### Checklist
- [X] I have updated to the latest available Home Assistant versiā¦on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
- [ ] I have tried reproducing the issue in [safe mode](https://www.home-assistant.io/blog/2023/11/01/release-202311/#restarting-into-safe-mode) to rule out problems with unsupported custom resources.
### Describe the issue you are experiencing
Tablet model tried: Samsung Galaxy Tab S4 / 10.5" 1600 x 2560
Applies to both HA Companion Android app and Chrome on Android. See version details below.
Using the new Sections view on a tablet in portrait mode, the dashboard displays a single column of cards with wide empty borders, whereas the Masonry view displays two columns with essentially the same content, making much better use of the screen area.
I don't know if this should be a bug report or a feature request. If a feature request, the implementation could be to allow setting of a minimum number of columns similar to the maximum number of columns setting introduced in 2024.4 beta.
### Describe the behavior you expected
Dashboard in portrait mode should display in two columns with Section view for this screen width as it does in Masonry view for this screen width.
### Steps to reproduce the issue
1. Create Sections view in Dashboard.
2. Open HA Companion Android app or Chrome Android on tablet in portrait mode.
### What version of Home Assistant Core has the issue?
2024.4.0b3
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
Chrome Android 123.0.6312.80 / HA Companion Android app 2024.1.5-full
### Which operating system are you using to run this browser?
Android 10
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
```yaml
- type: sections
title: Home
path: default-view
icon: mdi:home-assistant
sections:
- type: grid
cards:
- custom_fields:
day_date:
card:
entity: sensor.day
label: |
[[[ return states['sensor.date_short'].state ]]]
show_icon: false
show_label: true
show_name: false
show_state: true
styles:
label:
- color: var(--secondary-text-color)
- justify-self: end
state:
- font-weight: bold
- font-size: 120%
- justify-self: end
card:
- background: rgb(0,0,0,0%)
- box-shadow: none
- border-radius: 0px
- border-color: rgb(0,0,0,0%)
type: custom:button-card
time: |
[[[ return states['sensor.time'].state ]]]
entity: ''
hold_action: none
styles:
card:
- padding: 4%
- font-size: 500%
- styles:
- color: var(--button-card-text-color)
custom_fields:
day_date:
- justify-self: end
- font-size: 40%
- text_color: var(--secondary-text-color)
time:
- justify-self: start
grid:
- grid-template-areas: '"time day_date"'
- grid-template-columns: 2fr 3fr
- grid-template-rows: 1fr
tap_action: none
- show_current: true
show_forecast: false
type: weather-forecast
entity: weather.twickenham_pirate_weather_daily
forecast_type: daily
tap_action:
action: navigate
navigation_path: '#weather'
- type: horizontal-stack
cards:
primary: Away Mode
secondary: |-
{% set away_mode=states.input_boolean.vacation_mode.state %}
{% set ron=states.person.ron.state %}
{% if away_mode=='off' %}
Off
{% elif away_mode=='on' and ron=='home' %}
On | Home
{% elif away_mode=='on' and ron=='away' %}
On | Away
{% elif away_mode=='on' and ron=='not_home' %}
On | Away
{% elif away_mode=='on' %}
On | {{ states.person.ron.state[0]|upper }}{{ states.person.ron.state[1:] }}
{% else %}
Unknown
{% endif %}
icon: mdi:beach
entity: input_boolean.vacation_mode
layout: horizontal
icon_color: |-
{% set state=states.input_boolean.vacation_mode.state %}
{% if state=='off' %}
grey
{% elif state=='on' %}
blue
{% endif %}
badge_icon: |-
none
mdi:check
{% endif %}
badge_color: |-
none
green
{% endif %}
multiline_secondary: false
primary: Water Heater
secondary: >-
{{ states('switch.water_heater_power')[0]|upper }}{{
states('switch.water_heater_power')[1:]|lower }}
icon: mdi:water-boiler
entity: switch.water_heater_power
layout: horizontal
icon_color: |-
{% set state=states.switch.water_heater_power.state %}
grey
green
{% endif %}
badge_icon: ''
badge_color: ''
fill_container: true
hold_action:
action: more-info
tap_action:
action: toggle
cards:
- type: custom:button-card
icon: si:tado
tap_action:
action: url
url_path: app://com.tado
styles:
card:
- height: 100%
- width: 60px
primary: Heating
secondary: |-
{% set state=states.group.heating.state %}
All Off
{% else %}
Auto
{% endif %}
icon: mdi:home
entity: group.heating
layout: horizontal
icon_color: |-
{% if state=='Off' %}
gray
blue
{% elif state=='auto' %}
green
{% endif %}
badge_icon: >-
{% set state=state_attr('climate.living_room', 'hvac_action')
none
{% elif state=='idle' %}
mdi:clock-outline
{% elif state=='heating' %}
mdi:fire
{% endif %}
badge_color: >-
none
disabled
deep-orange
{% endif %}
tap_action:
action: navigate
navigation_path: '#heating'
hold_action:
action: more-info
- type: conditional
conditions:
- condition: user
users:
- 11b58d799cf543ebac68a50223e3c620
- d7314adfd60b48fbb0cfc261f7d14870
- 47184b7353474660be1dcbcbb2d2943f
- 9dfa188438124d1f9e9c6dd0ef44a611
card:
type: custom:mushroom-template-card
primary: Living Room
secondary: >-
{{ state_attr('climate.living_room', 'current_temperature')
}}Āŗ C
icon: mdi:bed
entity: climate.living_room
layout: horizontal
icon_color: |-
{% set state=states.climate.living_room.state %}
gray
{% elif state=='heat' %}
deep-orange
green
{% endif %}
badge_icon: >-
'hvac_action') %}
none
mdi:clock-outline
mdi:fire
{% endif %}
badge_color: >-
'hvac_action') %}
none
disabled
deep-orange
{% endif %}
- type: conditional
conditions:
- condition: user
users:
- a3728a103fdb4eb3bfe48c88a6abf391
card:
primary: Master Bed
secondary: >-
{{ state_attr('climate.master_bedroom',
'current_temperature') }}Āŗ C
icon: mdi:bed
entity: climate.master_bedroom
layout: horizontal
icon_color: |-
{% set state=states.climate.master_bedroom.state %}
gray
deep-orange
green
{% endif %}
badge_icon: >-
{% set state=state_attr('climate.master_bedroom',
'hvac_action') %}
none
mdi:clock-outline
mdi:fire
{% endif %}
badge_color: >-
'hvac_action') %}
none
disabled
deep-orange
{% endif %}
cards:
primary: '{{ states(''sensor.next_waste_collection'') }}'
secondary: '{{ state_attr(''sensor.next_waste_collection'', ''scheduled'') }}'
icon: '{{ state_attr(''sensor.next_waste_collection'', ''icon'') }}'
entity: sensor.next_waste_collection
icon_color: '{{ state_attr(''sensor.next_waste_collection'', ''icon_color'') }}'
hold_action:
action: none
double_tap_action:
action: none
badge_icon: ''
badge_color: ''
tap_action:
action: navigate
navigation_path: '#waste-collection'
primary: >
{% if state_attr('calendar.twickenham_event', 'message') ==
None %}
Twick Stadium
{% else %}
{{ state_attr('calendar.twickenham_event', 'message') }}
{% endif %}
secondary: >-
None %}
Check
{% else %}
{{ as_timestamp(state_attr('calendar.twickenham_event','start_time')) | timestamp_custom('%d %-b | %H:%M') }}
{% endif %}
icon: mdi:stadium
entity: calendar.twickenham_event
icon_color: >-
None %}
red
{% else %}
blue
{% endif %}
multiline_secondary: true
tap_action:
action: navigate
navigation_path: '#twickenham-event'
cards:
- type: custom:mushroom-vacuum-card
icon_animation: true
commands:
- start_pause
- return_home
layout: horizontal
icon: mdi:robot-vacuum
entity: vacuum.dexter
tap_action:
action: navigate
navigation_path: /lovelace/dexter
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background:
{% if states(config.entity) == 'docked' %}
rgba(76, 175, 80, 0.2) !important; /* Light green */
{% elif states(config.entity) == 'cleaning' %}
rgba(33, 150, 243, 0.2) !important; /* Light blue */
{% elif states(config.entity) == 'unavailable' %}
rgba(244, 67, 54, 0.2) !important; /* Light red */
{% endif %}
ha-state-icon {
color:
rgb(76, 175, 80); /* Green */
rgb(33, 150, 243); /* Blue */
rgb(244, 67, 54); /* Red */
{% endif %}
!important;
icon: phu:irobot
tap_action:
action: url
url_path: app://com.irobot.home
styles:
card:
- height: 100%
- width: 60px
- square: true
columns: 4
type: grid
cards:
- type: custom:mushroom-light-card
entity: light.lights_ground_floor
icon: mdi:home-floor-g
tap_action:
action: navigate
navigation_path: '#ground-floor-lights'
secondary_info: none
layout: vertical
use_light_color: true
icon_color: yellow
entity: light.lights_first_floor
icon: mdi:home-floor-1
tap_action:
action: navigate
navigation_path: '#first-floor-lights'
layout: vertical
icon_color: yellow
entity: light.lights_second_floor
icon: mdi:home-floor-2
tap_action:
action: navigate
navigation_path: '#second-floor-lights'
layout: vertical
icon_color: yellow
layout: vertical
icon: mdi:tree
tap_action:
action: navigate
navigation_path: '#outdoor-lights'
entity: light.lights_outdoor
use_light_color: false
icon_color: yellow
- type: grid
cards:
- type: custom:stack-in-card
cards:
- type: custom:mini-media-player
entity: media_player.sonos_all_inside
artwork: full-cover
background: /local/images/cover_art_speaker.png
hide:
controls: true
icon: true
info: true
mute: true
power: true
progress: true
source: true
volume: true
runtime: false
tap_action:
action: url
url: app://com.sonos.acr2
card_mod:
style: |
ha-card {
aspect-ratio: 1 / 1;
border-width: 0;
margin: 12px;
transform: translate3d(0,0,0);
-webkit-transform: translate3d(0,0,0);
content: "";
background-size: contain;
filter: drop-shadow(4px 4px 6px rgba(0, 0, 0, 0.5));
border-radius: var(--control-border-radius);
--mmp-overlay-color: rgba(0,0,0,0);
- type: conditional
conditions:
- entity: media_player.sonos_all_inside
state_not: 'off'
state_not: idle
card:
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: false
controls: true
more_info: false
toggle_power: false
group: true
card_mod:
style:
mmp-progress$: |
paper-progress {
{{ '--paper-progress-container-color: rgba(var(--rgb-indigo-color), 0.2) !important;' if is_state(config.entity, 'playing') }}
ha-card {
margin: 0px 12px 6px;
--mmp-progress-height: 12px !important;
height: var(--mmp-progress-height);
--mmp-accent-color: rgb(var(--rgb-indigo-color), 0.3);
--mmp-border-radius: 12px !important;
--ha-card-border-width: 0;
- type: custom:mushroom-media-player-card
use_media_info: true
icon_type: icon
collapsible_controls: true
show_volume_level: false
volume_controls: []
media_controls:
- next
- play_pause_stop
- previous
- shuffle
- repeat
icon: mdi:play
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
mushroom-state-info$: |
.secondary:after {
content: " | {% if 'media_player.garden_patio' in state_attr(state_attr('media_player.sonos_all', "active_child"), 'group_members')|list or 'media_player.garden_terrace' in state_attr(state_attr('media_player.sonos_all', "active_child"), 'group_members')|list %}{{ state_attr(state_attr('media_player.sonos_all', "active_child"), "friendly_name") }} + {{((state_attr((state_attr('media_player.sonos_all', 'active_child')), 'group_members'))|list|count)-1 }} | Garden{% else %}{{ state_attr(state_attr('media_player.sonos_all', "active_child"), "friendly_name") }} + {{((state_attr((state_attr('media_player.sonos_all', 'active_child')), 'group_members'))|list|count)-1 }}{% endif %}"
mushroom-shape-icon {
display: flex;
{% set media_type = state_attr(config.entity, 'media_content_type') %}
{% set source = state_attr(config.entity, 'source') %}
{% if source == 'TV' or media_type == 'tvshow' %}
--card-mod-icon: mdi:television-classic;
animation: flicker 1s linear infinite alternate;
{% elif media_type == 'movie' %}
--card-mod-icon: mdi:movie-roll;
animation: spin 2s linear infinite reverse;
{% elif media_type == 'music' %}
--card-mod-icon: mdi:music;
animation: beat 1.3s ease-out infinite both;
{% elif media_type == 'playlist' %}
{% else %}
--card-mod-icon: mdi:play;
{% endif %}
{{ 'animation: none;' if not is_state(config.entity, 'playing') }}
@keyframes flicker {
0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
@keyframes beat {
0%, 60% { --icon-symbol-size: 21px; }
5%, 17%, 57% { --icon-symbol-size: 22px; }
10%, 20%, 51% { --icon-symbol-size: 23px; }
25%, 45% { --icon-symbol-size: 24px; }
30%, 39% { --icon-symbol-size: 25px; }
33% { --icon-symbol-size: 26px; }
ha-card {
box-shadow: none;
volume_controls:
- volume_mute
- volume_set
- volume_buttons
media_controls: []
show_volume_level: true
use_media_info: false
icon_type: none
primary_info: none
card_mod:
style: |
ha-card {
box-shadow: none;
cards:
- type: custom:mushroom-chips-card
alignment: justify
chips:
- type: template
icon: mdi:speaker-multiple
double_tap_action:
action: none
tap_action:
action: navigate
navigation_path: '#sonos-groups'
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 13px;
margin-right: 2px;
margin-left: 10px;
margin-bottom: 12px;
--chip-background: rgba(var(--rgb-disabled), 0.1);
--chip-box-shadow: none;
--chip-border-radius: 12px;
--chip-border-color: rgba(0, 0, 0, 0);
--chip-height: 40px;
--chip-padding: 10px;
mush-chip-icon-size: 40px;
box-shadow: none
- type: template
entity: input_button.sonos_everywhere
icon: mdi:home-circle-outline
tap_action:
action: toggle
double_tap_action:
action: none
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 13px;
margin-right: 2px;
margin-left: 0px;
box-shadow: none
- type: template
entity: input_button.sonos_downstairs
content: ''
double_tap_action:
action: none
tap_action:
action: toggle
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 13px;
margin-right: 2px;
margin-left: 0px;
box-shadow: none
- type: template
entity: input_button.sonos_top_floor
content: ''
double_tap_action:
action: none
tap_action:
action: toggle
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 13px;
margin-right: 2px;
margin-left: 0px;
box-shadow: none
- type: template
entity: input_button.sonos_garden
icon: hue:room-outdoors
content: []
double_tap_action:
action: none
tap_action:
action: toggle
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 13px;
margin-right: 2px;
margin-left: 0px;
box-shadow: none
- type: template
entity: input_button.sonos_volume_sync
icon: mdi:volume-equal
double_tap_action:
action: none
tap_action:
action: toggle
hold_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 13px;
margin-right: 10px;
margin-left: 0px;
box-shadow: none
- type: grid
cards:
- type: custom:frigate-card
view:
default: live
dark_mode: 'off'
timeout_seconds: 60
update_force: true
menu:
buttons:
frigate:
enabled: false
live:
enabled: true
priority: 79
clips:
enabled: true
snapshots:
enabled: false
media_player:
priority: 14
cameras:
priority: 100
timeline:
enabled: false
camera_ui:
enabled: false
style: overlay
position: right
cameras:
- camera_entity: camera.london_doorbell
title: Doorbell
live_provider: go2rtc
icon: mdi:doorbell
go2rtc:
modes:
- webrtc
- camera_entity: camera.london_front_door
icon: mdi:door
title: Front Porch
- camera_entity: camera.london_136b
icon: mdi:home-floor-b
title: 136b
image:
url: /local/images/test_pattern.png
mode: camera
layout:
fit: cover
position:
x: 0
live:
transition_effect: none
show_image_during_load: true
layout:
position:
'y': 0
x: 49
fit: contain
zoomable: true
auto_unmute: never
auto_play: selected
dimensions:
aspect_ratio_mode: static
primary: Front Door
icon: |-
{% if is_state('binary_sensor.front_door_sensor_iaszone', 'on') %}
mdi:door-open
{% elif is_state('binary_sensor.front_door_sensor_iaszone', 'unavailable') %}
mdi:door
{% else %}
mdi:door-closed
{% endif %}
badge_icon: ''
icon_color: |-
red
orange
{% else %}
green
{% endif %}
badge_color: ''
entity: binary_sensor.front_door_sensor_iaszone
tap_action:
action: more-info
primary: Courtyard Door
icon: >-
{% if is_state('binary_sensor.multisensor_courtyard_contact_a',
'on') %}
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
badge_icon: ''
icon_color: |-
red
{% else %}
green
{% endif %}
badge_color: ''
entity: binary_sensor.multisensor_courtyard_contact_a
tap_action:
action: more-info
primary: Patio Door
icon: |-
{% if is_state('binary_sensor.patio_door_sensor_iaszone', 'on') %}
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
badge_icon: ''
icon_color: |-
red
{% else %}
green
{% endif %}
badge_color: ''
entity: binary_sensor.patio_door_sensor_iaszone
tap_action:
action: more-info
- type: grid
cards:
- type: vertical-stack
cards:
- type: custom:bubble-card
card_type: pop-up
hash: '#ground-floor-lights'
close_on_click: false
auto_close: 60000
state: sensor.living_room_temperature
bg_opacity: 88
shadow_opacity: 60000
entity: light.entry
show_brightness_control: true
show_color_control: true
show_color_temp_control: true
icon: mdi:light-recessed
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.dining_room_main
name: Dining Room - Main
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.dining_room_pendants
name: Dining Room - Pendants
icon: mdi:globe-light-outline
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.living_room_main
name: Living Room - Main
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.kitchen_main
name: Kitchen - Main
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.living_room_lamp
name: Living Room Floor - Lamp
icon: mdi:floor-lamp
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.kitchen_side
name: Kitchen - Side
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.kitchen_pendant
name: Kitchen - Pendant
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.kitchen_led_strips
icon: mdi:led-strip-variant
name: Kitchen - LED Strips
layout: horizontal
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.under_stair_cupboard
icon: mdi:lightbulb
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
cards:
card_type: pop-up
hash: '#first-floor-lights'
auto_close: 60000
state: sensor.guest_room_temperature
entity: light.bottom_stairs
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.library_main
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.guest_room_main
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.guest_bathroom
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
cards:
card_type: pop-up
hash: '#second-floor-lights'
auto_close: 60000
state: sensor.master_bedroom_temperature
entity: light.top_stairs
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.study_main
name: Study - Main
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.study_desk_lamp
name: Study - Desk Lamp
icon: mdi:desk-lamp
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.master_bedroom_main
name: Master Bedroom - Main
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.left_bedside_lamp
name: Master Bedroom - Left Bedside Lamp
icon: mdi:desk-lamp
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.right_bedside_lamp
name: Master Bedroom - Right Bedside Lamp
icon: mdi:desk-lamp
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.master_bathroom
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
cards:
card_type: pop-up
hash: '#outdoor-lights'
icon: mdi:flower
auto_close: 60000
state: sensor.courtyard_temperature_sensor_temperature
entity: light.porch
show_brightness_control: false
icon: mdi:dome-light
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.courtyard
icon: mdi:wall-sconce-flat-outline
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.patio
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
entity: light.garden_main
icon: hue:floor-spot
icon_color: yellow
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px
cards:
card_type: pop-up
hash: '#heating'
icon: mdi:radiator
auto_close: 60000
- type: custom:mushroom-climate-card
icon: mdi:sofa-single
show_temperature_control: true
layout: horizontal
hvac_modes:
- 'off'
- auto
collapsible_controls: false
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
margin: 0px 8px 8px;
entity: climate.kitchen
icon: mdi:fridge
layout: horizontal
hvac_modes:
- 'off'
- auto
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
entity: climate.guest_room
icon: mdi:bed
layout: horizontal
hvac_modes:
- 'off'
- auto
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
entity: climate.library
icon: mdi:bookshelf
layout: horizontal
hvac_modes:
- 'off'
- auto
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
entity: climate.study
icon: mdi:desktop-classic
layout: horizontal
hvac_modes:
- 'off'
- auto
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
icon: mdi:bed
layout: horizontal
hvac_modes:
- 'off'
- auto
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
cards:
card_type: pop-up
hash: '#weather'
show_forecast: true
cards:
card_type: pop-up
hash: '#waste-collection'
name: Hounslow Recycling
- initial_view: listWeek
type: calendar
entities:
- calendar.london_borough_of_hounslow
cards:
card_type: pop-up
hash: '#twickenham-event'
- initial_view: dayGridMonth
type: calendar
entities:
- calendar.twickenham_event
cards:
card_type: pop-up
hash: '#sonos-groups'
auto_close: 60000
- type: custom:sonos-card
sections:
- grouping
predefinedGroups:
- name: Whole House
media: ''
entities:
- player: media_player.dining_room
volume: 15
- player: media_player.living_room
volume: 15
- player: media_player.kitchen
volume: 15
- player: media_player.guest_room
volume: 15
- player: media_player.library
volume: 30
- player: media_player.master_bedroom
volume: 15
- player: media_player.study
volume: 15
- name: Top Floor
media: ''
entities:
volume: 15
volume: 15
topFavorites:
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
Sections view (from YAML above) showing single column in HA Companion Android app:
Sections view (from YAML above) showing single column in Android Chrome:
Masonry view with essentially the same content showing two columns in HA Companion Android app:
