Add group.all_* with AppDaemon
Add Domain Group (group.all_<domain>s)
hacs_badge
Group All app for AppDaemon.
Adds a domain group to Home Assistant. The added domain groups will have the name group.all_<domain>s. e.g. if the domain light is specified, group.all_lights will be created.
With the legacy configuration, this will restore all hidden group.all_* groups that were removed in Home Assitant v0.104:
  • group.all_automations
  • group.all_covers
  • group.all_devices
  • group.all_fans
  • group.all_lights
  • group.all_locks
  • group.all_plants
  • group.all_remotes
  • group.all_scripts
  • group.all_switches
  • group.all_vacuum_cleaners
  • group.calendar
  • group.remember_the_milk_accounts
Installation
Download the group_all directory from inside the apps directory to your local apps directory, then add the configuration to enable the hacs module.
Example App configuration
Legacy Configuration
# Creates all legacy groups.  All newly created entity_id's will be added to the correct legacy group.
groups:
  module: group_all
  class: GroupAll
Only all switches
# Creates group.all_switches, the group will update when a new switch is added to home assistant.
groups:
  module: group_all
  class: GroupAll
  domains:
  - switch
Advanced
# Creates groups for all domains.
# Renames group.all_switches to group.switch_master
# Renames group.all_lights to group.light_master
# Any new entity_id that is created will be added to the correct group.
groups:
  module: group_all
  class: GroupAll
  domains: all
  track_new_entities: true
  group_config:
    switch:
    light:
  log_level: INFO
App Configuration
key optional type default description
module False string group_all The module name of the app.
class False string GroupAll The name of the Class.
track_new_entities True bool true Dynamically adds new entity_idā€™s to the entity list of a domain group.
domains True 'all' | 'legacy' | list 'legacy' A list of domain names. 'all' will create all available domains at startup. 'legacy' will create all avialable legacy domains. Adding your own list will only create those domain groups.
group_config True map A map for domain names.
log_level True 'INFO' | 'DEBUG' 'INFO' Switches log level.
Domain Map Configuration
name False string Friendly Name of the created group.
EDIT
Version 1.1 is out. There are a few breaking changes. This should be easier to configure and itā€™s more optimized. Unfortunately, the trade off for better performance was to remove the ability to find new domains.
HI Petro,
though my legacy groups are created the AD log throws this:
2020-01-21 08:15:26.603265 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.604559 WARNING AppDaemon: message: (legacy entity_id tracking) Adding domain script., args: ('DEBUG',)
2020-01-21 08:15:26.652417 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.653732 WARNING AppDaemon: message: (legacy entity_id tracking) Updating group.all_scripts with 275 entities., args: ('DEBUG',)
2020-01-21 08:15:26.819863 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.821061 WARNING AppDaemon: message: (legacy entity_id tracking) Adding domain light., args: ('DEBUG',)
2020-01-21 08:15:26.854826 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.856060 WARNING AppDaemon: message: (legacy entity_id tracking) Updating group.all_lights with 98 entities., args: ('DEBUG',)
2020-01-21 08:15:26.902577 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.904107 WARNING AppDaemon: message: (legacy entity_id tracking) Adding domain switch., args: ('DEBUG',)
2020-01-21 08:15:26.932342 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.933974 WARNING AppDaemon: message: (legacy entity_id tracking) Updating group.all_switches with 75 entities., args: ('DEBUG',)
2020-01-21 08:15:26.974627 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:26.976150 WARNING AppDaemon: message: (legacy entity_id tracking) Adding domain automation., args: ('DEBUG',)
2020-01-21 08:15:27.020514 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:27.021675 WARNING AppDaemon: message: (legacy entity_id tracking) Updating group.all_automations with 208 entities., args: ('DEBUG',)
2020-01-21 08:15:27.092467 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:27.094044 WARNING AppDaemon: message: (legacy entity_id tracking) Adding domain device_tracker., args: ('DEBUG',)
2020-01-21 08:15:27.131735 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:27.133073 WARNING AppDaemon: message: (legacy entity_id tracking) Updating group.all_devices with 107 entities., args: ('DEBUG',)
2020-01-21 08:15:27.238837 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:27.240384 WARNING AppDaemon: message: (legacy entity_id tracking) Adding domain remote., args: ('DEBUG',)
2020-01-21 08:15:27.252379 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:27.253490 WARNING AppDaemon: message: (legacy entity_id tracking) Updating group.all_remotes with 5 entities., args: ('DEBUG',)
2020-01-21 08:15:27.280510 WARNING AppDaemon: Log formatting error - 'not all arguments converted during string formatting'
2020-01-21 08:15:27.282107 WARNING AppDaemon: message: (legacy entity_id tracking) Creating listen state handle., args: ('DEBUG',)
probably not a true issue, but nonethelessā€¦
btw for my AD learning purpose: why did you call this App ā€˜eventsā€™? And not ā€˜group_allā€™ ? or is that simply a c&p remnant from another appā€¦
It hasnā€™t been updated for appdaemon 4. I believe logging changed, not entirely sure, Iā€™ll look into and post a change. I havenā€™t updated to AD4, when that happens, Iā€™ll make official builds.
Iā€™m not sure why logging was changed. It apparently needs some extra single argument? Not entirely sure. Docā€™s donā€™t mention the required argument but all the examples do.
@ReneTode care to comment?
Is this a valid log line?
self.log('foo', level='DEBUG')
if not, why? EDIT: Nevermind.
change line 175
self.log(f"({tracking} tracking) {msg.capitalize()}", self._level)
to
self.log(f"({tracking} tracking) {msg.capitalize()}", level=self._level)
Correct, reverted to Ad3 and all log errors were gone
you already found out it is :wink:
yeah keyword for level is now required, more in the line from regular logging.
great that you created this app.
but i would only listen for the selected domains. that will reduce the amount of callbacks quite a bit.
Couldnā€™t find out how to do that with the documentation. I wanted to do that. Whatā€™s the call?
EDIT: Namespace seems like it was integrations, not domain.
self.listen_state(self.cb, ā€œdomainā€)
entity ( str , optional ) ā€“ name of an entity or device type. If just a device type is provided, e.g., light, or binary_sensor. listen_state() will subscribe to state changes of all devices of that type. If a fully qualified entity_id is provided, listen_state() will listen for state changes for just that entity.
namespace is something else.
in general is a namespace a collection from entities and events.
everything from HA is in 1 namespace (if not set in the plugin settings it is default and doesnt need to be provided)
every plugin has 1 or more namespace, and you can use AD internal namespaces.
Ah yes, but you canā€™t feed it a list of domains to track. So Iā€™d need to make n listeners with less callbacks or 1 listener with n callbacks. Not sure which one is less taxing.
the difference wouldnt be great when you got all possible groups (allthoug sensors were not grouped, so if someone has a lot of sensors, it would be a great difference too)
but for sure if someone only uses 1 domain, the difference would be significant.
and you could also create the option that the group is only created once, and not updated. (make use of ONESHOT)
Iā€™ve been running this a few days on all, the performance hit is non existent. I think youā€™re over estimating how many resources the callback is actually using. Itā€™s 2 if statements that require almost no computing power. The only ā€˜taxingā€™ manipulation that happens is the string split.
How does appdaemons core work? Iā€™ve never bothered looking into it. Does each callback register a new thread? Most apps* keep the callback in the same thread. And if thatā€™s the case, then creating more listeners would be worse for the system then having less callbacks. Typically more threads = more cpu tax.
EDIT: By apps i mean applications. Not referring to appdeamon apps.
callbacks from an app are all in 1 thread.
so you use 1 app, so 1 thread.
and believe me, with a very busy system, you want to reduce the amount of callbacks.
but take a look at the admin interface. you will see the amount of callbacks your system has. i think it opens your eyes about how busy you keep the system if you listen for every state change.
thats why i also suggested the oneshot option. groups would only be build on startup, without the cost of extra cpu.
my system is already up to 100.000 callbacks a day. if i add your app as is, i would probably double that easy.
if you just add 1 listener for each domain it would also be possible to create 1 app for each domain.
using 1 thread for each domain. which would reduce the risk of building up a queue on very busy systems.
Ah ok, so the callbacks from all listeners go into a queue?
If you turn on the dynamic updating. You can turn that off so it only updates on startup:
events:
  module: group_all
  class: GroupAll
  track_new_domains: none
  track_new_entities: false
Know the thread count makes a difference. Iā€™ll swap the domain listeners. That wonā€™t be too difficult.
There still isnā€™t a better way for finding new domains. Maybe an event gets created when new items are added. Iā€™ll play around and see if thatā€™s the case.
i dont see you using any constraints, or oneshot option.
so it only updates once, but still generates callbacks for every state change.
im not sure, but i believe there is an event for new entities.
but it would make your app more complicated, because then you need to take care of 2 type of events (startup/reload and entity added)
i dont know if that would be worth the trouble, but for complicated systems it would make a difference.
Nope, it does not create the callback listener:
        if track_domains != OPTION_NONE or self._track_entities:
            # Listener to create new everything on state changes.
            self.applog("creating listen state handle.")
            self.handle = self.listen_state(self.track_new_items)
It wouldnā€™t take much effort. Itā€™s registering for an event vrs listening to all state changes. I built the app to be easily modifiable because I knew these conversations would likely happen.
ah, ok. i missed that you left out the listen_state and called the add_group from initialise directly.
i would have chosen to create the groups on the first state change, i think.
just trying to give you info to optimise, because ts an app that has a chance to be used by quite a few people. :wink:
and i really appreciate your efford!
Yeah, Iā€™m going to optimize it. I was under the impression that listeners were in their own threads. Iā€™ve tailored most of my apps this way.
Edit: Plus I need to update the one log line to use the kwarg level. So Iā€™m going to do it in optimizing/fixing in one shot.
Where is this admin interface? I asked you before about the move from HACS to that interface but I realized that I donā€™t know what interface you are referring to.
