I see new ways, have PS as well. Can create my own… but yours are very nice as well!!
Hi All
First of all thanks for sharing all the information.
In my case i try to replicate the configuration for this nice designig but im strugelling with the popup section
See below a basic example for the popup configuration:
Im not able to display propertly the diferent entities on the card because i receive below error
Would be really nice if you share with me the configuration about your popup, i tried to follow the configuration on github for @Mattias_Persson but is not working for me at all even if i change the entity and so on (https://github.com/matt8707/hass-config/tree/master/popup)
As and example below from the github repository not work for me
action: call-service
service: browser_mod.popup
service_data:
card:
cards:
- entities:
- entity: sensor.hass_version_template
- entity: switch.watchtower
icon: ‘mdi:lighthouse-on’
- entity: sensor.hass_release_template
- entity: sensor.home_assistant_v2_db
icon: ‘mdi:database’
- entity: sensor.home_assistant_log
icon: ‘mdi:file-document’
- entity: sensor.docker_uptime
icon: ‘mdi:clock’
“No card type configured” error because you didn’t specify card type on line 6
service_data:
title: Home Assistant
card:
type: horizontal-stack
cards:
- entities:
- entity: sensor.hass_version_latest
- entity: sensor.last_boot
type: entities
- entities:
type: entities
@Mattias_Persson really apreciated your help! now start working.
Today i just start to play arround with the background image and is incredible how stop working when i tried to change. looks like is not able to load from the folter \config\www\background.png
Did you facing before such type of issue? can be the case that any of the resources is not load properly? Im not able to found any log information about that?
See below the simple configuration, and always really apreciated your help!
custom_header:
kiosk_mode: false
resources:
- type: module
url: /community_plugin/lovelace-card-preloader/lovelace-card-preloader.js - type: module
url: /community_plugin/lovelace-layout-card/layout-card.js - type: module
url: /community_plugin/custom-header/custom-header.js - type: js
url: /community_plugin/bar-card/bar-card.js - type: module
url: /community_plugin/button-card/button-card.js - type: module
url: /community_plugin/button-entity-row/button-entity-row.js - type: module
url: /community_plugin/circle-sensor-card/circle-sensor-card.js - type: js
url: /community_plugin/light-entity-card/light-entity-card.js - type: module
url: /community_plugin/lovelace-card-mod/card-mod.js - type: module
url: /community_plugin/lovelace-card-tools/card-tools.js - type: module
url: /community_plugin/mini-graph-card/mini-graph-card-bundle.js - type: module
url: /community_plugin/mini-media-player/mini-media-player-bundle.js - type: module
url: /community_plugin/swipe-card/swipe-card.js - type: js
url: /community_plugin/upcoming-media-card/upcoming-media-card.js - type: js
url: /community_plugin/vertical-stack-in-card/vertical-stack-in-card.js - type: module
url: /community_plugin/popup-backdrop-filter/popup-backdrop-filter.js - type: js
url: /community_plugin/hass-bha-icons/hass-bha-icons.js - type: js
url: /community_plugin/light-slider-card.js
preload:
- markdown
- conditional
- map
- entities
- iframe
title: Casa
- badges: []
panel: true
path: default_view
title: Home
cards:-
type: picture-elements
image: /local/background.pngstyle: |
ha-card {
height: calc(100vh) !important;
width: auto !important;
elements:
### SideBar Time
###################################################################################### ### Hora ########################################### - type: state-label entity: sensor.time hold_action: action: none style: color: 'rgba(255, 255, 255, 0.7)' font-family: SF Text font-size: 5.41vw font-weight: 600 left: 5.5% letter-spacing: '-0.05vw' max-width: 1px pointer-events: none top: 7% tap_action: action: none
Please read this first
Sorry for asking, but why are you linking to that topic? Is it because you saw the line “now start working”?
If so, assuming here, but if i read the posts from @simposium i notice the lack of propper grammar in his sentences. I believe he’s using some kind of translation tool weird things can happen there.
I am assuming again he tried to say that it started to work again. Not trying to tell you to work.
Just trying to help out clear out some stuff
Sorry for my gramar… i just try to said that from time to time the background image under the picture element not load
I understand. I’m not criticizing your grammar I’m asking you to read the post I linked because it shows you how to properly format code.
Don’t know if this will help, but a recent HASS update requires moving resources to: configuration.yaml.
Like this:
lovelace:
mode: yaml
resources:
- url: /hacsfiles/layout-card.js
type: module
It’s not required yet.
This awesome new feature comes with a deprecation if you use Lovelace in manual YAML mode: You need to move the
resources
section from yourui-lovelace.yaml
to thelovelace:
section inconfiguration.yaml
. It is not a breaking change yet; we still load them from the previous location if we didn’t find anything in thelovelace:
section, however, this fallback is being removed in a future version.
Thanks for the answer. Does it means that the configuration in your github is valid to load resources from configuration.yaml?
I read many documentation and when i ijust check the config looks fine, but still not unable to load the background. Again thanks for your patience and for your time
lovelace:
mode: yaml
resources:
[ {‘url’:’/hacsfiles/bar-card/bar-card.js’, ‘type’:‘js’},
{‘url’:’/hacsfiles/button-card/button-card.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/button-entity-row/button-entity-row.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/custom-header/custom-header.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/light-entity-card/light-entity-card.js’, ‘type’:‘js’},
{‘url’:’/hacsfiles/lovelace-card-mod/card-mod.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/lovelace-card-preloader/lovelace-card-preloader.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/lovelace-layout-card/layout-card.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/lovelace-slider-entity-row/slider-entity-row.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/lovelace-valetudo-map-card/valetudo-map-card.js’, ‘type’:‘js’},
{‘url’:’/hacsfiles/mini-graph-card/mini-graph-card-bundle.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/mini-media-player/mini-media-player-bundle.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/popup-backdrop-filter/popup-backdrop-filter.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/stack-in-card/stack-in-card.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/swipe-card/swipe-card.js’, ‘type’:‘module’},
{‘url’:’/hacsfiles/upcoming-media-card/upcoming-media-card.js’, ‘type’:‘js’},
{'url':'/hacsfiles/mod/circle-sensor-card.js?v=1.2.0', 'type':'module'},
{'url':'/hacsfiles/mod/light-slider-card.js?v=3.2.2', 'type':'js'},
{'url':'/hacsfiles/mod/hass-bha-icons.js?v=f015ee3', 'type':'js'},
{'url':'/local/font.css', 'type':'css'} ]
hello Mattias your UI is simply superb
I would like to install it but iam new to home assistant so can you help me some tutorials.
So that i can follow those and install your interface.
This would be really nice … i just read all the files try to adap but is quite hard…
Taken so much inspiration from this, particularly loving hiding things away in pop-ups to keep the UI clean. Thanks so much for the details and config share
how to get buttons with title above, just like in first post
really like it
Thank you for your great work @Mattias_Persson!
I’m working on a copy of your design but having trouble with adding the popups to my light switches.
I get the following error:
unknown tag !<!include> at line
Do you know what I am doing wrong?
My code:
entity: light.office_desk
type: 'custom:button-card'
hold_action: !include popup/test.yaml
template: light
custom_fields:
icon: >
<svg viewBox="0 0 50 50"> <path d="M27.4 47.3h-4.9s-.7.1-.7.8.4.9.7.9h4.9c.3
0 .7-.1.7-.9s-.7-.8-.7-.8zm3.3-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0
.8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-3H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0
.8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0
.8-.1.8-.9s-.9-.8-.9-.8zm5.2-23.2c-3.3-5.3-7-5.6-10.9-5.6-3.8 0-8.4.4-10.9
5.6-.1.1-.1.3.1.7.4.8 3.3 7.2 3.2 18.8 0 1.1-.1 1.6 0 1.7 0 .1 0 .7
1.1.7h13c1 0 1-.5 1.1-.7v-1.7c-.1-11.6 2.8-18 3.2-18.8.1-.4.1-.5.1-.7"
fill="var(--primary-color)"/> <path d="M14.1 15.3c3.4-.3 7-.4 10.9-.4 3.8 0
7.5.2 10.9.4.4-.4.7-.8.9-1.1C39 8.5 38.9 6.5 38.9
6c-.2-4.4-8.4-5-12.1-5h0-3.4c-3.7 0-12 .5-12.1 5 0 .5-.1 2.5 2.1 8.2
0.3.3.8.7 1.1z" fill="var(--button-card-light-color)"/> </svg>
Hard to say. Does test.yaml exist in folder popup. Do you have browser_mod installed. Test without !include and have the service call under hold action
Hi Matthias , did your state_image on the person tracking work at the moment? It works for me a time but now it dont show the “not_home” picture. The “home” picture is ok.
I don’t know, I’m not using state images anymore
I see it, you have change your Config.
I have it working again now.
Thanks.
