A raspberry pi turned into a Google Home, and it works!
Use this, is great
i got it working now and actually with little trouble.
the only trouble i have is that i need to restart appdaemon when i restart HA, so i need to figure that out.
but at this moment i can do this kind of conversation:
me> Alexa mach assistant an. (i need to speak in german to Alexa)
me> translate livingroom to dutch (i need to speak english to google)
google assistant> woonkamer (the response is in dutch)
follow up questions are also a bit buggy for now.
i am trying to get that right.
oke, i uploaded the appdaemon app to use google assistant with an input_boolean in HA.
can be found here.
https://github.com/ReneTode/My-AppDaemon/tree/master/Google_assistant_app
Can I use a switch to invoke the Google Assistant?
an input_boolean.
when it is turned on you can talk, after the conversation it automaticly turns off.
off course you can also use any kind of automation to turn the input_boolean on.
for instance:
open a door and say ā€œhello i am homeā€ to google
its actualy the same, but maybe you understand the instructions better :wink:
here you find install instructions.
Not sure if this is of interest, but I will be buying a copy for the Google Voice kitā€¦! https://www.raspberrypi.org/magpi/google-aiy-voice-magpi-57/
Pretty cool, but imo pointless needing a button to activate rather than ā€œhey googleā€ voice activation
MagPi folks said one could ā€œprogramā€ to use wake wordā€¦but no detail
You could use snowboy to do it or pocket sphinx.
Magic mirror, for?
Does this allow multi room synced music as the original Google home?
not yet, I think will come
There are a few variants out there as well.
Wake word
this method I do not like.
ANy python code that we can adapt, and use a switch like the xiami switch?
with the app i made you can use any switch you like :wink:
and with some rewriting it could be made to a script that you can call with a commandline switch.
thanks Rene, I just canā€™t install appdaemon, tried a couple of times and it did not work for me
like i said, you could also adapt that code to make a commandline switch.
and you asked for python code you could adapt :wink:
Sure, but my coding skill is below 0
