
Is line 121 in button_card_templates/update.yaml correct?
hacs_update = states['update.hacs_update']?.attributes.installed_version,
āupdate.hacs_updateā doesnāt seem right but I could very easily be wrong. Furthermore, I donāt have a sensor or any entity named āhacs_updateā and in sensor.hacs, installed_version is part of an array in the repositories attribute.
Does anyone have this working that can shed some light on this? @masoncrawford1994 you seem to have a pretty good handle on these templates. Is this something you have working?
