A different take on designing a Lovelace UI
How do i turn off the looping at the effect. Going crazy !!
Pls help!
Hey, love the theme. I’ve jumped right in trying to customize it for myself. So far its going ok for how new to this I am. :sweat_smile:
Was wondering if anyone could help me get the climate to do more than just cool? I have a nest that does cool, heat and heat_cool. I basically just want it to be blue and say cool when cooling or red and say heat when heating and have the title “deactivate” and say idle when its not doing those things. I assume currently to get it to go from white to grey it has to be outright off which will never be my case.
Would something like this work for the state:
   - type: custom:button-card
        entity: climate.hallway_thermostat
        double_tap_action: !include popup/sovrum_klimat.yaml
        template:
          - base
          - icon_climate
          - circle
        variables:
          circle_input: >
              if (entity) {
                  return entity.state === 'cool'
                      ? Math.round(entity.attributes.temperature).toString()
                      : Math.round(entity.attributes.current_temperature).toString();
              if (entity) {
                  return entity.state === 'heat'
          circle_input_unit: "°C"
been out of the space for some time, but im back and happy to help
I do not change the tile of the cards on slide but that has been done, see this link.
if you do not provide code for me to look at I can’t help you more
the section at the bottom of the side bar is done like this
you should have the 1st 3 lines in your code, under where the sidebar is set up, add what I have
  entity: sensor.template_sidebar
  template: sidebar
  entity: sensor.template_sidebar_uptime
  template: up_time
then you will need to add the up_time template
in button card template folder
add a file named up_time.yaml
up_time:
  show_icon: false
  show_name: false
  show_state: true
  styles:
    card:
      - margin-top: -100px
      - border-width: 0
    state:
      - font-size: 1vw
      - font-family: SF Mono, Roboto
      - opacity: 0.65
      - padding: 0.55vw 1.2vw 0.5vw 1.2vw
hi I think iv already cover this in an older post A different take on designing a Lovelace UI - #3687 by masoncrawford1994
hay welcome to the project, I think you should look at this project by @Laffer,
he has an example of heating, I have also done heating but for me it was a lot of small changes all over the place.
for example adding ‘heat_cool’, ‘heat’ to the stat on in /button_card_templates/base.yaml
base:
  template:
    - settings
    - tilt
    - extra_styles
  variables:
    state_on: >
      [[[ return ['on', 'home', 'cool', 'heat_cool', 'heat', 'fan_only', 'playing', 'unlocked'].indexOf(!entity || entity.state) !== -1; ]]]
Thanks! I think that has put me on the right track. Can change the icon to red and show Heat. I can’t quite wrap my head around having it show like its off when its just idle though. Ill have to keep playing.
Hello. can you give a example or what command should I input to use chatgpt to modify the code?
@ zs2766 This is really amazing, can you share the complete dynamic icon code of the air conditioner?
hi agin @Laffer
After this update:
Home Assistant 2023.7.3
Supervisor 2023.07.1
Operating System 10.3
Frontend-version: 20230705.1 - latest
I cant use light in my phone. Only on the bigger screens i can see “x” on the lights to close the popup.
How do i fix this
Its working now.
I hade the first code.
I did a change “”>${inner_text}/3" and now its working :slight_smile:
Thnx!
Hello, i have problem with click sound:
When I click on the button. kiosk browser gives me a sound playback error
“Failed to load sound: wrong URL or unsupported format?”
I transferred the sound files to www folder an edit settings for tablet
Hi! So first thanks @Mattias_Persson for this greet dashboard idea for everyone in this topic. So that everyone can give ther ideas to improve it even more… So Thats why i post this video of mine edited dashboard from you.
i hope you guys have any extra tips/tricks to improve the dashboards we make together
just a short link for 2 days (I wil get a full link)
Its a beta so things dont look like what they should look like
Which media / spotify popup is that? Could you share your code?
@Emad131
If you’re using the code for the light that I’ve modified, then there is no close button.
You simply have to click or tap outside of the popup to close it.
If you want a close button you could add a title with a space - or the text you’d like, like this:
  light:
    template:
      - base
      - circle
      - loader
    variables:
      circle_input: >
          if (entity) {
              // if light group get brightness from child to remove bounce
              let child = entity.attributes.entity_id,
                  brightness = child && states[child[0]].attributes.brightness
                      ? Math.round(states[child[0]].attributes.brightness / 2.54)
                      : Math.round(entity.attributes.brightness / 2.54);
              return brightness === 0 && entity.state !== 'off'
                  ? 1
                  : brightness
      circle_input_unit: '%'
      light_entity: '[[[ return entity.entity_id ]]]'
    double_tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.sequence
          sequence:
            #- service: browser_mod.close_popup
            - service: browser_mod.popup
                sequence:
                ## Title with close button
                title: ' '
                style: >
                  --popup-background-color: transparent;
                content:
                  type: custom:more-info-card
                  entity: '[[[ return variables.light_entity; ]]]'
                card_mod:
                  style:
                    more-info-card:
                      $ha-card:
                          state-card-content {
                            display: none !important;
                          .card-header {
                        more-info-light:
                            ha-attributes {
                            .controls {
                              margin-bottom: 0 !important;
The following part of the code is the key here:
                sequence:
                title: ' '
KING!
Its working now <3
Here is my template code (Still wanna get every popup in my popup folder, but still working on it)
  Media_player_living:
    variables:
      media_on: >
        [[[ return !entity || ['on', 'playing', 'paused', 'idle'].indexOf(entity.state) !== -1; ]]]
      media_off: >
        [[[ return !entity || ['off', 'standby', 'unknown', 'unavailable'].indexOf(entity.state) !== -1; ]]]
      volume_control: '[[[ return entity.entity_id; ]]]'
      player: '[[[ return entity.entity_id; ]]]'
    tap_action:
      browser_mod:
          style: >
            --popup-max-width: 2000px;
          card_mod:
            style:
                ha-header-bar {
                :host {
                  --mdc-theme-surface: rgba(0,0,0,0);
                @media screen and (max-width: 2000px) {
                  ha-header-bar {
          content:
            type: custom:mod-card
            card_mod:
              style:
                layout-card:
                  $grid-layout$:
                    hui-vertical-stack-card:
                        ha-card {
                          animation: border 1s forwards;
                      $hui-horizontal-stack-card:
                          #root {
                            height: 0% !important;
                            justify-content: center !important;
                            margin-top: 2.2em !important;
            card:
              type: custom:layout-card
              layout_type: custom:grid-layout
              layout:
                grid-template-columns: 500px 500px
                grid-template-rows: 1fr
                grid-column-gap: 15px
                grid-template-areas: |
                  "media  none"
                  "Actions  boobs"
                mediaquery:
                  #phone
                  "(max-width: 1250px)":
                      "media"
                      "none"
              cards:
                - type: vertical-stack
                  view_layout:
                    grid-area: media
                  cards:
                    - type: conditional
                      conditions:
                        - entity: media_player.hk_citation_one_d20393
                          state_not: 'off'
                      card:
                        type: custom:mini-media-player
                        volume_stateless: true
                        tap_action:
                          action: none
                        info: scrol
                        group: false
                        volume_step: '2'
                        sound_mode: full
                        artwork: full-cover
                        toggle_power: false
                        source: icon
                        hide:
                          source: true
                          next: true
                          prev: true
                          play_pause: true
                          volume: true
                          power: true
                        style: |
                          .flex {
                            display: block;
                            {% if not is_state('media_player.hk_citation_one_d20393','off') %}
                            filter: drop-shadow(0px 2px 2px rgba(0,0,0,1));
                            {% else %}
                            {% endif %}
                          ha-card.--has-artwork .cover{
                            opacity: 0.9;
                          .entity__info__media {
                            opacity: 1 !important;
                            padding-right: 16px;
                            overflow: hidden;
                            height: 4.4em;
                            height: 90%;
                          ha-card > div.mmp-player > div.mmp-player__core.flex >
                          div.entity__icon {
                            display: none;
                            {% endif %}
                          } ha-card > div.mmp-player > div.mmp-player__core.flex { }
                          mmp-media-controls {
                            flex-wrap: wrap-reverse !important;
                            {% endif %}
                          } mmp-powerstrip  {
                          } ha-card > div.mmp-player {
                            padding: 25px !important;
                            {% else %}
                            #display: none !important;
                            {% endif %}
                            {% if is_state_attr('media_player.hk_citation_one_d20393','media_content_id', 'Bluetooth') %}
                            position: relative;
                            height: 20vh;
                            {% else %}
                            position: absolute;
                            align-self: flex-start;
                            height: 100%;
                            {% endif %}
                            background: radial-gradient(circle, rgba(255,255,255,0) 10%, rgba(0,0,0,0.6) 90%) !important;
                            font-size: 0.9em !important;
                          } ha-card > div.mmp-player > div.mmp-player__adds {
                            position: absolute;
                            bottom: 25px;
                            padding: 0px 16px 0px 0px;
                          } div.flex.mmp-media-controls__media {
                              margin-bottom: -5px !important;
                  cards:
                  - type: custom:spotify-card
                    spotify_entity: media_player.spotify_jacobien_cristian
                    playlist_type:
                    grid_covers_per_row: '4'
                    limit: 40
                    country_code: NL
                    display_style: grid
                    default_device: Speaker Woonkamer
                    card_mod:
                      style: |
                        ha-card {
                          border-radius: calc(var(--custom-button-card-border-radius) / 2) !important;  /* card - rounded corners */
                          aspect-ratio: 2/2 !important;  /* card - square */
                          margin: 0px !important;  /* remove card margins to line up with rest of dashboard */
                          padding: 0% !important;
                        .grid{
                          object-fit: cover !important;  /* fill the whole card */
                          aspect-ratio: 1/1;  /* needed for object-fit */
                          gap: 0,5% !important;
                        .btn {
                          top: 50% !important;  /* center buttons */
                        .grid-item{
                          border-radius: var(--button-card-border-radius) !important;
                          aspect-ratio: unset;  /* undo image aspect-ratio when clicked */
                          box-shadow:none !important;
                          color: transparent !important;
                        .grid-item-album-image img{
                        .grid-item:hover{
                        .grid-item-album-image.playing{
                        #header{
                          display:none !important;
                        #footer{
                        .playback-controls{
                        #header-track{
                          display:none;
                        #content{
                          border: 0px !important;
                          background-color: transparent !important;
                  - type: horizontal-stack
                    cards:
                        icon: >-
                          [[[ return entity.entity_id === 'media_player.denon_receiver' ?
                          'custom:nvidia-m' : 'mdi:power'; ]]]
                        tap_action:
                          action: call-service
                          service: >-
                            'script.living_room_set_inputs_to_shield' :
                            'media_player.turn_off'; ]]]
                          service_data:
                            entity_id: >-
                              'none' : variables.player; ]]]
                        template: icon_button
                        icon: >-
                          'custom:nvidia-m' : 'mdi:skip-previous'; ]]]
                        tap_action:
                          service: >-
                            'media_player.media_previous_track'; ]]]
                          service_data:
                            entity_id: >-
                        icon: >-
                          'bha:apple-tv' : 'mdi:play-pause'; ]]]
                        tap_action:
                          service: >-
                            'script.living_room_set_inputs_to_apple_tv' :
                            'media_player.media_play_pause'; ]]]
                          service_data:
                            entity_id: >-
                        double_tap_action:
                          service: >-
                            'media_player.media_stop'; ]]]
                          service_data:
                            entity_id: >-
                        hold_action:
                          service: >-
                          service_data:
                            entity_id: >-
                        icon: >-
                          'custom:sonos' : 'mdi:skip-next'; ]]]
                        tap_action:
                          service: >-
                            'script.living_room_set_input_to_sonos' :
                            'media_player.media_next_track'; ]]]
                          service_data:
                            entity_id: >-
                        icon: >-
                          'custom:sonos' : 'mdi:volume-off'; ]]]
                        tap_action:
                          service: input_boolean.toggle
                          service_data:
                            entity_id: input_boolean.mute
                    cards:
                      - type: entities
                        entities:
                          - type: custom:slider-entity-row
                            full_row: true
                            step: 5
                            grow: true
                            max: 100
                        style: |
                          ha-card {
                            margin-top: -40px;
Very nice thanks! Do you also have the code for the icons? Will take some work to get it running for my setup
Would love to get peoples guidance on how to make a button “light up” while a script is running.
I have a sprinkler/irrigation system. Right now, I have to press one button to start the watering and a different button to stop it mid-cycle. Each button successfully calls a service. Right now, pressing the ‘Run’ button works fine, but it doesn’t stay lit-up while any zone is watering. I would like to fix that. Anyone have any suggestions on how? Once I get that figured out, I am going to combine the two buttons so a long-tap performs the stop. For reference, here is my ui-lovelace-tablet.yaml code for the two buttons, and they both currently work as expected.:
      - type: grid
        title: Sprinklers
        view_layout:
          grid-area: outside
        columns: 2
        cards:
            tap_action:
              service: bhyve.start_program
              service_data:
                entity_id: switch.outside_mysprinklers_main_program_program
              target: {}
            template:
              - base
              - icon_sprinkler
            tap_action:
              service: script.turn_on
              service_data:
                entity_id: script.sprinkler_stop_scrpt
            template:
              - light
              - icon_sprinkler
Thank You!
I think that could be done by using an input boolean to trigger and stop your script instead. Probably you need to make an automation to trigger the script from the input boolean. I’m not too experienced with that, but maybe it gives you an idea :slight_smile:
