thanks. I currently use generic calibration, is this correct?
Its not so easy to decide if one not know how cal. works.
I am still not sure about interaction between cal. and aggressive mode.
The latter would help the TRV to close so i know the boiler can be switched of if its warm in all rooms.
You need two temperature sensors. One next to your thermostat that is mapped to your climate entity. And a 2nd in the room as reference for the calibration.
//EDIT:
I reorder generic calibration and aggressive mode. First the new target will be calculated by aggressive mode and then the calibration offset will be added on top of the target temperature.
Hi @panhans,
I just wanted to get back to say that all Danfoss issues are now gone by me. After the update you mentioned there were still some small hiccups, but after some subsequent update they disappeared and now it’s all OK.
Now I’, going to buy you some coffee :-).
And I would suggest everybody who you helped should do the same – if a friend came to your house and debugged your heating, wouldn’t you at least buy them a coffee?
I would totally sign that. @panhans is taking care of every little problem or questions I have had. If its perfectly working or not (on my end it is), this project is totally worth it. I’ll also be refilling the coffee soon.
So after a lot of “try and error” and understanding at least a bit more i managed to fix the calibration issue (it seems so far). I had to modify the zha quirk for my thermostat.
What i did you can read here (another user with a similar question for this device):
But after a few hours i already see the calibration and offset values finaly match and are in the range the device can handle. Not sure it’s the most elegant solution and not sure it has no side effects i don’t discovered yet
At least i got sensible calibration / offset values between 0 and -2 now and no extremes like -20°C (instead of -2.0°C) anymore. Still not sure the device itself doesn’t mess it up with internal calibration functions. The AHC v4 blueprint seems to work fine so far. Fingers crossed
I will update the test version of v4 now. This is the first release candidate. But there are some breaking changes:
this version supports the newproximity integration. You don’t need to select an entity for this. Just define some persons, select them in your proximity service and select the zone of your proximity service
some tweaks and options got some new selectors in order to bring more structure in this mess of UI. I recommend to resetup your automations. At least you have to tick your tweaks and options again. Sorry for this!
Thank for your help, debugging and making this piece of blueprint reliable for everyone.
It feels like a fight against standards and faulty devices. But the main thing is that it works in the end and your apartments are warm and maybe you save a little money, too.
can you add switch for extarnal boiler etc. i am using sonoff thermostats my rooms i have dry contact on my combi and i have sonoff trvbz on my radiators. i want to use which room needs head trigger dry contact switch and all rooms is get heat dry contact off
