I am completely new to the world of Home assistant (and sadly also to the world of docker etc.). I have a fresh installation of Raspberry OS on my Raspberry Pi 400, then docker and afterwards portainer. Than I managed to install Home Assistant via portainer. So far so good. (only took me 10 hours ).
Now I have the problem that I am not able to go into the supervisor settings from my Home assistant. I can enable the advanced mode but the āSupervisorā tab that is supposed to pop up in the sidebar wonĀ“t come up. I tried rebooting in every different combination and several different browsers. It would not work. Now I am unable to install add-ons etc. and I canĀ“t use Home Assistant to its fullest potential.
I already searched this forum and the internet for two hours but can not find the solution. I read somewhere that the advanced mode is not working with docker. Is that true? If yes, why would you install Home assistant in docker in the first place?
There is no addon store when running the home assistant container version. See this thread.
Technically, the addons are themselves docker containers that are managed by the home assistant supervisor. What addons did you want to use? You generally can install the equivalent full version of the addon in docker. For example, you already installed portainer so wouldnāt need the portainer addon. I have zwavejs2mqtt, Zigbee2mqtt, and node red all installed independently through docker, but they still work with Home Assistant container. I can post install instructions on one you would need if Iām familiar with them.
I posted about reasons why in the thread below.
The main reason is you can install other software on the machine besides homeassistant. With hassos, you can only install addons. Other options include āsupervisedā, which has a lot of requirements (if using raspberry OS you already arenāt meeting them), and a VM, which isnāt as efficient at managing resources as docker.
If youāre not going to use the rpi for anything beside home assistant or the addons though, best to just use homeassistant os as detailed here, with full access to the addon store.
Thank you for your answers. Really appreciate it. So it seems that I have chosen a wrong way to install Home assistant.
Sadly I want to use the rpi for other things as well like pihole and nextcloud. So I thought my docker and portainer approach would the be right way.
In home assistant I want to use add-ons for waste management, alexaā¦ I think it will be too difficult for me to install all of them in seperate containers (just donĀ“t have the know-how).
Is there a possibility for me to use Home Assistant supervisor with docker(portainer) on the raspberry OS? It seems there is no installation guide, so it propably does not work.
What would your recommendation be for someone who needs it as simple as possible? Start from scratch again, try to install debian an then docker with home assistant supervisor?
The Debian supervised install is anything but simple. I really would not recomend it, and the documentation also has multiple warnings to steer people away.
If you donāt want to take the time to learn docker, and need to run other software, installing Home Assistant in a VM might be the way to go. Home Assistant and addons will run in the VM, and everything else like pihole and nextcloud will run outside it in raspberry OS. I havenāt installed a VM on raspberry (have on windows). Itās not the most efficient way but the raspberry 400 should have enough processing power to do it. Others im sure can weigh in.
VM install instructions are below
If the VM route doesnāt work for you, you might want to consider purchasing a seperate rpi just to run Home Assistant.
I hoped there would be a solution that everyone is working with, because to me it seems like that it should be a problem everybody is facing.
Would it be possible to run Home Assistant OS and then also use Nextcloud and something like pihole on the same raspberry?
I think I try to learn docker a little bit more and work via the containers. If that does not work I try a VM. Could you recommend a guide for a beginner with docker? Maybe in the first place install the containers for working with alexa or just some general approachesā¦
When you want to run home assistant, addons, and other nonaddon software all on the same machine, you will find there is no āperfectā easy solution. There are a lot of threads in the forum on people wanting an easy way to do this. Unfortunately, there isnāt one that is perfect, simple, and universally agreed on. There are also multiple ways to do it, all with their advantages and disadvantages, as mentioned above by running supervised, VM, or a container install. With the VM install, the are even more options, like proxmox. Itās nice to have all these options, but with so many options, it can lead to confusion.
I started with the container install. Iām not going to sugar coat it- it was painful. There is no comprehensive guide and I had to scour the forum, YouTube, and Google for various solutions as I ran into issues. Also, the minority of users run it this way. You are already ahead of where I was when I started by knowing how to use Portainer, so Iām sure with some time you could do it. Now that I know it though, I wouldnāt go back to a āsupervisedā install with addons.
Your best bet is to continue using portainer to setup and work with docker. I use it all the time and hardly have to mess with the command line at all. Most containers you install will give you sample docker compose files. You can use the stack option in portainer to use the compose to create your containers. See this guide which is pretty good.
As far as updating a container, itās as easy as clicking recreate and toggle āpull latest imageā to on. I posted more about how to do that here.
